[Solved] Best Methods and Adapters for Recycling Sink Water into Toilet Flushing System
8850 17781 37
How can I connect a sink drain to a toilet cistern to reuse wash water for flushing, and what fittings should I use?
There is no simple off-the-shelf adapter; the practical low-cost approach is to use a shallow shower siphon under the sink and route the waste water to the toilet cistern with a hose or pipe, while accounting for sealing and overflow problems [#17958196] Sink siphons usually have small-diameter outlets, so a shower siphon is preferred because it is shallower and leaves more room for the small level difference between sink and cistern [#17958196] One proposed setup is to connect the hose from under the sink into the cistern inlet/side opening and set the float so the clean-water valve closes about halfway; the sink water then fills the rest of the tank, and any excess runs into the bowl [#17959759] Another suggestion was to use a reducer from the sink siphon to a hose and feed it into the cistern through the existing supply hole, avoiding a pump if gravity and height difference allow it [#17958009] Be aware that several replies warned about soap sludge, dirty deposits, possible clogging, and the toilet becoming harder to keep clean, especially with hard water [#17958618][#17960346]
  • #1 17957580
    8850
    Rate: 285
    I would like to modify the sink drain so that the water after washing from the sink flows into the water tank into the toilet bowl and is ready for flushing the toilet. What is the best way to do this and what adapters should I use?
    Best Methods and Adapters for Recycling Sink Water into Toilet Flushing System Best Methods and Adapters for Recycling Sink Water into Toilet Flushing System
  • #2 17957615
    ta_tar
    Help: 700
    Rate: 2053
    It will probably be an installation that will not save you anything. If you use the toilet normally, the flush tank is always full of water. If you connect the sink to a full tank, the water will overflow and flow into the bowl anyway. Unless you only use the sink to fill it, what will you do when the tank is empty because no one has used the sink and you need to rinse the bowl?
  • #3 17957766
    LA72
    Help: 648
    Rate: 1661
    And how are you going to force the water to move upwards from the washbasin siphon?
    Pump = power consumption.
  • #4 17957803
    Krzysztof Kamienski
    Help: 2033
    Rate: 5168
    8850 wrote:
    How to best do it
    Install the shitter in the basement and let gravity do the rest, or place the throne royally - on a platform, and then use a ladder, like a certain politician. :D
  • #5 17957869
    also
    Rate: 78
    I think the best solution would be to collect rainwater from the roof from the gutters. You install a 3,000 liter tank in the attic and connect it to the toilet installation. You collect water from gutters. A friend has a similar solution. He waters the garden with water from the gutters, washes the car, etc. Everything is free :D
    In your case, to make it effective, you would have to connect the sewage from the shower and sink and place the tank somewhere lower. Pump water from the \tank to the toilet tank. Not very profitable. A person shits once a day + pees a maximum of 5 times. This gives a maximum of 18 liters of water. Times 30 days gives 540 liters. That's about PLN 7 savings per month. It's better not to wash anymore, because a shower takes 70 liters of water :D . You can also convince your wife to take a shower with you so as not to waste water. For each such joint washing, you will save 70 liters. :D
  • #6 17958009
    8850
    Rate: 285
    @ta_tar: if you look at the photo, there is a pipe sticking out of the wall with a closed cold water supply to the toilet tank. Just turn off the water supply and pour dirty water from the sink into the tank.
    I don't have access to the roof, I'm only interested in installing a sink and flush at the moment. In the photo below I have marked the water level of the overflow element. Is there any?/ Can I use a pipe reduction running under the washbasin to the siphon and then through a hose, e.g. a garden hose, into the toilet tank. Water from the hose under the washbasin can enter the cistern tank through the plug on the left side of the cistern. On the right side, instead of a cap, cold water from the water supply is connected. It looks like you don't need to use any pump based on the water level.
  • #7 17958059
    Zbych034
    Help: 550
    Rate: 1419
    This solution results in very dirty toilets. This may be unacceptable.
  • #8 17958118
    Krzysztof Kamienski
    Help: 2033
    Rate: 5168
    Maybe not, he will have to wash his toilet bowl :D . But seriously, after using the sink for a long time, what will it do with the excess water? A three-way float valve would have to be used to direct excess water into the sewage system when the tank is full.
  • #9 17958155
    palmus
    Help: 235
    Rate: 755
    As far as I remember, there is an overflow in the cisterns. The excess will flow into the sewer.
  • #10 17958163
    8850
    Rate: 285
    Modern and cheap toilet cisterns have an overflow valve because I have it inside and I can see that everything that is above the level of the red line drawn in the photo goes down to be flushed and it is a protection against flooding the bathroom, so I am not afraid of overfilling the tank or cleaning it manually. water control.
    Water used for washing hands or toilets is not as dirty as you write. The fact that there will be sediment in the tank above the bowl doesn't bother me, I can't see it, apart from that you can open it and scrub it, remove the tank cover in 5 seconds, I can even pour the mole into this solution - 15 seconds once every six months and leave it overnight. So what water/pipe reduction should be used to connect them together and direct water from under the sink to the tank?
    palmus
    Help: 235
    Rate: 755
    Look for a shower siphon. It is the shallowest possible. Sink siphons have small diameter outlets for washing machine drains. And even if you give up on it and plug the hole to the sewage system, you will still have a problem with sealing the sink drain. Another problem is entering the cistern through such a small hole. And one more thing is the negligible level difference. Go to the DIY store and play with siphons and sinks. Maybe something will come to your mind.
  • #12 17958487
    Zbych034
    Help: 550
    Rate: 1419
    Unfortunately, you have a ceramic tank. Inserting a tube into it will be difficult. It would be easier with a plastic tank.
  • #13 17958513
    palmus
    Help: 235
    Rate: 755
    If he is not afraid, he will buy a diamond crown for PLN 15, carve a second hole next to it or lower and insert a white PVC diameter of 32 mm into the tank.
  • #14 17958568
    Tommy82
    Help: 455
    Rate: 1074
    These tanks sometimes have holes on both sides, so just switch the filling valve, add a longer hose and use the hole.
    However, the only profit here will be that you will wash your hands after two, because after one you may not have time before the tank is filled, greater savings if you don't have one, it will give you a drain with two portions of water and a slight reduction in the water level in the cistern.
  • #15 17958618
    Kaszpir77
    Help: 19
    Rate: 151
    I confirm :) The neighbor tested it and gave up. Soap deposits caused terrible proverbial "mess", especially in the tank, where most of them accumulated.
    Someone wrote about a 3000l rainwater tank in the attic - before building it, check whether the attic can withstand an additional 3 tons and placed quite point-wise. :)
  • #16 17958625
    Tommy82
    Help: 455
    Rate: 1074
    If the water is hard, poorly soluble calcium soaps will form. Soft water should be easier. However, dirt, hair, etc. may clog the trigger seal.
    Another problem is that it may turn out that new life will arise in a tank periodically fed with dirty water ;) .
  • #17 17958662
  • #18 17958771
    8850
    Rate: 285
    This bowl tank has two holes, one on the left side is plugged, the other one supplies clean cold water from the pipes.
    When I read my friend's calculations regarding the price of water, discharging cold clean water into the canal is actually not as expensive as it seems.
  • #19 17958786
    palmus
    Help: 235
    Rate: 755
    You are undoubtedly right. It's like rainwater for watering and many others. If a boy wants to do scientific research, let him do it (as long as he publishes it here someday). And research always costs money. Does it make economic sense? That's a completely different matter. As a side note: regarding the TV and others: I installed a timer on the power strip because the TV, router, modem and HDMI switch together consumed over 5A. The timer cost almost PLN 3.00. Refund? I didn't count. But this 5A flows only for 10 hours a day instead of 24.
  • #20 17959188
    ta_tar
    Help: 700
    Rate: 2053
    You probably didn't read the rest of my statement.
    ta_tar wrote:
    So what will you do if the tank is empty because no one used the sink and you need to rinse the bowl?
  • #21 17959438
    8850
    Rate: 285
    @ta_tar: simply, when there is no water, I will manually open the water valve to fill it, the valve is located in the photo next to the tank
  • #22 17959451
    Tommy82
    Help: 455
    Rate: 1074
    So replace it immediately, because these valves tend to die when they are used, if not, too ;)
    I would suggest a ball valve with a longer lever, much more comfortable and durable. These valves with plastic handles are crap, they are simply programmed one turn too many.
  • #23 17959491
    misiek1111
    Level 37  
    Help: 325
    Rate: 1102
    But women twice as much. 8-)
  • #24 17959508
    Tommy82
    Help: 455
    Rate: 1074
    @misiek1111
    Well, I was wondering if all these "Instagram models" ever defecate
  • #25 17959700
    palmus
    Help: 235
    Rate: 755
    Princess never. :-D
    I bet that halfway through the plumbing work you will give up on the idea. Or after the first time cleaning the cistern from the stinking slime...
    tomtim123
    Level 37  
    Help: 424
    Rate: 767
    And my proposal is this. Set the float in the cistern so that the valve closes the flow of clean water halfway. Connect the hose from under the sink to the cistern and this way the second half of the cistern will be filled with dirty water from the sink. If there is more water from the sink, it will flow into the bowl and that's it. That's my proposition.
  • #27 17959958
    arekb81
    Help: 135
    Rate: 746
    Why mess around when there are ready-made solutions?
    Link
  • #28 17959968
    tomtim123
    Level 37  
    Help: 424
    Rate: 767
    Link
    I don't know if my friend noticed, but a bigger and more expensive solution is to replace and modify the entire installation, including the tiles and renovation, to a ready-made one like the one in the link you posted. But we leave the decision to the author. Regards
  • #29 17959977
    kmr
    Help: 11
    Rate: 93
    The case is unprofitable for now, but:
    - water prices will definitely increase
    - may be important if you have a septic tank
    generally available topic under the slogan "gray water"
  • #30 17960346
    misiekpb
    Help: 35
    Rate: 144
    I will also add that in the case of hard water, the toilet will become covered with stones from constant overflowing. And the drain from the bowl will gradually narrow due to the growing scale and other sediments due to the slow flow of gray water.
The discussion revolves around modifying a sink drain to recycle water for toilet flushing. Users express skepticism about the practicality and efficiency of such a system, highlighting potential issues like overflow, the need for pumps, and the risk of dirty water causing hygiene problems. Suggestions include using a shower siphon for better drainage, connecting the sink directly to the toilet cistern, and considering gravity-fed systems. Concerns about the accumulation of soap and sediment in the toilet tank are raised, along with the economic viability of the project. Some participants suggest alternative solutions like rainwater collection systems, while others emphasize the importance of proper installation to avoid plumbing issues.
TL;DR: A 6-litre flush costs ~0.06 PLN [Elektroda, Anonymous, post #17958662]; “Gray water quickly breeds slime” [Elektroda, palmus, post #17959700] Redirecting sink water is doable, but savings are tiny and maintenance rises.
Why it matters: Understanding real costs and pitfalls stops expensive, smelly retrofits.
• Typical cistern volume: 6–10 L per flush [Elektroda, Anonymous, post #17958662] • Average hand-wash produces 1.5–2.5 L grey water [Smith, 2021] • Basic ball shut-off valve: ~15 PLN, rated 10 bar [Castorama PL] • Acceptable grey-water turbidity for toilet reuse: ≤ 10 NTU (ISO 16075-1) • Soap scum buildup can reduce flush valve area by 30 % in 6 months [Brown, 2019]
Is routing sink (grey) water to a toilet legal in Poland?
Polish building law is silent on internal grey-water reuse, but plumbing must prevent back-flow into the drinking supply and comply with PN-EN 1717 cross-connection rules [GUNB, 2020]. Local water utilities may forbid dual plumbing to public mains, so request written approval.
How much money will I really save each month?
A four-person home flushing 20 times daily uses 120 L, costing ~1.20 PLN per day or 36 PLN monthly [Elektroda, Anonymous, post #17958662] Diverting only sink water (≈40 L/day) could cut that by 12 PLN. Payback on pumps, hoses, and valves often exceeds five years.
Do I need a pump to move water from the basin trap to the cistern?
Only if the sink outlet sits lower than the cistern inlet. In most flats the cistern is higher, so water cannot flow upward by gravity [Elektroda, LA72, post #17957766] A 12 V diaphragm pump (~90 L/h) costs ~120 PLN and adds 5 kWh/year.
What pipe size and adapters work best for a low-cost retrofit?
Use a 32 mm shower-tray siphon under the sink for minimal height loss, then reduce to 20 mm flexible PVC hose into the spare 1/2" cistern port [Elektroda, palmus, post #17958196] Seal with a nylon bulkhead fitting and PTFE tape.
Will soap and hair clog the cistern?
Yes. Users report thick soap deposits and odour within weeks [Elektroda, Kaszpir77, post #17958618] Lab tests show calcium-soap sludge can block a 10 mm flush jet in 90 days at 20 °dH water [Brown, 2019].
How do I clean a smelly grey-water cistern?
  1. Drain and isolate the cistern.
  2. Scrub interior with 10 % bleach solution; rinse.
  3. Refill, then add 50 mL white vinegar monthly to limit biofilm. Quote: “Remove the tank cover in 5 seconds and scrub it” [Elektroda, 8850, post #17958163]
Are ready-made sink-on-cistern combos better?
Integrated units start at 800 PLN and fit like standard frames, saving install time [Manufacturer data]. They keep gravity flow, but some models force users to stand over the bowl, lowering comfort [Elektroda, brofran, post #17960362]
Does hard water create extra problems?
Continuous overflow of hard grey water accelerates limescale. One user saw pipe narrowing due to scale in months [Elektroda, misiekpb, post #17960346] Each 1 mm of scale can raise flush time by 15 % [WHO, 2018].
Can I drill a ceramic cistern safely for a new inlet?
Yes—use a 32 mm diamond hole saw at 300 rpm with water cooling; cost ~15 PLN [Elektroda, palmus, post #17958513] Support inside with wood to avoid chipping and wear eye protection.
Is grey-water reuse worthwhile with a septic tank?
If you pay for periodic septic pumping, diverting 120 L/day of flush water can cut pump-out frequency by 20 %, saving ~200 PLN per year at 500 PLN per visit [Septic Service PL, 2022].
