Connectivity Issue with Huawei B525 Router and Play Network Sim Card
Pawelmck 24855 5
  • Play SIM card incompatibility with B525 router
    #1 18249657
    Pawelmck
    I have a problem. B525 router, inside sim card play internet card. The router will not connect to the network. The light on the router is red. After putting the sim card into the phone, the internet works without any problems.
    Another card also from the Play network with a different tariff went to the router and connects to the network without any problems.
    I will mention that the B525 bought on the Allegro branded by the Play network.
    I am combining all the ways and nothing.
  • #2 18249753
    vieleicht
    Level 37  
    Help: 463
    Rate: 460
    After logging in, check in the router settings on this tab if there is an active connection to the cellular network. It is possible that the settings for different sim cards are saved somewhere. Well, maybe reset it at the start.
    And the pin on the card is disabled?
  • #3 18249795
    Pawelmck
    After logging in, after hovering over the range lines, there is the information that there is no service.
    Nothing was done with the pin on the card.
    Is it automatically turned on and should it be turned off?
    Pin off and still the same.
  • #5 18249978
    Pawelmck
    Updating the software to the latest one helped. Thank you for your help.
  • #6 18249985
    kejk1992
    Rate: 14
    Try to manually search for the network. (In Ethernet settings). Use the machine to search manually, etc.
    It helped me :)
