What time relay for the fan - 30s delay?
corsarz19 1110 2
  • #1 18495812
    corsarz19
    I would like to add a time relay to a bathroom fan which, when the power is switched on, will switch on the fan but only after 30s and switch off immediately ( there may also be a time delay ) the fan when the power is switched off ( in this case the bathroom lighting). I don't know much about this and there are loads of relays on the market.
    Please help.
    Greetings
    elkard
    Level 36  
    Help: 397
    Rate: 253
    You need a time relay with a delayed switching function.
    E.g: PCR-513 230V F&F
  • #3 18496114
    corsarz19
    So there are no relays that have two simultaneous functions of switch-on delay and switch-off delay?
