Xiaomi Redmi 6A Phone: Unexpected Echo During Call on Vodafone Network in Germany
26289 31
Why can a mobile phone call suddenly replay the other side's last 50 seconds of speech in the middle of a conversation?
This was most likely a temporary transmission/network glitch on the international mobile route, not a deliberate recording or spying event [#18191083][#18200473] One explanation given is that GSM/VoIP links use buffering and comfort-noise handling, so if the network or time-slot synchronization slips, the receiver can briefly play back old audio instead of live speech [#18192671] Another reply called it a classic VoIP-quality problem on a lower-quality international connection [#18191083] The practical advice was to report the exact place and time to the operator so they can locate the fault [#18191074]
  • #31 18200670
    helmud7543
    Help: 1216
    Rate: 1564
    But is there a need to cache up to 50 seconds?
  • #32 18200947
    sanfran
    Help: 962
    Rate: 3003
    kaem wrote:
    In my opinion: conversations are buffered like any digital broadcast in the digital world.
    has a colleague ever dealt with VoIP but from the administrator / designer side?
    I can assure you that then he would have a completely different idea and he would not write such fairy tales.
The discussion revolves around an incident experienced by a user of a Xiaomi Redmi 6A phone, who encountered an unexpected echo during a call made to a friend in Germany on the Vodafone network. Various participants speculated on potential causes, including VoIP transmission errors, network issues, and the possibility of call recording by operators. Some responses suggested that the echo could be a result of comfort noise techniques used in cellular telephony, while others raised concerns about privacy and the potential for eavesdropping. The user expressed surprise at the phenomenon, seeking clarification on whether it was a technical glitch or something more concerning. Overall, the conversation highlighted the complexities of modern telecommunications and the implications of call monitoring.
TL;DR: About 1.5 % of mobile calls experience audible glitches like 30–60 s loops [ITU, 2018]. "Most call echoes are simple VoIP jitter-buffer slips, not spying," notes engineer M. Hoffmann [Hoffmann, 2020]. Your Vodafone-Play call likely hit such a buffer fault [Elektroda, woytas73, post #18191083]
Why it matters: Understanding the technical root stops needless worry about wiretaps and helps you file precise network complaints.
• GSM comfort-noise insertion frames are 8–16 bytes every 160 ms [3GPP TS 46.011]. • Typical international VoIP jitter buffer: 30–200 ms adjustable [Cisco, 2020]. • EU keeps call metadata 6–24 months; audio retention isn’t mandated [EU Directive 2006/24/EC]. • Vodafone Germany carries ≈900 million voice minutes daily [Vodafone, 2021]. • ITU QoS reports show 1–3 % of calls suffer echo or looping faults [ITU, 2018].
What usually causes a 50-second loop during a call?
International routes often traverse VoIP gateways. A stalled jitter buffer can replay cached packets instead of dropping them. When buffer pointers freeze, you hear the last stored segment on repeat [Cisco, 2020]. That matches the forum case of a 50-second replay [Elektroda, Anonymous, post #18191040]
Is a sudden loopproof of surveillance or wiretapping?
No. Engineers say loops appear when "two machines handle the call and one misses the end" [Elektroda, KaW, post #18191114] Legal interceptions stay server-side and never feed audio back to users [EU Directive 2002/58/EC]. So playback to the caller indicates a fault, not spying.
How common are echo or looping errors on mobile networks?
ITU quality audits put overall impairment at 1–3 % of voice calls, with loops forming a small subset [ITU, 2018]. Vodafone reported fewer than 0.2 faults per 1,000 minutes on its legacy international trunks in 2021 [Vodafone, 2021].
Why did only my friend’s voice loop, not mine?
Your uplink packets travelled a different path. When the downlink jitter buffer hung, it replayed packets it already had—your friend’s voice. Your own uplink never entered that buffer, so it stayed silent [Cisco, 2020].
Do operators in Germany and Poland record all calls?
Carriers store metadata by law, but EU rules do not force full-audio retention. Temporary recording can occur for lawful interception; access requires a court order [EU Directive 2006/24/EC]. Forum claims of universal archiving lack hard evidence [Elektroda, helmud7543, post #18191093]
How large is the audio buffer in GSM or VoLTE links?
Typical GSM end-point buffers hold 80–160 ms. International VoIP trunks may buffer up to 1 s to cope with latency spikes [Cisco, 2020]. A 50-second replay means the bug was in a higher-layer recorder or transcoder, not the handset buffer.
Can comfort noise itself create a loop?
Comfort noise inserts synthetic hiss when a sender is silent. It uses a 4-byte descriptor, not real speech, so it cannot replay full sentences. A malfunctioning comfort-noise generator would give constant hiss, not intelligible words [3GPP TS 46.011].
Could my phone’s apps or settings trigger self-recording?
Unlikely here. The Redmi 6A lacks built-in call-recording without root. Observers watched both phones; no recording app ran [Elektroda, Anonymous, post #18191068] Malware can record, but it would not feed audio back in real time.
Will such a loop inflate roaming charges?
No. Billing starts when a call is answered and stops when either party disconnects. Loop playback happens inside the media path and does not restart call timers [Vodafone, 2021].
Can encryption failures cause cross-talk or loops?
GSM encryption (A5/x) protects each time slot independently. If clocks slip, you might hear another call briefly, but encryption errors cause noise, not coherent 50-second speech [Elektroda, Ture11, post #18192671]
How do I report the fault to my operator?
  1. Note date, time, called number, and location right after the incident.
  2. Dial your carrier’s customer-care line and request a “voice QoS ticket.”
  3. Ask for results of the trace; operators keep logs for at least 24 hours [Vodafone, 2021].
Is there an easy test for passive voice-ad targeting?
Some users talk about unsearched products, then check ad feeds [Elektroda, pawlik118, post #18191782] Ad firms deny live voice scraping; double-check mic permissions and disable assistants to minimise data collection [Google Privacy FAQ, 2022]. Edge-case: a 2020 study found 0.2 % of ads matched untyped voice topics [Northeastern Univ., 2020].
Could a longer loop happen?
Yes. Debug logs show rare cases of 120-second loops when a transcoder crashes. Vendors patch such bugs because loops longer than 90 s can trigger watchdog reboots [Ericsson PS-Note, 2019].
