FIBARO Relay Switch LUA Configuration: Fixing Output Delay Issue
mssolutions 627 0
  • #1 18025592
    mssolutions
    Problem with FIBARO RealySwitch, request for help
    This is about configuring a Realy switch connected at the input with a bistable switch and two test bulbs.
    Configuration .
    - 1 click is to start output 1.
    - 2 clicks output 2
    - holding is to turn it off.
    The problem is that when I do 1 click it turns on the first one but when I do 2 click it first turns off 1 output then the second one lights up and then the first one again. Again the issue is. With the fade-out when pressing the button, first the first output switches off and only after a while the second output switches on. How do I make it so that there is no blanking and everything works together?
    I need help in finding the error/solution or I will have it programmed accordingly.
