Which cloud-local solution for data collection:domoticz/thinspeak?
JanuszKornas 1578 9
How can I build a local, Internet-independent system for collecting and visualising data from ESP8266/ESP32 projects, and is Domoticz, Blynk, or ThingSpeak the better choice?
A practical option is to run Blynk locally on a Raspberry Pi so the system keeps working without Internet, and on a local server you can set the energy-unit limit yourself; a hybrid setup with a local Blynk plus a reduced remote view is also possible [#18053851] [#18054153] [#18062251] If your main need is not only data collection but also graphs, alarms, and visualisation, choose the software based on those requirements; one user runs Domoticz as the management server, forwards data to InfluxDB and then Grafana for graphs, and uses Node-RED for extra logic, with ESP8266/ESP32, Tasmota, Espurna, and Arduino all fitting into that setup [#18053880] [#18053908] There was also a warning that future Blynk versions may stop allowing a private local server, although older versions may still work [#18062773] [#18063838]
  • #1 18053836
    JanuszKornas
    Help: 6
    Rate: 25
    I have a couple of projects that I've partly done, am doing, will be doing based on Arduino, but I'm increasingly fond of ESP8266/ESP32, so in the context of that I'm asking:
    1. home improvements, i.e. typical IoT,
    2. collecting voltage measurements from a dozen or more 12V batteries
    3. Ongoing supervision and monitoring of the parameters of the portable battery charger(s).
    So far with the help of the Arduin (ad 2 and 3) I have been doing attempts to collect data on an SD card, but I am expanding the system and have some first attempts with Blynk. Since in the absence of Net, this would stop working, I'm considering looking into something I can install locally on some Malinka and here the search engine mostly gives Domoticz, and if Domoticz and ESP8266, then ESPEasy. Meanwhile I'd rather stay with C/C++/ArduinoIDE or something similar. I don't want to learn Lua, or even less EspEasy.
    Please advise, is it better to learn Domoticz and communicate with it via JONSON (another thing to learn), or to collect a dozen data for my own server, are there other better solutions?
    I heard something about thingspeak - maybe that would be better?
  • #3 18053880
    TvWidget
    Help: 472
    Rate: 699
    In this type of solution, the main problem is not the collection of data itself, but its visualisation and possible notification of e.g. alarms. Consider what your requirements are in this respect and see if any ready-made software meets them.
  • #4 18053907
    JanuszKornas
    Help: 6
    Rate: 25
    khoam wrote:
    The Blynk server can also be set up locally:
    I haven't read it yet, but maybe you know: The Blynk app on the smartphone has a certain level of 2000 units which are consumed as I add more items to the visualisation on the phone. If I put the Blynk on a localhost, will the app on the phone also eat up these units?
    And, in order to push myself from ESP to Domoticz programming in C/C++/Arduino IDE, do I need to learn JONSON, as I haven't seen libraries, any ready-made ones? Did I write correctly that C/C++ and JONSON are enough to send/receive data from Domoticz?
  • #5 18053908
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    I have this configuration:
    Management server - Domoticz
    In addition, data from Domoticz goes to Influxdb and then to Grafana to have beautiful graphs.
    Not only ESPEasy works with the ESP8266, but also Tasmota and Espurna and Arduino. Plus NodeRed to get something that can't otherwise be done in an easier way.
    Current measurement sensors could be PZEM-004 or sonoff pow for example, or possibly stc-013.
    I use the stc-013 with the Esp32 to measure the current throughout the house, with data every 10 seconds flying to the Influxdb.
    In addition, there is still lighting via sonoff touch on Tasmota and via Node-Red voice control via Google Home mini.
  • #6 18054153
    oskar777
    Help: 76
    Rate: 243
    For graphs you can have this, although I confess I haven't run it yet
    https://play.grafana.org/d/vmie2cmWz/bar-gauge?orgId=1&refresh=10s
    You can have blynk locally and a truncated blynk on a remote server with basic information
    here is some description
    https://blynk.pl/auth-token-czyli-jak-zaadresowac-przesylke-w-blynk/
    Oskar-info
    Gidzińskiego 24/1, Warszawa, 02-293 | Tel.: 501XXXXXX (Show) | Company Website: http://oskar-info.pl
  • #8 18062773
  • #9 18063032
    oskar777
    Help: 76
    Rate: 243
    Unfortunately, there are many indications that it will no longer be possible to install a private local server in the next version of Blynk.
    Do you have any information on this more accurately?, possibly you can use an older version as it happens.
    Oskar-info
The discussion revolves around selecting a cloud-local solution for data collection in IoT projects using Arduino and ESP8266/ESP32. The user is exploring options for home improvements, voltage measurement from 12V batteries, and monitoring portable battery chargers. They have experimented with data collection on an SD card and Blynk but seek a local solution due to internet dependency. Domoticz is suggested as a management server, with additional tools like InfluxDB and Grafana for data visualization. Alternatives such as Tasmota and Node-Red are also mentioned. Concerns about Blynk's future local server capabilities and energy unit consumption are raised, with suggestions to consider the requirements for data visualization and notifications.
