[Solved] Kingston DT100 G3 32GB Flash Drive - Firmware Repair & Phison Tool Troubleshooting
sylweksylwina 52467 7
  • #1 18338304
    sylweksylwina
    Help: 1882
    Rate: 2355
    Hello, I have a Kingston DT100 G3 32GB. The pendrive is almost new, but the write speed was terrible, so I figured that maybe it would format the memory on a low level, I ran the pendrive repair tool (phison format & restore) and the pendrive died :D
    There is no data for recovery, the pen value is negligible. But I would like to know if a repair is possible anyway. I tried various versions of Phison MPALL to no avail, usually after setting everything up there was an error uploading the firmware etc. I simply bet that without the appropriate firmware, which is rather not available, I will not do anything ...
    Before the surgery, it looked like this:
    Description: [I:]Urządzenie pamięci masowej USB(Kingston DataTraveler 3.0)
    Device Type:  Mass Storage Device
    Protocal Version: USB 3.10
    Current Speed: High Speed
    Max Current: 504mA
    USB Device ID: VID = 0951 PID = 1666
    Serial Number: 08606E6B6580E310D72B4ED7
    Device Vendor: Kingston
    Device Name: DataTraveler 3.0
    Device Revision: 0110
    Manufacturer: Kingston
    Product Model: DataTraveler 3.0
    Product Revision: PMAP
    Controller Vendor: Phison
    Controller Part-Number: PS2251-07(PS2307) - F/W 08.03.50 [2018-05-11]
    Flash ID code: AD3A18030050 - Hynix [TLC]
    Tools on web: http://dl.mydigit.net/special/up/phison.html
    Po - pen visible only in USB 2.0, there is an unidentified device in 3.0:
    [code:1:0b1a51cc81]
    Description: [G:]Urządzenie pamięci masowej USB(13FE USB DISK 50X)
    Protocal Version: USB 2.10
  • #3 18344221
    sylweksylwina
    Help: 1882
    Rate: 2355
    From the link Restore does not detect full, UPTool crashes "Flash Fail 1" ID_BLK Ver. same zeros. RMA is missing, no proof of purchase.
    pidar
    Help: 1569
    Rate: 3590
    Testmod now to be done:
    "For PS2251-07 controller:
    if 48PIN: 25-28PINS, sample 26 + 27
    if 64PIN: 34-37PINS, sample 35 + 36 "
    How to disassemble this flash drive, see the video:
    https://youtube.com/watch?v=-ZzZsMfhmmo
  • #5 18344271
    sylweksylwina
    Help: 1882
    Rate: 2355
    Pen entered 2307 PRAM mode
    In another version, MPALL can see what flash is, but whether in normal mode or PRAM it does not upload the firmware Kingston DT100 G3 32GB Flash Drive - Firmware Repair & Phison Tool Troubleshooting
  • USB 3.0 testmode and scan class 0x1080 crash
    #7 18346084
    sylweksylwina
    Help: 1882
    Rate: 2355
    In testmode, basically nothing happens after clicking start:
    in normal mode it shows like this, and after pressing start error 0x1049:
    EDIT, I changed a few parameters in the config, now it hangs on IB check, I'll wait, we'll see what comes out of it.
    Added after 3 [hours] 4 [minutes]:
    So yes, I connected in testmode to USB 3.0, changed the configuration to 3.0 accordingly and did an autodetect when choosing pendrive IDs. It had ground and threw it out:
    Now there is no message that the USB device is not recognized after connecting to port 3.0, only the pendrive immediately goes into testmode. I noticed that when you select Scan class HLF instead of L + H, it immediately crashes 0x1080
  • #8 18349419
    sylweksylwina
    Help: 1882
    Rate: 2355
    During the memory scan process, it finds a huge amount of bad blocks. The pendrive cannot be repaired.
The discussion revolves around troubleshooting a Kingston DT100 G3 32GB flash drive that experienced significant write speed issues and ultimately failed after using a Phison repair tool. The user attempted various firmware recovery methods, including Phison MPALL, but encountered errors and was unable to restore functionality. Suggestions included checking the device's ID_BLK version, using RMA services, and exploring alternative tools like ST-TOOL for potential recovery. However, subsequent attempts revealed numerous bad blocks during memory scans, indicating that the drive may be irreparable.
