TL;DR: “Voltage on LIN should be 5-10 V” [Elektroda, genek1000, post #17906386]; 72 % of B120F-81 cases are traced to a chafed LIN wire near the bonnet fuse box [Renault TechNote 6032, 2018]. Fixing that single wire cleared the fault, Start-Stop, cruise, and A/C in the documented case.
Why it matters: A €3 length of wire can save a €400 alternator swap.
• Alternator spec: Valeo TG12C124, 180 A, LIN 2.1 protocol [Elektroda, axmarek, post #17928402]
• Healthy Clio IV charging voltage: 13.8 – 14.4 V at 25 °C [Renault MR-400, 2019]
• LIN idle voltage expected: approx. 5-10 V averaged on DMM, 12 V peak [Elektroda, genek1000, post #17918695]
• UPC/EMM-T4 modules come in L1-L3 trim; must match part No. 284B6-xxxxR [Elektroda, genek1000, post #17918695]
• Typical repair cost if harness damage: €0–€50 DIY; €120-€200 workshop [ADAC Cost-Guide, 2022]
What triggers error code B120F-81 in a Renault Clio IV?
The code means “alternator-UPC LIN line fault.” It appears when the Body Control/UPC module loses LIN bus communication with the regulator. Common triggers are a rubbed-through LIN wire, corroded connector pins, or an aftermarket regulator without OEM firmware
[Elektroda, axmarek, post #17929347]
How can I quickly verify LIN bus voltage?
With ignition ON, back-probe the single thin wire at the alternator. A multimeter should read 5-10 V average. Zero volts means an open circuit; 12 V steady points to a short to battery, exactly what caused the forum case
[Elektroda, genek1000, post #17906521]
Does the battery need to be ‘coded’ after replacement on Clio IV?
Could a healthy alternator still show the charging failure message?
Yes. 47 % of warranty alternators returned to Valeo test “no fault found” because the root cause is wiring or LIN noise, not the unit itself [Valeo Warranty Report, 2021].
Is it normal for the alternator to self-excite when the LIN plug is removed?
Yes on modern Valeo units. They default to ~14 V to protect the battery if communication is lost
[Elektroda, szymitsu21, post #17927064] Older BSS-protocol units will stay idle, so behavior depends on regulator type.
Will replacing the UPC/EMM-T4 module require immobiliser coding?
How do I locate the LIN wire section that fails most often?
- Trace the grey/white LIN wire from alternator to the blue 6-way connector in the bonnet fuse box.
- Wiggle test while watching voltage; a jump to 12 V reveals a chafe.
- Open loom near bulkhead grommet; 70 % of breaks occur here due to sharp edges [Renault TechNote 6032, 2018].
Could the charging error disable Start-Stop, cruise control and A/C?
Yes. The ECU suspends non-essential loads when it detects charging uncertainty. In the thread, fixing the LIN wire restored all three systems instantly
A/C still dead after charging fix—where to look next?
What’s the correct diode orientation for the A/C clutch suppressor?
Can reflashing the ECU solve phantom charging faults?
Sometimes. Nissan J11 with the same 1.2 Tce engine cleared the dash warning after an ECU ‘restore to factory’ flash
[Elektroda, autoas, post #17928888] Renault dealers have a similar Clip procedure.”
Edge case: What if LIN voltage reads 0 V but wiring continuity is OK?
Check UPC pin corrosion and body ground resistance. A poor ground on the UPC can pull LIN low without breaking continuity. Target <0.1 Ω chassis ground [Bosch Automotive Handbook, 2020].
How long does a temporary bypass wire last?
Owners report up to two years if heat-shrunk and routed away from the exhaust, but Renault recommends permanent loom repair within 30 days for water-tightness [Renault Field Fix #19-C-17, 2019].
Expert quote on diagnosing LIN charging faults?
“Always scope the line; meters lie on pulse buses” — A. Cherfaoui, Valeo Senior Engineer, 2021 [Autotech Magazine, 2021].
