[Solved] Wisniowski Sliding Gate ST-2 Steering Unit: Dealing with H3 Static Overload Error
rsp1254 4014 1
  • #1 18225592
    rsp1254
    When I want to open the gate, the ST-2 module shows 'H3' error code: static overload protection. But there is no obstacle.
    If I move the metal support of the ST-2 module to release the motor, the gate moves manually without worries. The motor would be down? I know, it's not easy to answer :(
    I've switched off and on the steering module, no effect.
    If you have any ideas, thanks in advance.
    Regards
  • #2 18226256
    rsp1254
    Regards
    after several manipulations the engine no longer blocks ...
