[Solved] Ikea Medelstor GHE423CA1 Dishwasher - Error i30, Hissing Sound & Flooding Protection Issue
cyranek 32199 9
How do I fix an i30 anti-flood error on an Ikea Medelstor dishwasher that keeps hissing after the cycle ends?
The i30 error is usually caused by water in the base/tray triggering the anti-flood sensor, so there is no simple reset; the dishwasher must be pulled out and dried/checked [#18023658][#18023921] In this case, warming or drying the area around the filter/base made the machine start again, which fits the sensor having been disconnected by evaporated water [#18023752][#18023921] If the fault comes back, check the drain arrangement as well, because one user fixed a recurring problem by installing the drain pipe properly down to the siphon below [#18719024]
  • #1 18023613
    cyranek
    Rate: 38
    Hello!
    I have a dishwasher like in the subject (Ikea). Everything was ok until yesterday. The dishwasher washed the pots and did not turn off at the end, something hissing in it all the time. Once I had such a problem and it turned out that the filter in its lower part was dirty.
    This time also, mainly coffee particles. I cleaned it, turned it on again, but unfortunately it continues to hiss and after a while i30 error . In the manual I read that it is a protection against flooding. Now the question: is it a bug that she remembered or is there still something wrong, or maybe a reset is needed? Before I pull it out, I want to check everything to avoid it. Anyone have any idea?
    :arrow: I have corrected TONI_2003
    • Ikea Medelstor GHE423CA1 -zmywarka-zintegrowana__AA-1402866-2.pdf (1019.58 KB) You must be logged in to download this attachment.
  • #2 18023658
    UczenEl
    Help: 31
    Rate: 391
    You can't do without stretching
  • #3 18023752
    cyranek
    Rate: 38
    ... and yet yesterday evening I flooded the chamber where the filter was, with very warm water.
    The dishwasher has started today :) Thanks for showing interest. Hope it will work.
  • #4 18023921
    mrice
    Moderator of Home appliances
    Help: 2215
    Rate: 6957
    Because water evaporated from the base and disconnected the anti-flood sensor. The problem will most likely come back. Read about i30 errors on the forum (AEG and Elektrolux dishwashers) and you will find more than that.
  • #5 18024546
    cyranek
    Rate: 38
    OKAY. I will read.
    Question: Medelstor is which company?
  • #6 18024566
    nares
    Home appliances specialist
    Help: 1520
    Rate: 3392
    cyranek wrote:
    Medium to jaka company?
    Clone Electrolux, a.
  • #7 18637135
    kloon
    Did the rinsing error reappear? I have the same problem and I do not know whether to call the service or somehow deal with myself?
  • #8 18637162
    mrice
    Help: 2215
    Rate: 6957
    Depends on your mechanical skills. A sea of knowledge has already been written about the i30 error in electrolux dishwashers in this forum. Use the search engine, read and decide whether you are fighting alone or looking for a working website.
  • #9 18719024
    kloon
    A service technician came and replaced the pump. Unfortunately, when it left after a few cycles, the water was left again. I sat a bit and read on the forums. I found out that the drain itself may not be mounted like that. I installed a drain pipe to the siphon below and everything is OK.
  • #10 18719048
    cyranek
    Rate: 38
    However, I'm still ok, the problem has not returned
The discussion revolves around the Ikea Medelstor GHE423CA1 dishwasher, which is experiencing an i30 error, a hissing sound, and issues related to flooding protection. The user initially cleaned the filter, suspecting coffee particles as the cause of the problem. After cleaning, the dishwasher continued to hiss and displayed the i30 error, indicating a potential flooding issue. Other users suggested that the hissing could be due to water evaporating from the base, which might disconnect the anti-flood sensor. One user mentioned that a service technician replaced the pump, but the issue persisted until they adjusted the drain pipe installation. The conversation highlights troubleshooting steps and the importance of understanding the i30 error, particularly in relation to Electrolux dishwashers, which share similarities with the Ikea model.
