[Solved] Which 230V relay for delayed shutdown on DIN rail?
rafal23s23 1008 6
  • #1 18324669
    rafal23s23
    Rate: 28
    Hello colleagues. I need a pulse-controlled 230V relay for delayed shutdown of a circuit ( delay time within 10-30 minutes) on a DIN rail that would have a convenient knob for adjustment that can be turned with fingers and not just a screwdriver. Perhaps some forum members have come across something like this?
  • #2 18324719
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Buddy, go to the f&f website and you will find plenty of programmable time relays.
  • #3 18325473
    rafal23s23
    Rate: 28
    Before I wrote the post here I checked the websites of the most popular manufacturers. I couldn't find any with an adjustment knob that I could turn with my fingers and not with a screwdriver and that's what I need
  • #4 18325501
    CYRUS2
    Help: 1241
    Rate: 3536
    rafal23s23 wrote:
    Before I wrote the post here I checked the websites of the most popular manufacturers. I could not find any with an adjustment knob that I could turn with my fingers and not with a screwdriver and that is the need I have
    Paste the plastics into the potentiometers.
  • #7 18327666
    rafal23s23
    Rate: 28
    And this is exactly what I had in mind. Thank you, Greetings and Closing
A user seeks a pulse-controlled 230V relay for delayed shutdown on a DIN rail, specifically one with a finger-adjustable knob for setting delay times between 10-30 minutes. Initial suggestions included checking the f&f website for programmable time relays, but the user noted the lack of suitable options with the desired knob feature. Helpful responses included recommendations for the Alstom RTx and Omron H3CR models, which align with the user's requirements.
