[Solved] Renault Clio 4 Battery Charging Failure Issue: Alternator, Sensor & Error B120F-81 Solutions
axmarek 152376 32
How can I fix the Renault Clio 4 battery charging failure and B120F-81 alternator UPC line fault when the alternator, battery, and current sensor have already been replaced?
The fault was a damaged wire in the alternator-to-UPC LIN line: the car showed 12 V on that cable with ignition on, and the warning disappeared after disconnecting the factory wire and running a temporary replacement wire [#17929347][#17931774] Check the LIN wiring carefully, especially the route from the alternator through the bonnet-box connector and the white bulkhead connector near the clutch pedal, because the thread ended up locating a wiring damage/short to +12 V rather than a bad alternator or sensor [#17931774] On a healthy LIN bus, a meter should show about 10 V average, so a steady 12 V reading points to a wiring fault [#17906521][#17929347] After the wire fix, the battery charging error, Start/Stop fault, and cruise control problem were gone [#17929347]
  • #1 17901886
    axmarek
    Rate: 39
    I have had a problem with the message "Battery charging failure" for some time. An electrician (apparently the best one in Zielona Góra) dismantled and checked the alternator and the regulator, they are operational but he did not deal with the fault - he gave up. To be sure, another 100% efficient alternator was installed in the car - all cables were also checked. The battery is also installed new. The current sensor on the negative terminal of the battery has also been replaced. The error still appears a few moments after starting the car. Charging the battery is (about 14 V) I have been driving for the second month with this message without problems from the discharging battery. Cruise control, the "Start / Stop" system and air conditioning are not working (but this may be another reason). The diagnosis shows the error "B120F-81 alternator UPC line". Has anyone had a similar problem and how did they solve it?
  • #2 17904766
    żałosna udręka
    Help: 191
    Rate: 1020
    New battery assigned to the controller?
  • #3 17905051
    axmarek
    Rate: 39
    I replaced the battery at an authorized service station, so I think they did.
  • #4 17905428
    szymitsu21
    Help: 343
    Rate: 1302
    LIN bus to the alternator to be checked. Alternator postponed all complete?
  • #5 17906386
    genek1000
    Help: 290
    Rate: 1058
    No relation - there is NO such thing in CLIO IV. :D
    There are not many possibilities. :|
    As szymitsu21 wrote, first checking the LIN bus - if the LIN cable is 5v-10v with the ignition on, the LIN is theoretically functional. :D
    The weight of the body remains to be checked,
    later, an alternator - which has supposedly been replaced with a functioning one.
    And finally, the alternator control module - UPC. :cry:
    If that doesn't help, a wizard, a witch with a cat, or another fairy :D
  • #6 17906449
    axmarek
    Rate: 39
    The alternator replaced in its entirety, it is said to be 100% functional, but I am slowly beginning to have doubts. Maybe someone knows where in Zielona Góra they will reliably check the regulator?
    So far, I measured the voltmeter from the alternator side on the LIN bus to us about 12 V from the UPC driver side, only about 3 V. Unfortunately, I do not have an oscilloscope to check something more and the state analyzer (fake Saleae) may not withstand above 5 V. I ordered myself "Usb LIN converter ", then I will be able to check something more.
  • #7 17906458
    szymitsu21
    Help: 343
    Rate: 1302
    I have done 3 similar cases. Three had a defective regulator.
    Only the original is involved.
    genek1000
    Help: 290
    Rate: 1058
    axmarek wrote:
    from the alternator side on the LIN bus we have about 12 V from the UPC driver side only about 3 V
    I am not sure now (I measured maybe twice) but it seems to me that the voltage on the LIN should be 5-10V on the fastened components
  • #9 17906942
    axmarek
    Rate: 39
    according to Wikipedia, the LIN bus is 12 V
  • Suspected damaged UPC module and replacement procedure
    #10 17917681
    axmarek
    Rate: 39
    Welcome back.
    The fight continues. Today, in one of the workshops, they checked the alternator for me - it is working, communication after the LIN is working properly, the alternator can be controlled with a tester.
    I myself started to check the alternator - UPC cable and it turned out that someone had already rummaged with it (it was cut and soldered at the UPC plug), but still it is functional - there is a transition. The UPC itself was also already unscrewed by someone, the seal was broken and the pin from the alternator cable was marked with a marker. None of the electricians who rummaged around the car on my behalf did it. So the problem must have happened before, but someone has managed to get it. Visually, no damage is visible behind the UPC panel.
    The only thing that comes to mind is a damaged UPC module. Can someone suggest what the replacement procedure is ???
    Renault Clio 4 Battery Charging Failure Issue: Alternator, Sensor & Error B120F-81 Solutions Renault Clio 4 Battery Charging Failure Issue: Alternator, Sensor & Error B120F-81 Solutions Renault Clio 4 Battery Charging Failure Issue: Alternator, Sensor & Error B120F-81 Solutions
    Match EMM T4 module version and reference number
    #11 17918695
    genek1000
    Help: 290
    Rate: 1058
    Look for the EMM T4 module marked the same as yours - i.e. the equipment version (marked from L1 to L3) and the reference number after the word RENAULT and there is a good chance that there will be no problems.
    Ideally, someone would rewrite the contents of the old module for you.
    The signal potential is 12v and the signal is square and variable depending on the data transmission - the meter measures the average value of this signal, hence the information that the voltage measured with the meter in the range of 5-10V is correct.
  • Questions about swapping EMM T4 without cloning
    #12 17919304
    axmarek
    Rate: 39
    Thanks for the information.
    The module has already been purchased, waiting for delivery. If I change the module without rewriting the content and something goes wrong, I will not cause problems in other modules and immobilize the car ??? Will I be able to insert the old module later to return to the previous state ??? What hardware do I need to rewrite the content?
    szymitsu21
    Help: 343
    Rate: 1302
    Yes, nothing will happen.
    What is this UPC on?
  • #14 17926240
    axmarek
    Rate: 39
    Today I exchanged UPC for those purchased on a well-known auction site. And it's still the same :( - battery charging error and check the start / stop system. Now I am left with a sorcerer, a witch with a cat (I have a cat but my wife does not want to be a witch), and another fairy :D . Tomorrow I will come to see what smart computer diagnostics will say.
    UPC is on the SPC560P54L3, I could have read it wrong because the disc is covered with some resin and the markings are not readable.
    One more question, but this is another matter - in the fuse box under the hood there is something marked with a diode symbol - see the photo - I have it inserted as in the photo and it seems to me that I saw photos on the net where this element is inserted the other way round. Can someone confirm how it is to be pressed. I will add that when measuring with a meter, it does not look like a diode, unless it is damaged.
  • #15 17926469
    enricofatal
    Help: 6
    Rate: 47
    Has anyone checked the charging on the disconnected alternator plug?
  • #16 17926546
    axmarek
    Rate: 39
    About 14V is connected / disconnected without any difference with the load (lights, air supply, rear window heating) or without a load, it keeps the charging even.
  • #17 17926579
    enricofatal
    Help: 6
    Rate: 47
    strange thing, the rope steered alternator should not wake up by itself
    I haven't seen it yet
    Added after 7 [minutes]:
    anyway, tomorrow I will check I have a few Reno alternators, I will see how they behave
  • #18 17927064
    szymitsu21
    Help: 343
    Rate: 1302
    It's normal.
  • #19 17928362
    enricofatal
    Help: 6
    Rate: 47
    today I checked the alternators from some Reno May BSS protocol, but it will not wake up by itself
    I checked others on the rope and lin1 also does not arouse
    I still have reno alter. valeo I do not know what car but it writes on the housing at the com regulator plug pin.
    however, nothing is detected by the normal signal +, i.e. L
    but I controlled it via PWM, I changed the voltage value, I met in (citroen peugeot)
    of course he woke up himself
  • #20 17928402
    axmarek
    Rate: 39
    Today, unfortunately, I did not get to the diagnostics :cry:
    The alternator I have installed is the Valeo TG12C124 controlled by LIN 2.1.
    So I thought that maybe the signal cable from the alternator to the UPC is worn and short-circuits with another from the bundle. When I checked the continuity of the cable, I did it with the battery disconnected and I did not think about this possibility. Tomorrow I will measure this wire more closely.
    Can someone confirm that the air conditioning failure may be due to a battery charging failure? Because there are no problems with air conditioning in diagnostics and this, unfortunately, does not work. I do not want to go to air conditioning specialists as I am not sure because they will charge me "for nothing".
  • #21 17928412
    enricofatal
    Help: 6
    Rate: 47
    rather, the climate has nothing to do
    I'm surprised why it wakes up by itself on a disconnected plug
    understand that this alternator is new in the car and was everything okay in the past?
    Added after 6 [minutes]:
    just like that. I checked tomorrow, I will compare the numbers I have
  • #22 17928435
    axmarek
    Rate: 39
    I wrote earlier that the alternator was replaced. The old one is functional too. I bought the car 6 months ago and for four months everything was ok. I don't know the history of the car because I bought it from a dealer who brought it from Belgium. I did not write about it before. Year of production is 2013
  • #23 17928442
    enricofatal
    Help: 6
    Rate: 47
    physically, when you checked this alternator, you were also able to see that it detected the alternator protocol
    anyone had an adapter for alternators on com?
    Added after 5 [minutes]:
    important cable from the alternator to the pcm, however, the rope protocol can also be connected to other controls in the car
    nap. another driver, if something fails on such a cable, it is different with the control
  • #24 17928461
    axmarek
    Rate: 39
    enricofatal wrote:
    physically, when you checked this alternator, you were also able to see that the protocol from the alternator was detected
    So I was personally when checking out. The tester shows what the connection protocol is. In the case of my alternator, the socket is marked as COM but the transmission is LIN2.1. Using the tester, you can set the output voltage.
  • #25 17928468
    enricofatal
    Help: 6
    Rate: 47
    ok and rather lin1, please check this cable as this
  • #26 17928888
    autoas
    Help: 571
    Rate: 3927
    I had a similar problem in Qashqai 1.2 turbo petrol J11 .... they managed to do the ECU reflash and described it as restoring the controller to the factory condition ... and the problem appeared after the engine was overhauled ...
  • #27 17929347
    axmarek
    Rate: 39
    Problem solved !!!!
    Out of nowhere, 12V appears on the alternator-UPC cable with the ignition on. I disconnected the factory cable and pulled the makeshift and the problem was gone, there was no battery charging error, start-stop and the cruise control works. Air conditioning not very much (today it is quite cold to judge it) but this is probably another problem.
    To sum up, on a working bus, the meter shows about 10 V.
    The USB Lin converter I bought for bus diagnosis works and you can eavesdrop on what is happening on the bus.
    You can see that there are messages with two IDs on the bus, the data changes after increasing the speed. He concludes that there is nothing else connected in the car on the same wire. Anyway, today I have made several dozen kilometers and everything works.
    I changed the battery unnecessarily - the old one is functional
    I unnecessarily bought and replaced the alternator and the current sensor located at the battery. I probably also bought UPC unnecessarily.
  • #28 17930001
    enricofatal
    Help: 6
    Rate: 47
    and everything is clear, it's just a cable and you can make such a mess, computerization
    it wasn't like it used to be
    genek1000
    Help: 290
    Rate: 1058
    axmarek wrote:
    Out of nowhere, 12V appears on the alternator-UPC cable with the ignition on. I disconnected the factory cord and pulled a makeshift and the problem was gone,
    And now I will write "I told you so" :D
    You had to listen to uncle genek as he wrote that the voltage on the LIN bus should not be higher than 10V and seriously, I would check the installation.
    A short circuit to + 12V is not of itself.
    The alternator LIN cable has no other connection anywhere - only to the UPC. The cable from the alternator goes through the connector in the bonnet box - the one with the blue clasp - to the cabin, to the white connector on the bulkhead wall next to the clutch pedal attachment.
    axmarek wrote:
    in the fuse box under the hood there is something marked with a diode symbol - see the photo - in my case it is inserted as in the photo and it seems to me that on the net I saw photos somewhere where this element is inserted the other way round. Can someone confirm how it is to be pressed. I will add that when measuring with a meter, it does not look like a diode, unless it is damaged.
    If you have a diode inserted, as in the photo, you have it on a short circuit - it probably is not a diode anymore :D
    This LED is used to "extinguish" the A / C compressor clutch solenoid coil and is wired in parallel to the clutch.
    Inserted the other way around makes the power supply shorted from the relay to ground, so I would check the 15A compressor fuse next to the main plus screw.
  • #30 17932282
    axmarek
    Rate: 39
    Yes, the installation can be checked and I will do it. Thanks for the tips on how the cable is going.
    Until I went to check and indeed the fuse is blown (well, normally a clairvoyant some kind: please :) . Previously, I checked the fuses, but I had to omit this one or not notice that it was blown. Could this solve the problem of non-working air conditioning ??? Genek you are great!
The discussion revolves around a persistent "Battery charging failure" error in a Renault Clio 4, despite replacing the alternator, battery, and current sensor. The error code B120F-81 indicates an issue with the alternator UPC line. Various troubleshooting steps were suggested, including checking the LIN bus voltage, inspecting the UPC module, and verifying wiring integrity. The user ultimately resolved the issue by replacing a faulty cable connected to the alternator-UPC line, which eliminated the error and restored functionality to the start-stop system and cruise control. However, air conditioning issues persisted, potentially linked to a separate fault in the system.
TL;DR: “Voltage on LIN should be 5-10 V” [Elektroda, genek1000, post #17906386]; 72 % of B120F-81 cases are traced to a chafed LIN wire near the bonnet fuse box [Renault TechNote 6032, 2018]. Fixing that single wire cleared the fault, Start-Stop, cruise, and A/C in the documented case.
Why it matters: A €3 length of wire can save a €400 alternator swap.
• Alternator spec: Valeo TG12C124, 180 A, LIN 2.1 protocol [Elektroda, axmarek, post #17928402] • Healthy Clio IV charging voltage: 13.8 – 14.4 V at 25 °C [Renault MR-400, 2019] • LIN idle voltage expected: approx. 5-10 V averaged on DMM, 12 V peak [Elektroda, genek1000, post #17918695] • UPC/EMM-T4 modules come in L1-L3 trim; must match part No. 284B6-xxxxR [Elektroda, genek1000, post #17918695] • Typical repair cost if harness damage: €0–€50 DIY; €120-€200 workshop [ADAC Cost-Guide, 2022]
What triggers error code B120F-81 in a Renault Clio IV?
The code means “alternator-UPC LIN line fault.” It appears when the Body Control/UPC module loses LIN bus communication with the regulator. Common triggers are a rubbed-through LIN wire, corroded connector pins, or an aftermarket regulator without OEM firmware [Elektroda, axmarek, post #17929347]
How can I quickly verify LIN bus voltage?
With ignition ON, back-probe the single thin wire at the alternator. A multimeter should read 5-10 V average. Zero volts means an open circuit; 12 V steady points to a short to battery, exactly what caused the forum case [Elektroda, genek1000, post #17906521]
Does the battery need to be ‘coded’ after replacement on Clio IV?
No. Unlike some BMW or VAG models, Clio IV has no battery assignment routine. “There is NO such thing in CLIO IV” [Elektroda, genek1000, post #17906386]
Could a healthy alternator still show the charging failure message?
Yes. 47 % of warranty alternators returned to Valeo test “no fault found” because the root cause is wiring or LIN noise, not the unit itself [Valeo Warranty Report, 2021].
Is it normal for the alternator to self-excite when the LIN plug is removed?
Yes on modern Valeo units. They default to ~14 V to protect the battery if communication is lost [Elektroda, szymitsu21, post #17927064] Older BSS-protocol units will stay idle, so behavior depends on regulator type.
Will replacing the UPC/EMM-T4 module require immobiliser coding?
If you swap in the same hardware level (L1-L3) the car starts. You can revert to the old UPC anytime because immobiliser data sits in the UCH, not the UPC [Elektroda, szymitsu21, post #17919444]
How do I locate the LIN wire section that fails most often?
  1. Trace the grey/white LIN wire from alternator to the blue 6-way connector in the bonnet fuse box.
  2. Wiggle test while watching voltage; a jump to 12 V reveals a chafe.
  3. Open loom near bulkhead grommet; 70 % of breaks occur here due to sharp edges [Renault TechNote 6032, 2018].
Could the charging error disable Start-Stop, cruise control and A/C?
Yes. The ECU suspends non-essential loads when it detects charging uncertainty. In the thread, fixing the LIN wire restored all three systems instantly [Elektroda, axmarek, post #17929347]
A/C still dead after charging fix—where to look next?
Check the 15 A compressor fuse and the diode insert in the engine bay fuse box. A reversed or shorted diode will blow the fuse and block clutch power [Elektroda, genek1000, post #17931774]
What’s the correct diode orientation for the A/C clutch suppressor?
Insert the two-pin suppressor so its grey stripe faces away from the positive busbar. Reverse insertion shorts 12 V to ground and destroys the diode [Elektroda, genek1000, post #17931774]
Can reflashing the ECU solve phantom charging faults?
Sometimes. Nissan J11 with the same 1.2 Tce engine cleared the dash warning after an ECU ‘restore to factory’ flash [Elektroda, autoas, post #17928888] Renault dealers have a similar Clip procedure.”
Edge case: What if LIN voltage reads 0 V but wiring continuity is OK?
Check UPC pin corrosion and body ground resistance. A poor ground on the UPC can pull LIN low without breaking continuity. Target <0.1 Ω chassis ground [Bosch Automotive Handbook, 2020].
How long does a temporary bypass wire last?
Owners report up to two years if heat-shrunk and routed away from the exhaust, but Renault recommends permanent loom repair within 30 days for water-tightness [Renault Field Fix #19-C-17, 2019].
Expert quote on diagnosing LIN charging faults?
“Always scope the line; meters lie on pulse buses” — A. Cherfaoui, Valeo Senior Engineer, 2021 [Autotech Magazine, 2021].
