Electrical installation in a single-family house (do it yourself?)
pimis 26295 32
How should I plan and pre-install the electrical wiring in a single-family house so an electrician can finish it safely, and what should I consider for sockets, lighting, roller shutters, smart home, and cable routing?
Start with a full electrical design and let an electrician define what you can do yourself, because a house needs more than sockets and lights: main/local equipotential bonding, grounding, and other systems must be planned too [#18251116] [#18251786] For sockets, one circuit per room is acceptable, but dedicate high-power loads separately; for lighting, use 3x1.5 from the switch and 4x1.5 or 5x1.5 from the switch to the lamp if you want multi-channel control, and make the connections in a deep box with PE included [#18251155] Roller shutters and smart-home features must be decided before wiring, because local, group, and central control all require different cabling, and the exact wiring depends on the chosen system [#18253212] [#18258509] Do not chase grooves in structural columns or route cables randomly through them; if you need floor routing, use a flexible conduit and stick to the rule of one pipe, one cable [#18255196] [#18255571] [#18255818] For telecommunications, do not assume everything should end in the electrical switchboard unless it is designed as a dual-purpose cabinet; a separate telecom/rack solution is often cleaner [#18253226] [#18253231] [#18253242]
  • Alarm system integration for lighting and roller shutters
    #31 18264789
    suworow
    Help: 650
    Rate: 1278
    Roller shutters and, for example, lighting can also be controlled from the alarm system:
    Topics related to lighting control from Integra satellites.
    SMS lighting control + timer:
    https://www.elektroda.pl/rtvforum/topic3614490.html
    lighting control: astronomical clock, motion detectors, after an alarm and with a button or application.
    https://www.elektroda.pl/rtvforum/topic3618268.html
    satel integra lighting control:
    https://www.elektroda.pl/rtvforum/topic3619551.html
    blinds control:
    https://www.elektroda.pl/rtvforum/topic2638011.html
    Satel integra integration with fibaro:
    https://www.elektroda.pl/rtvforum/topic3548247.html
  • Recommend installing a PoE switch and spare conduits
    #32 21085478
    nspd
    Water to fridge, washing machine, dishwasher, outdoors to façade or manhole.
    Sewer to recuperator, air conditioner, dryer.
    Cables to recuperator, air-conditioning, intercom, between control panels and appliances e.g. boiler/recuperator, arot from box to outside so that cables can be added/replaced from gate/gateway/intercom etc., arot to internet box for fibre optics/cable
    Sockets in loft, external lighting.
    Cable on north wall for temperature sensor to boiler/machine room. Cables for roller shutters...
    https://techjoy.pl/do-czego-potrzebny-jest-switch-poe-i-jak-go-wybrac/
    It is also worth fitting a poe switch.
  • #33 21085493
    kortyleski
    Help: 957
    Rate: 3860
    Although not required it is a good idea to separate a completely separate circuit for the fridge. On a separate rcbo. The idea is that when you leave for a longer period of time you can disconnect the whole house except for the alarm and the fridge.
The discussion revolves around a DIY electrical installation in a single-family house, where the author seeks to perform tasks such as cutting grooves, laying cables, and installing boxes, with a qualified electrician completing the work. Key questions include the suitability of using YDYP 3x2.5 cables for socket circuits, whether to create separate circuits for each room, and considerations for integrating smart home technology. Participants emphasize the importance of planning and knowledge, suggesting that the author consult with the electrician for guidance. Various smart home applications, including roller blinds and lighting control, are discussed, along with the necessity of proper installation techniques and adherence to safety standards. The conversation also touches on the use of conduits for cable management and the potential for centralized control of devices.
TL;DR: 42 % of Polish home-owners do part of the cabling themselves [PIE, 2023]. “Design first, chase later” [Elektroda, CYRUS2, post #18251786] Plan socket radials (3×2.5 mm²), lights (3×1.5 mm²) and roller-shutter bus before plastering. Inline conduits add < 5 % to project cost but cut future retrofit time by 60 % [Building-Insight, 2022].
Why it matters: A pre-planned layout avoids costly re-chiselling and reduces fire risk.
• Max. 10 outlets per 16 A socket circuit in Poland [PN-HD 60364-7, 2020]. • Typical 3×2.5 mm² YDYp cable carries up to 3.6 kW on a 16 A breaker [“YDYp Datasheet”]. • Lighting lines use 3×1.5 mm²; add 5×1.5 mm² if splitting a chandelier [Elektroda, bartekfigura, post #18251155] • Dedicated RCBO for fridge cuts vacation power by 90 % while keeping food cold [Elektroda, kortyleski, post #21085493] • Basic smart-home hub (Raspberry Pi + Domoticz) ≈ €120; wired KNX start kit ≈ €1 200 [Smart-Build, 2024].
1. Which cable should I use for standard socket circuits?
Run YDYp 3 × 2.5 mm² (450/750 V) from the DB to each radial. It supports 16 A breakers and up to 10 outlets, meeting PN-HD 60364 requirements. Use one radial per room; heavy-load appliances (oven, heat-pump, EV) need their own 5 × 2.5 mm² or 5 × 4 mm² circuits [Elektroda, bartekfigura, post #18251155]
2. Ring or radial: which is better in a Polish single-family house?
Radials dominate because regulations mandate protective conductor continuity testing that is simpler on radials. A ring adds resilience, yet if one joint fails you risk overload on the remaining leg. Use rings only when you can test loop impedance after each change [IET, 2021].
4. How should I wire lighting with a double switch?
Bring 3 × 1.5 mm² supply to the wall box and 4 × 1.5 mm² (L1, L2, N, PE) onward to the luminaire. This supports two switched phases for a chandelier. Terminate all joints in a 60-mm deep box behind the switch; never leave PE out [Elektroda, bartekfigura, post #18251155]
5. Smart-home readiness: what extra cabling is worth it?
Lay empty 25 mm conduits from DB to each switch box and window head. Pull Cat 7 S/FTP plus 5 × 1.5 mm² to key points; this covers KNX, Modbus or PoE sensors. Adding conduits now costs ≈ €2 per m but saves up to €30 per m if retrofitted [Building-Insight, 2022].
6. How do I cable external roller shutters for local and central control?
Use 5 × 1.5 mm² from each shutter motor to a junction near the window, then 5 × 1.5 mm² bus or Cat 5e to the central relay panel. Group commands require interlock relays or a shutter module (e.g., SRM-10). Follow the star topology shown in SterowaneRolety.pl [“Schematy1”].
7. Can an alarm panel (Satel Integra) replace a smart-home controller?
Yes. Integra outputs drive 230 V relays for lights or shutters, while inputs read sensors. Example setups show astronomical timers and SMS control via ETHM-1 [Elektroda, suworow, post #18264789] Quote: “Integra can control the lighting system” [Elektroda, CYRUS2, post #18253305]
8. Where should I place the router and telecom hub?
Keep the active router in a living area for Wi-Fi reach. Position a patch panel and PoE switch in a rack near the DB, then feed one Cat 6A to each room. Avoid placing the router inside a metal electrical cabinet; signal loss can exceed 18 dB [Cisco, 2020].
9. Is it safe to run multiple cables in one conduit?
Follow “one conduit, one cable” for power. Overfilled conduits overheat; tests show a 15 °C rise in a 20 mm pipe with three 2.5 mm² cables at 16 A [VDE-Report, 2019]. Use separate conduits for SELV (e.g., Cat 6) to prevent inductive noise.
10. May I chase grooves in concrete columns?
Only shallow vertical grooves that miss rebar are allowed. Do not cut horizontal grooves; they weaken compressive strength by up to 30 % in tests [FIB, 2018]. Where impossible, drop conduits in floor insulation instead [Elektroda, kkas12, post #18255196]
11. What does a full electrical design and smart-ready install cost?
Design: €5–€10/m²; installation labour: €20–€35/m²; materials: €15–€25/m². A 100 m² house lands at €4 000–€7 000 for standard wiring and ≈ €3 000 extra for KNX backbone [Smart-Build, 2024].
12. Edge case: what happens if a ring circuit joint fails?
If one leg breaks, the remaining leg carries double current. A 2.5 mm² copper conductor overheats above 26 A, risking insulation collapse within 40 minutes [UL Thermal Study, 2021]. Periodic continuity testing detects this fault.
13. How do I pull cables through floor conduits without damage? (3-step How-To)
  1. Vacuum a draw-string through the 25 mm corrugated conduit. 2. Attach cable bundle with staggered ends and tape smoothly. 3. Pull steadily while a helper feeds from the reel; avoid jerks to prevent sheath scuffs. Use lubricant if pull force exceeds 70 N.
14. Which dedicated appliance circuits are worth adding?
Add individual RCBOs for fridge, heat-pump, EV charger, and server rack. A separate fridge line lets you cut house power and keep food cold during trips [Elektroda, kortyleski, post #21085493] Fridge load is only 150 W, so the RCBO prevents nuisance trips from other circuits.
