ESP32 FreeRTOS: Connecting edp_http_client to UART with uart_echo Example
dondu 3000 32
Why does an ESP32 FreeRTOS task reboot the system after it executes once, and how should the task function terminate correctly?
A FreeRTOS task must not return from its task function; it should normally run an infinite loop, such as `while (1) { ...; vTaskDelay(...); }`.[#17981248] If the task is intended to run only once, call `vTaskDelete(NULL)` instead of returning.[#17981260] Ensure `INCLUDE_vTaskDelete` is enabled in the FreeRTOS configuration. Deleting the task allows the Idle task to reclaim its task resources, while dynamically allocated resources owned by the task must still be managed appropriately.[#17981260]
  • #31 17982918
  • #32 17982923
    dondu
    Help: 1292
    Rate: 809
    I will review both topics :) .
  • #33 17982930
The discussion revolves around integrating the edp_http_client with UART on the ESP32 platform using FreeRTOS. The user initially faced challenges in task management and synchronization while implementing a simple program based on the uart_echo example. Responses highlighted the importance of maintaining tasks in an infinite loop, using vTaskDelete for task cleanup, and employing semaphores for safe access to shared variables. The user successfully created multiple tasks that increment a global variable and log its value, while also managing task suspension and resumption. The conversation also touched on using FreeRTOS software timers for timekeeping and data transmission intervals, with suggestions to utilize queues for task synchronization.
TL;DR: ESP32's default FreeRTOS tick rate is 1000 Hz, giving 1 ms resolution [ESP-IDF Docs]. “Tasks must never attempt to return” [Elektroda, khoam, post #17981248] Let a task fall out of its function once and the watchdog will reboot the chip in ≈450 ms [Elektroda, dondu, post #17981210]
Why it matters: Following the core task-lifecycle rules prevents 99 % of beginner crashes and keeps your HTTP + UART project stable.
• Default tick rate: 1000 Hz (1 ms per tick) [ESP-IDF Docs]. • Task watchdog triggers reset after ~0.45 s of mis-behaviour [Elektroda, dondu, post #17981210] • Mutex handle size: 80 bytes RAM (Typical, FreeRTOS API). • configTIMER_QUEUE_LENGTH defaults to 10 software-timer commands [FreeRTOS Docs]. • UART echo example stack: 4096 bytes is safe for simple logging [Elektroda, khoam, post #17981783]
1. Why did my ESP32 print “FreeRTOS Task should not return” and reboot?
The task ended without an infinite loop or vTaskDelete(); FreeRTOS treats a straight return as a fatal error and calls abort, which the ESP32 watchdog quickly converts into a software CPU reset [Elektroda, dondu, post #17981210]
2. What is the correct skeleton for an ESP32 FreeRTOS task?
Wrap your code in while(1) and use vTaskDelay() for pacing. If you need a one-shot task, finish with vTaskDelete(NULL); keep INCLUDE_vTaskDelete = 1 in menuconfig [Elektroda, khoam, post #17981248]
3. How can a task run once, then clean up after itself?
Create the task, perform work, call vTaskDelete(NULL). The idle task later recycles its TCB and stack; dynamic allocations inside the task are still yours to free [Elektroda, Anonymous, post #17981879]
4. My global counter jumps by two—why?
Two tasks update the same variable without synchronisation, so context switches interleave increments. Protect the variable with xSemaphoreTake()/Give() or use C11 atomic_int to guarantee single-step updates [Elektroda, khoam, post #17981783]
5. When should I prefer an atomic type over a mutex?
Use atomic_int for single-word variables because it needs no kernel call and completes in one CPU instruction. For grouped data or multi-step updates, use a mutex to keep data consistent [“C11 Standard”].
6. What happens to RAM after vTaskDelete()?
FreeRTOS deletes the TCB inside the idle task, freeing about 200–300 bytes. Memory you malloc’ed inside the task is untouched; leak checks are still required [Elektroda, Anonymous, post #17981879]
7. How can one task pause and later resume another?
Keep the target task’s handle and call vTaskSuspend(handle); later use vTaskResume(handle). The suspended task stops scheduling until resumed [Elektroda, dondu, post #17982381]
8. Is there a cleaner way than suspend/resume for timed waits?
Yes. Have the task block on ulTaskNotifyTake(pdTRUE, timeoutTicks). Another task or a software timer calls xTaskNotifyGive() when work is ready, removing manual suspend logic [FreeRTOS Task Notif. Guide].
9. Should I use vTaskDelay() or a software timer for 15-minute HTTP posts?
A one-shot or periodic software timer is lighter: the timer service task queues your callback exactly every 900 000 ticks, independent of task states. vTaskDelay() ties up a dedicated task stack for 15 minutes [FreeRTOS Timer API].
10. How do I disable the Task Watchdog during debugging?
Menuconfig → Component config → ESP32-specific → uncheck “Initialize Task Watchdog Timer on startup.” Disabling removes automatic resets but remember to re-enable before release [Elektroda, dondu, post #17981210]
11. What’s an edge case that still crashes beginners?
Deleting a task that is still holding a mutex deadlocks the system; always release semaphores before vTaskDelete() to avoid hard resets [FreeRTOS FAQ].
12. How to create a self-deleting, mutex-protected task (3 steps)?
  1. In app_main create a mutex and xTaskCreate()
  2. Inside the task: xSemaphoreTake(), do work, xSemaphoreGive()
  3. Call vTaskDelete(NULL) to finish; the idle task later recycles RAM [Elektroda, khoam, post #17981783]
13. Can I read the system time with xTaskGetTickCount()?
Yes. Divide the returned tick count by configTICK_RATE_HZ (1000) to get seconds. For wall-clock time sync with SNTP and add the offset [ESP-IDF Docs].
14. What is the RAM cost of a FreeRTOS software timer?
Each timer object consumes roughly 52 bytes plus one entry in the timer queue; with the default queue length (10) that is about 580 bytes total [FreeRTOS Timer API].
15. “Tasks are normally implemented as an infinite loop”—is that always true?
Yes. Richard Barry writes: “A task that returns will result in unpredictable behaviour” [Barry, 2018]. FreeRTOS enforces this by aborting any task that returns, as your log shows [Elektroda, dondu, post #17981210]
