How to wirelessly control Fibaro switches without a control unit?
cyk_pct 1026 4
  • Need for a four-channel Fibaro transmitter module
    #1 18307080
    cyk_pct
    Rate: 19
    Hello, I have one question for my colleagues after Fibaro training or with experience. To begin with, I must write that I have an installation made on the principle of transmitters (powered 230) and receivers (powered 230) . There is no wiring between them. While in Extafree there were four-channel extension transmitters (such a module supported four single switches), in Fibaro I can't find any replacement. I will replace the receivers with switches, but how to switch them on wirelessly from a switch, bypassing the control panel?
  • Fibaro association can bypass the control panel
    #2 18307138
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    cyk_pct wrote:
    In place of the receivers I'm going to install switches, but how to switch them on wirelessly from a switch bypassing the control panel ?
    In Fibaro it is called association.
    It is possible that you don't need to switch them on wirelessly if your installation is such that a cable goes from each button directly to the distribution board and a cable from each receiver to the distribution board, then it is enough to install Fibaro modules in the distribution board and connect them accordingly.
  • #3 18307158
    cyk_pct
    Rate: 19
    Unfortunately, these are not separate circuits for each device (switch, receiver) from a single point or switchgear. It's a quick upgrade, i.e. power 230 is always taken from the nearest circuit. I think it's time to make a wired installation and only then to install Fibaro.
    Also, it doesn't necessarily have to be Fibaro, so that it just gets along with my google assistant :) .
  • #4 18311368
    cyk_pct
    Rate: 19
    One more quick question: Can the realy switch control the wall plug bypassing the control panel ? the so-called association :) Because I read and read these manuals and they do not write anything about this particular topic .
  • #5 18314461
    cyk_pct
    Rate: 19
    If so, has anyone come across any 868 Mhz receivers that are supported by ewelink or something similar that works with google home?
