Choosing a Submersible Pump for a Single-Family Home: Market Pump vs Wilo
krehhones 6576 5
  • #1 16632186
    krehhones
    Gentlemen, what submersible pump should you buy for a single-family home. I have a deep well, one made of concrete rings. I would like to use this water for watering the garden. For now, I had a market pump for 800 zlotys, but I just feel that it is already unwell. I would like to invest something decent because he was pounding from the beginning, my friend wilo advises me. I associate the company, but rather with heating, they also have deep water tanks?
  • #2 16632367
    DiZMar
    Help: 2888
    Rate: 6635
    krehhones wrote:
    ... I have a deep well, one made of concrete rings. ..
    Deep sea with vertebrae? Something does not suit me here.
    link
  • #3 16632553
    mnichu13
    They are pretty cool in my opinion. I use wilo twi5 ", find yourself on the web, I will not put links to not spam. It costs about 1.5 thousand zlotys, but in my opinion it is worth spending if you want to have equipment for a long time. It has a lot of pros, it doesn't rust, it's basically easy for a layman to use, it can be dipped 17 meters and has a fairly large cable from 20 meters, I think.
  • #4 16633423
    jerry1960
    Level 37  
    Help: 284
    Rate: 1556
    What is the depth of this well, you need to know it to choose the lift height. What performance do you need, what power do you have. What is the performance of this well?
  • #5 16634288
    mfeiboo
    The pump you replaced is okay. If you have 100-150 meters of garden in the market, you won't manage it, the low pressure will be, in addition, if the garden hose is longer, it is a drama at all. In general, wilo does cool things in my opinion, pumps too. I plan to replace myself next year, because my pump is over 12 years old, so it's high time - I don't know if it will keep this season.
  • #6 16713391
    tadgra
    Help: 15
    Rate: 55
    Gentlemen, without exaggeration. 15 years ago, in Castorama, I bought a submersible pump of an Italian company with the symbol TM 10M CE 20MT for 850 PLN. It is drowned in a deep well with a diameter of 200mm at a depth of 24m. It was written on it that the lifting height is 80m, but it never gave so much. It supplies a 300 l hydrophore, 17 m from the water surface and I can easily fill it up to 3.8 atm. From this I supplied the whole two-story house where they didn't connect the water supply. Now it is mainly used for watering the lawn and I switch to the house when there is no water from the tap, which happens several times a year. I have a way out of the well outside and I connect a 50 m watering hose and I don't complain about the pressure, there is even a sprinkler spinning under the influence of recoiling water from it.
