Board Partition Wall: Best Techniques to Attach Boards (Plank Wall)
169kondi 16170 14
  • #1 18165396
    169kondi
    Level 4  
    Rate: 37
    Hello, I have a question how to attach such boards, I add an attachment. It's about a plank partition wall, just how best to fix them. Thank you for your help
  • #2 18165428
    Tommy82
    Help: 455
    Rate: 1073
    It depends on what conditions.
    As from scratch, for example, at the bottom for two carpentry pins, and at the top, from the top, to the suspended ceiling frame.
  • #3 18165665
    169kondi
    Level 4  
    Rate: 37
    But it is exactly when I put the pegs in, I will not fit the board unless there are 10cm gaps from the top and bottom
    Added after 5 [hours] 25 [minutes]:
    Can anyone help?
  • #4 18166302
    retrofood
    Help: 1140
    Rate: 4788
    There are no miracles, that's why @ Tommy82 clearly indicated that "like from scratch", i.e. there is no ceiling and you can operate the board. However, in the conditions existing as in the picture, it is not possible to simply make an invisible fastening. Unless you use some pins on the springs, e.g. magnetically retractable. But a skin for a layette does not pay off.
  • #5 18166330
    169kondi
    Level 4  
    Rate: 37
    It is not possible from the top, it needs directly from the floor to the ceiling, more I meant maybe there are some mounting pins that are first attached to the floor and ceiling and then the boards are put on them
  • #6 18166612
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1006
    Place two 30x30mm or 40x40mm stainless steel angles on the floor. The angles will be fixed to the floor and between the angles you will insert the boards. You can fix the boards by drilling holes in the angles and using stainless steel countersunk screws made of stainless steel. .
  • #7 18167146
    169kondi
    Level 4  
    Rate: 37
    I don't mean some angles at the top and bottom, I know how to do it, it's about the same effect as in the photo.
  • #8 18167307
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1126
    The photo shows as if there was a small gap between the plank and the floor next to the floor. Perhaps it is mounted on supports (I do not know, I do not remember the name of such fastening) which are attached to the bottom of the boards and then "tweak" these "supports" with a key so that the board rests against the ceiling and stands steadily. As you can see in the photo, there is enough space between the floor and the board to insert the "spinning" key.
    (I used a fragment of the photo contained in the topic)
  • #9 18167389
    169kondi
    Level 4  
    Rate: 37
    Exactly, I also associate something like this with such a support mount and I am looking only for how to track it: p maybe someone had something to do with something like that.
  • #10 18169024
    retrofood
    Help: 1140
    Rate: 4788
    The perfect place for any dirt to accumulate. It looks nice only in the photo, but you will curse it with your life, I mean someone who decides to do something like that ..
  • #11 18169178
    ladamaniac
    Level 40  
    Help: 721
    Rate: 2063
    It can look nice in the photo and in reality, for example, mounted with a jig. If you make a nice cap, you can hardly see it.
  • #12 18194973
    169kondi
    Level 4  
    Rate: 37
    Anyone else have any ideas, maybe some pegs or something similar
  • #13 18200428
    retrofood
    Help: 1140
    Rate: 4788
    169kondi wrote:
    Anyone else has any ideas, maybe some pegs or something similar
    You can use the dowels, but at the cost of creating an irremovable gap. There are no miracles.
  • #14 18200546
    zworys
    Help: 519
    Rate: 571
    The same effect as in the photo is given by properly matched plastic pads similar to those used in furniture, but then these boards have to be wedged from above. These are not typical boards, because "clean" wood works and ordinary boards, depending on the humidity, would loosen or bend with the same degree of wedging.
    These profiles are so thick that you can easily fit a plastic pin with a matching foot inside and wedge it on the other side (the less visible one), then masking the hole for the wedge.
✨ The discussion revolves around techniques for attaching boards in a plank partition wall setup. Users suggest various methods, including using carpentry pins, stainless steel angles, and supports that allow for adjustments. Some participants mention the challenges of achieving a clean look without visible fastenings, while others highlight the potential for dirt accumulation in gaps. Suggestions include using plastic pads for wedging boards and employing dowels, though these may create gaps. A video link is provided for further assembly guidance.
TL;DR: For a clean plank partition, use 2 stainless L‑angles (30×30–40×40 mm) with countersunk screws; "Place two 30x30mm or 40x40mm stainless steel angles" to secure boards. [Elektroda, kierbedz4, post #18166612]
Why it matters: This FAQ helps DIYers and pros choose secure, low‑visibility ways to mount vertical boards floor‑to‑ceiling without guesswork.
What’s the best way to attach plank boards floor-to-ceiling without removing the ceiling?
With a finished ceiling, a truly invisible fixing isn’t feasible. "It is not possible to simply make an invisible fastening." Specialized spring or magnetic pins exist but are costly and impractical for most builds. Choose discreet hardware or plan access if you need hidden fasteners. [Elektroda, retrofood, post #18166302]
What simple, sturdy hardware should I use for a clean look?
Use two stainless L‑angles, 30×30 or 40×40 mm. Fix them to floor and ceiling, drill the angles, then use stainless countersunk screws to secure the boards. This gives a rigid track while keeping fixings low‑profile behind the boards. [Elektroda, kierbedz4, post #18166612]
How do adjustable supports under the boards work?
Attach supports beneath the boards, then “tweak” them with a key until each board presses against the ceiling. Leave a small floor gap to insert the key and adjust. This method keeps the faces clean while providing upward pressure. [Elektroda, wojtek1234321, post #18167307]
How do I hide or finish the wedge/support hardware?
Use thick profiles so a plastic pin and matching foot fit inside. Wedge from the less visible side. Then mask the hole used for the wedge with a plug or cap for a near‑invisible finish. [Elektroda, zworys, post #18200546]
Is a small floor gap a problem in daily use?
Yes. A visible gap looks great in photos, but it becomes a dirt trap and a cleaning headache. "It looks nice only in the photo." If you still need access, plan removable trim. [Elektroda, retrofood, post #18169024]
Can I pre-install dowels/pegs and then slide the boards in?
You can, but you’ll create a gap you cannot remove later. That tradeoff is the cost of using dowels with a finished ceiling. Consider other methods if you want a tight floor junction. [Elektroda, retrofood, post #18200428]
How do I hide screws using a pocket-hole jig (like Kreg)?
Use a pocket‑hole jig to place hidden screws on the back. 1. Drill pocket holes on the board’s rear edges. 2. Position the board and drive screws into anchors or framing. 3. Cap pocket holes with matching plugs for a clean face. [Elektroda, wojtek1234321, post #18200598]
Will solid wood movement loosen a wedged installation?
Yes. Solid wood expands and contracts with humidity. "Clean wood works" and ordinary boards can loosen or bend under the same wedging force. Use stable profiles or plan adjustable tension. [Elektroda, zworys, post #18200546]
How much clearance do I need to tilt boards past pre-set pegs?
Plan for about 10 cm clearance to tilt boards in if pegs are pre‑installed. With less space, you may not fit the board past the pegs without forcing a gap. [Elektroda, 169kondi, post #18165665]
How did the photo achieve such a seamless look?
It can look great in real life when mounted with a jig. Add neat caps so fasteners are barely visible on the face. "If you make a nice cap, you can hardly see it." [Elektroda, ladamaniac, post #18169178]
How do I install using L-angles in three quick steps?
  1. Fix two stainless L‑angles (30×30–40×40 mm) to floor and ceiling. 2. Pre‑drill angle holes and board edges. 3. Use stainless countersunk screws to fasten boards through the angles, then cover as desired. [Elektroda, kierbedz4, post #18166612]
Can I attach the top directly to a suspended ceiling frame?
Yes. Fix the bottom with carpentry pins, then anchor the top into the suspended ceiling frame. This approach works well when starting from scratch with access above. [Elektroda, Tommy82, post #18165428]
What screw type should I choose to avoid rust or staining?
Use stainless steel countersunk screws with stainless angles. They resist corrosion and sit flush for a clean finish along the profiles. This pairing keeps the installation durable and discrete. [Elektroda, kierbedz4, post #18166612]
