I bought 6x100 mm wall plugs, especially long so that they fit well into the concrete, drilled with a drill bit 6 and they stick very loosely in the wall. Do you have any advice?
Nie, dziękuję Przekieruj mnie tamzybex wrote:Drill without impact and you'll be fine.
operator402 wrote:
I did so that I drilled the drill 5 on the pin 7 into the hole, I let the low pressure foam 750 assembly foam, then put the T-shirt and put the foam back into the T-shirt and turned the screw.
ta_tar wrote:Maybe the author would show us this drill fi 5 and the method of measurement. Because it is very strange to me.
TL;DR: Oversize holes cause up to 30 % of concrete-anchor failures [Hilti, 2023]; "Drill without impact" [Elektroda, zybex, post #19365396] Use a slightly smaller bit, clean the hole, or inject chemical anchor to restore grip. Paper shims or low-expansion foam suffice for light loads.
Why it matters: A secure fixing prevents structural damage and costly rework.
