[Solved] Audio Device Issue in CS: GO with Samson Go Mic: Microphone Not Recognized
gorad 22353 5
  • #1 18267682
    gorad
    Rate: 10
    Hi I have a small problem, because in my cs: go, when I go to the options and want to change the "Audio device", it is impossible and I emphasize that I have a Samson Go mic and it works everywhere but not in csgo, because instead of a microphone there is a speaker like this on the screen: Audio Device Issue in CS: GO with Samson Go Mic: Microphone Not Recognized
    Could someone help me please :)
  • #2 18267882
    Matesz 063
    Help: 13
    Rate: 25
    1. This is not a place where you choose input, only output.
    2. In CS: GO it is not possible to set the audio input as CS: GO uses the default.
    You enter the Control Panel / Devices and Sound / Sound / Recording and by right-clicking on the microphone you choose the option "Set as default"
    PS I have Windows in English so I'm not 100% sure if that's exactly what these options are, but the path is correct. If you did not find something, write it.
  • #3 18269620
    gorad
    Rate: 10
    Rather, it's not a problem with the microphone I tried, uninstalling cs it and installing it didn't help. I did what you told me.
    PS I don't hear others either
  • #4 18269817
    Matesz 063
    Help: 13
    Rate: 25
    But others hear you? Go into what I was saying and while speaking into the microphone, see which line is green and set this to the default one. In CS: GO, set up your speakers.
  • #5 18270533
    gorad
    Rate: 10
    Others can hear me, but I can't hear them. Done still doesn't work. Speakers set but still not working. Audio Device Issue in CS: GO with Samson Go Mic: Microphone Not Recognized
  • #6 18307237
    gorad
    Rate: 10
    the problem has not been resolved :(
