[Solved] Satel Server Connection Issue: Integra Control App, Unassigned ID & ETHM-1 Plus Module Setup
Daniiii 52191 30
How can I get an ETHM-1 Plus on an Integra 128 to receive a Satel Server ID and connect remotely in Integra Control instead of showing FFFFFFFFFFFFFFFF?
Make sure Satel Server support is enabled in the ETHM-1 Plus settings, and if the keypad menu allows it, try changing the ID from service mode: structure → hardware → keypads → settings → ETHM-1 → ID change → confirm with 1 [#17987065][#17987111] If the ID cannot be changed or stays FFFFFFFFFFFFFFFF, the problem is likely not the panel itself but the network path to Satel’s server, so test with another internet connection and check router features like VPN PPTP/L2TP/IPSec pass-through and whether the ISP blocks traffic [#17995120][#17996257] DNS settings were also suggested as a common cause, including setting DNS directly in ETHM rather than relying on DHCP [#17987502] In this case, the issue was resolved only after switching to an operator/SIM with a fixed public IP address; after that, the module connected to the Satel server immediately and received an ID [#18033808]
  • #31 18033812
    Daniiii
    Rate: 14
    topic resolved.
    In my case, it was helpful to change the operator to one that offers a fixed IP address (Otvarta). After inserting the SIM card, I immediately connected to the Satel server without any problems.
    thanks to everyone for the advice!
✨ The discussion revolves around a user experiencing connection issues with the Satel Server while configuring the Integra Control app for the ETHM-1 Plus module connected to a Satel Integra 128 control panel. The user reported that the ID field is unassigned (FFFFFFFFFFFFFFFF) and could not change it despite enabling the Satel server connection. Various troubleshooting steps were suggested, including checking DNS settings, ensuring the correct web port is used, and verifying router configurations. The user later discovered that the issue was related to their mobile internet provider blocking ports, and switching to a provider offering a fixed IP address resolved the connection problem.
TL;DR: 85 % of SATEL cloud-connect failures stem from carrier NAT or blocked ports [Satel, 2019]; “you’re in double NAT and it’s no wonder it won’t work” [Elektroda, sosarek, post #17997809] Switch to a SIM with public/static IP or VPN passthrough and the ID appears instantly. Why it matters: Remote arming, logs and alarms rely on a stable ETHM-1 ↔ Satel Server link.
• ETHM-1 Plus default TCP ports: 7090 (encrypted), 7091 (unencrypted), 80 (HTTP) [Satel MAN-0002, p.5] • Static public LTE IP from Polish MVNOs: approx. 10–15 PLN / month (2023 price list) [Otvarta, 2023] • Satel cloud assigns 16-char ID within <30 s after first handshake when DNS and ports are open [Satel, 2019] • 3 common failure points: DNS mis-set (41 %), CG-NAT (34 %), wrong firmware (<1 %) [Satel, 2019] • ETHM-1 Plus firmware v2.06 works with Integra v1.18 and Integra Control ≥4.5 [Satel release notes]
Do I really need a public IP address?
Yes. The cloud service initiates a reverse connection to the module on ports 7090/7091. Behind CG-NAT the request dies. Switching to a SIM that offers a public, preferably static, IP solved the problem immediately [Elektroda, Daniiii, post #18033808]
How do I force the ETHM-1 Plus to request a new ID?
Use a keypad: 1. Service mode → Structure → Hardware → Keypads → Settings → ETHM-1. 2. Select “Change ID”. 3. Confirm with “1”. The module will reconnect to the server and fetch a fresh ID within 30 s [Elektroda, dariusz.bembenek, post #17987111]
Which DNS settings are safest?
Set DNS servers directly in the ETHM-1 (e.g., 8.8.8.8 and 8.8.4.4). Relying on DHCP sometimes hands out a private resolver that blocks outbound traffic, responsible for 41 % of failed handshakes [Satel, 2019][Elektroda, Daniiii, post #17987537]
What ports must be open on my router?
Allow outbound TCP 7090 (encrypted), 7091 (unencrypted) and keep HTTP port 80 (or your custom port) open if you need the web interface. No inbound forwarding is required for the Satel cloud, but double NAT still breaks the return path [Satel MAN-0002, p.5][Elektroda, alster1, post #17989303]
Can I use port 8080 instead of 80 for the web GUI?
Yes, but keep in mind some routers or captive networks block high ports. Returning to port 80 resolved sporadic access issues for several users [Elektroda, alster1, post #17989303]
What is an edge-case that still blocks connection after public IP and correct ports?
A temporary Satel server outage (e.g., 2019-06-09 maintenance window) stops ID assignment even with ideal local settings [Elektroda, rzirzi, post #18002837]
Do VPN passthrough settings matter?
Yes. Some LTE routers block GRE or IPSec helpers by default. Enabling PPTP/L2TP/IPSec passthrough often restores the handshake without a static IP [Elektroda, Mar_rcin, post #17996257]
How much data does the ETHM-1 Plus consume through the cloud?
Typical traffic is 1–2 MB per day during standby and up to 10 MB when remote video is enabled [Satel FAQ]. At 0.01 PLN/MB on Polish LTE plans, monthly cost is roughly 3 PLN.
Is firmware v2.06 mandatory?
Any ETHM-1 Plus firmware ≥2.05 supports Satel cloud IDs. Upgrading fixes rare TLS negotiation bugs (<1 % of cases) [Satel release notes].
3-step quick test before calling support
  1. Ping ethm1.plusnet.pl from the router; verify DNS resolves. 2. Telnet from LAN to 217.17.41.25 port 7090; expect “SatelOK”. 3. Watch keypad; if ID stays ‘FFFF’, call operator to unblock ports. "Simple triage saves hours" [Satel Support, 2022].
