Guidance on Connecting Two Houses to One Deep Well Pump: Selecting Reliable Brands
cysiu388 24084 8
  • #1 18060361
    cysiu388
    Hello. I need help/advice in solving water connections to two houses. I have a deep well that currently supplies one house, I need to connect another house to the same pump. He plans to have power supply from one house, a common pump and a water tank in each house. I would like the other house to not pump water into my tank while I am away, even if I have no pressure. I would like to ask for help in solving the problem, advice on what to buy and what brand to make the devices less reliable.
    Thank you in advance, best regards.
    bumble
    Level 40  
    Help: 609
    Rate: 1195
    If you don't have pressure, how can it not pump. You can use a self-filling pressure valve and then when your pressure becomes equal, the valve will shut off your house. Same thing in the second one. I don't see it otherwise.
  • #3 18060486
    cysiu388
    I don't know if I wrote it correctly. What I meant was that if I drain the water from the system in my house, e.g. in winter, I would like someone in the other house to be able to use the water ;)
    Mobali
    Help: 1355
    Rate: 3921
    At the beginning, I advise you to carefully consider entering this type of company for two houses. I don't know this specific situation, but... I know life! And I know many such conflicts that broke out over trivial things and effectively poisoned life for many years.
    If there is really no other option, you can drill a common well. But a common pump and hydrophore is not a good idea. How will you divide the costs of energy and necessary service? Who will supervise the system and who will be responsible? So I propose to share the costs for the well and then introduce two separate submersible pumps into it. In addition, each house should have its own hydrophore and individual installation. The advantage of this solution is also greater independence and safety in the event of a failure - with good systems, you can use a second system by borrowing water from a neighbor until the problem is fixed.
    And if it is necessary to have a common pump, one collective hydrophore can be placed underground (properly insulated, of course). This way, there is no dilemma about who should keep it and whose tank will take up valuable space. To sum up, with such a system it is possible to install a submersible pump, an expansion tank and a pressure switch ("press control") "in the well". At the exit, you only need to install a splitter for both buildings. This will work, but... I suggest still remembering the rule to install as few common parts as possible.
    To minimize possible disputes, the system can be expanded a bit more. The cost will not increase significantly. So, a common well with a common pump installed, from which two pipes with non-return valves need to be led out. Their main function will be to direct water only towards the hydrophores, but block the return towards the well. The pumps can also be powered from both houses - this can be done by two additional contactors that turn on the pump. However, these must be contactors with mutual locking of switching on, so that when an attempt is made to switch them on from both houses, only the power supply of the recipient whose pressure sensor in the hydrophore sent the signal first is switched on. In this system, each house is billed independently (more fairly) and in practice pays for the energy it used to pump its own hydrophore. In case of
    In case of mutual pumping of water, the costs will be divided more or less equally. You can also add solenoid valves to the system that open the water flow only when water is pumped. However, I think this is an unnecessary increase in the complexity of the system.
    mietek654
    Help: 140
    Rate: 292
    Hello, but you are trying to figure it out, all you need to do is install a shut-off valve in front of the hydrophore from which the water is to be drained. Replace the non-return valve together with the pressure switch in front of the branch. Regards
  • #6 18092071
    cysiu388
    Thanks for the help ;)
  • Pressure switch must sense hydrophore pressure directly
    #7 18093388
  • #8 18134579
    mietek654
    Help: 140
    Rate: 292
    A pressure switch, of course, behind the non-return valve, is probably logical.
The discussion revolves around connecting two houses to a single deep well pump while ensuring that one house does not draw water from the other when pressure is low. Suggestions include using a self-filling pressure valve to manage water flow and installing shut-off valves to prevent backflow. Some participants recommend separate submersible pumps for each house to avoid conflicts over energy costs and maintenance responsibilities. The importance of having individual hydrophores and installations for each house is emphasized for greater independence and reliability. Concerns about pressure switches and non-return valves are also raised, highlighting the need for proper system design to prevent excessive pump cycling.
