EVOBOX LITE Multi-Room Wi-Fi Issue: Connects to Hotspot/LAN But Not Main Router - Solutions?
toporczyk 24231 3
  • #1 18194419
    toporczyk
    Rate: 33
    The main decoder connects to the router via wifi, and the second (Lite) does not want to? It connects to any other network (e.g. a personal hot-spot) or a wired network (LAN), but does not want to wifi. I don't know - maybe it's requesting the same IP address or what? I have no idea what to do with this.
  • #2 18194669
    LeDy
    Help: 1990
    Rate: 2933
    All you need to do is connect the decoders with a twisted pair.
  • #3 18202786
    djmiller
    If it is not possible to run a UTP (internet) cable, you can also use PLC (Power Line) adapters. Thanks to them, you can use electrical sockets for signal transmission - it works in the same way as a wired LAN network.
  • #4 18250647
    kamilalek1
    Rate: 41
    I suggest changing the ssid name on the router to something else, then try to connect to this network using the lite decoder.
    You can still try to change the channel on the router.
