[Solved] Solar Edge SE5K Inverter: Red LED & Failure - Need Help with Updated Model & New Manual
25773 6
  • #1 18229756
  • #2 18229834
    Adam-T
    Help: 834
    Rate: 1096
    czesterw wrote:
    I turned off the inverter.
    czesterw wrote:
    Now turn on the inverter again
    And it had to be done with an interval of several, several minutes. Perhaps there was a power outage (temporary) and something in the inverter hung up and needed just such a reset.
    Of course, the contractor should provide you with the current manual.
  • Temporary phase loss caused inverter shutdown
    #3 18231894
    Adam-T
    Help: 834
    Rate: 1096
    czesterw wrote:
    Does anyone have or know where to download the current manual?
    If you gave the full name of this inverter, it would be easier to find.
    Take care and enjoy.
    PS, of course, forget about Polish ;)
    • SolarEdge-Three-Phase-Inverter-with-SetApp-Configuration-Installation-Guide-v12.pdf (9.68 MB) You must be logged in to download this attachment.
  • #5 18235928
    Adam-T
    Help: 834
    Rate: 1096
    I will just add that the full name of this inverter, or rather the manufacturer's code, is SE5K-RW0TEBNN4. You can also search as "SE5K SetApp". This may be useful in the future when looking for instructions in Polish.
    czesterw wrote:
    Thank you very much for the information and sending me the instructions.
    You're welcome.
    czesterw wrote:
    I'm not closing the topic, because maybe someone has or knows where to download the current manual.
    I guess it can be closed now. ?
  • Found English manual and started translating it
    #7 18266007
The discussion revolves around a Solar Edge SE5K inverter that experienced a failure indicated by a red LED light, while the system showed no electricity production. The user, who received outdated installation instructions, faced difficulties diagnosing the issue due to the lack of a current manual. After identifying a temporary power loss to one phase, the user managed to reset the inverter. Assistance was provided by other forum members, who helped locate the correct manual and offered advice on the inverter's full name and model code. The user expressed gratitude for the support received and is currently translating the manual for better understanding.
