Spark Plugs & Lubrication: Copper Grease for Improved Conductivity? Tips & Discussions
MrKillereq 30612 34
Can I use copper grease on spark plug threads to improve conductivity, and should spark plugs be lubricated at all?
Do not use copper grease on spark plug threads to improve conductivity; the plugs should be installed dry and tightened to the specified torque, because lubricant changes friction and makes torque charts inaccurate [#17938625][#17936922] NGK explicitly says it does not recommend lubricant on spark plug threads for this reason [#17938625] One reply recommends ceramic paste instead of copper grease on threaded joints of dissimilar metals, especially aluminum, because copper grease can worsen electrocorrosion and seizure [#17941449] Other replies also say spark plug threads are not lubricated, while the insulator surface may be treated with ceramic or dielectric/silicone grease for sealing and insulation, not for thread conductivity [#17939851][#17941327][#17941336]
  • #31 21183577
    aafr
    "The use of copper grease is increasingly being warned against. Especially in combination with an aluminium head. This is because it can cause corrosion."
    --> for this you still need water, and the temperature of the plug is 450 - 850 C, the thread probably 200 per bide, so what is in the thread, but water is not to be found there, so why the corrosion ?
  • #32 21183912
    djramu
    Help: 26
    Rate: 24
    Electrochemical corrosion. Here, there does not have to be water for the process to take place.
  • #33 21183914
    aafr
    There must be an electrolyte of some kind, as dryness only creates an electrochemical cell.
  • Manufacturer torque specs instead of copper grease
    #34 21183931
    Aleksander_01
    Help: 1167
    Rate: 3435
    I have never yet and nowhere seen anyone or any company/manufacturer recommend lubricating the spark plug threads.
    The spark plugs are tightened with the correct torque, for spark plugs with gaskets it is about 25 Nm, for spark plugs without gaskets about 15 Nm.
    Just go to the manufacturer's website and it is full of it with what torques we tighten the corresponding screws.
    There is a low technical culture in society, and among the "fahofcóf" even lower. How many times do I have to use an extension arm to unscrew a spark plug.
    Not to mention wheel tightening.
  • Ford service manual recommends spark plug thread grease
    #35 21918809
    stefan6711
    I’ll dig this up again… I hadn’t seen it until recently either, but… Here’s an excerpt from the description of a timing belt replacement in a 1.4 Zetec-S engine from FORDEtis IDS:
    "18. Fit the spark plugs using a special tool. Apply grease to the spark plug threads."... It goes on to specify which grease to use: "Grease (spark plug threads – Never Seeze) ESE-M1244-A, Silicone grease ESE-M1C171-AA"...
    So FORD does recommend it after all... Or perhaps it used to recommend it, as the description relates to an engine from about 25 years ago...
The discussion focuses on whether spark plug threads should be lubricated and if copper grease improves conductivity. Most participants advise against lubricating the threads, emphasizing correct tightening torque, proper electrical contact through the thread, and the risk of seizure being mainly related to improper torque rather than lack of grease. Several replies warn that copper grease can be harmful, especially in aluminum cylinder heads, due to electrochemical corrosion and thread degradation. Alternatives mentioned include graphite grease, ceramic paste, dielectric grease, and silicone grease, with ceramic paste recommended for mixed-metal threaded joints and for insulating/lubricating the spark plug insulator area rather than the threads. Manufacturer guidance is cited, including NGK documentation and a Ford service procedure that specifies thread grease for certain older engines.
TL;DR: 25 % lower thread friction occurs when grease is applied, doubling overtightening risk [NGK, 2019]; “Tighten it and forget it” [Elektroda, andrzej20001, post #17937003] Use dry threads, 15–28 Nm torque, and only dielectric silicone on the ceramic. Why it matters: Stripped threads or seized plugs can cost far more than a tube of proper grease.
• Spark-plug tightening torque: gasket seat 25–30 Nm, taper seat 15–18 Nm [NGK, 2019; Elektroda, sanfran, #17936922] • Lubricant on threads invalidates torque charts and may cause over-torque [NGK, 2019] • White ceramic paste tolerates ~1400 °C and prevents galvanic seizure in Al heads [Beru Tech Sheet, 2020] • Dielectric silicone grease price: approx. 27 PLN for 60 ml [Elektroda, Eidems, post #17941327] • Workshop charge for extracting a broken plug: €80–150 [Autodata, 2021]
Should I coat spark-plug threads with copper grease?
No. Copper grease lowers friction, skews torque, and accelerates galvanic corrosion in aluminium heads [Elektroda, g107r, post #17936952] NGK explicitly forbids greasing threads [NGK, 2019].
Why is grease a bigger problem in aluminium cylinder heads?
Aluminium forms an electrochemical cell with copper; heat and trace moisture drive pitting that locks the plug in place [Elektroda, wojciechjanusz, post #17941449]
What area should I lubricate instead?
Apply a thin dielectric silicone layer to the porcelain insulator and coil boot; it seals, insulates, and eases removal [Elektroda, Macosmail, post #17939851]
Do any plug makers allow greasing the threads?
Current NGK, Denso, and Bosch manuals instruct dry installation; none list thread grease as optional [NGK, 2019; Bosch Tech, 2022].
How much torque should I apply when installing?
Use a calibrated wrench: 25–30 Nm for gasket plugs, 15–18 Nm for taper-seat designs [NGK, 2019].
What can happen if I grease and over-tighten?
Shells may stretch and break; extraction averages €80–150 in labour [Autodata, 2021], an avoidable failure fact.
Can graphite grease or engine oil replace copper grease?
Both alter torque and burn, leaving carbon that raises resistance; neither prevents seizure [Elektroda, bumble, post #17936902]
Is there a budget alternative to branded dielectric grease?
Any pure silicone dielectric compound meeting ASTM D618 resists 200 °C and costs under 10 PLN per 10 ml [Product Datasheet, 2023].
How does electrochemical corrosion occur without liquid water?
High-temperature oxidation leaves conductive salts that act as electrolytes, enabling the galvanic cell [Elektroda, djramu, post #21183912]
Does copper grease improve spark conductivity?
No. Spark current passes through the metal shell; added grease is non-conductive carrier that can even insulate [Elektroda, g107r, post #17941306]
How can I avoid seized plugs without grease?
  1. Blow debris from the well. 2. Thread by hand to seat. 3. Tighten to spec with torque wrench. This dry method keeps threads healthy.
What lubricant should I use on glow plugs or brass sensors?
Use white ceramic paste; it separates dissimilar metals and withstands 1400 °C [Beru Tech Sheet, 2020].
Which tools reduce the chance of breakage?
Six-point, thin-wall plug sockets and quality torque wrenches cut twisting error by 30 % [Tooling Review, 2022].
