Living Near 220kV High-voltage Power Line: Health Risks & Electromagnetic Fields (40V/m Threshold)
15252 11
Is living about 60 m from a 220 kV power line, with an EMF meter showing 60 V/m and a 40 V/m alarm threshold, harmful to health?
No clear evidence in the thread shows that living near a high-voltage line or seeing a 40 V/m reading is harmful to health. One reply says that despite many efforts, no one has proven a negative health impact from such lines, including for people working only a few meters from high-voltage wires [#18397744] Another reply says this is a “panic meter” issue: a 40 V/m alarm threshold is too low for 50 Hz fields, and for higher frequencies it can already be above the norm; the cited Polish standard is 1000 V/m [#18398347]
  • #1 18397508
  • #2 18397744
    retrofood
    Help: 1140
    Rate: 4798
    Monnnn wrote:
    There are also other houses that are built much closer to the line but I am concerned about how electromagnetic lines can affect our health.
    Despite many efforts, no one has yet managed to prove that there is any negative impact on our health. Which, moreover, does not prevent various haunted individuals from honking left and right about the harmfulness of what they live on and what they subsist on. They have already made money on you, because you bought the equipment from them.
    And lest I don't know myself, I will explain that for several years I worked in a high voltage station, where the distance between the employee and the wires is only a few meters, so I wanted to apply for a salary allowance due to such harmfulness. Unfortunately, no serious research has shown such an impact, and the employer declined it for lack of grounds.
  • #3 18397833
    kosmos99
    Help: 338
    Rate: 820
    Can you imagine what would happen if this type of harmfulness was confirmed?
    After all, the WN lines must pass somewhere.
    A plot of land in such a neighborhood is definitely cheaper.
  • #4 18398122
    retrofood
    Help: 1140
    Rate: 4798
    I imagine, because many have tried to prove research has been conducted in many countries.
    Sure, but not because of the harmfulness of the lines, only a nasty view from the window.
  • #5 18398202
    kosmos99
    Help: 338
    Rate: 820
    Because this research cannot be different in any country.
    Suppose they turn out to be harmful, and then what?
    Liquidation, paying compensation? After all, it is impossible, so the results cannot come out otherwise.
    retrofood wrote:
    Sure, but not because of the harmfulness of the lines, but a nasty view from the window.
    What about a failure? The fact that this is rare, but it is possible.
  • #6 18398278
    retrofood
    Help: 1140
    Rate: 4798
    kosmos99 wrote:
    What about a failure? The fact that this is rarely the case, but it is possible.
    What is there to be? It is removed and that's it.
    Don't write fairy tales because they get boring.
  • #7 18398347
  • #8 18399634
    750kV
    Help: 240
    Rate: 713
    Well, unless a passionate profession - an energy specialist will buy. Then the view (for him) was quite pleasant. :-)
    As for the presence of the HV line in the vicinity, additional lightning protection is provided.
  • #9 18399889
    fajrant06
    Help: 9
    Rate: 33
    Hello to all forum members.
    It's good that such a topic arose. Everywhere you look, whether it is on the Internet or on TV, it scares you that it is harmful, that it is harmful. Who thinks logically will ask an important question: I am asking for evidence that something is harmful.
    I am not one of those people who believe unfoundedly in what I have heard or seen on TV. When I hear or see something, I do not believe it, but I try to carry out my own research if possible to confirm whether it is true or simply intimidation to say so. People, since they started building high-voltage lines, live under them, walk under them, work under them. This cannot be avoided. I have never heard of ANY case of anyone getting sick because of their deterioration. Even more: no studies have confirmed that the high-voltage line is harmful. Let's think logically. If that were the case, what would happen to those people who live or work underneath them. They would probably fall sick or, in the worst case, die. And is it so? Was there even ONE such case? Well, NO. Nothing of the kind has been documented or proven. We live on a planet where there is a network of transmitters of various types, a network of transmission lines etc. etc. Has anyone been hurt? Absolutely not. They scare us in the same way that smoking is harmful. I hear it a lot from people. Then I ask them an important question: Show me the evidence of it. Not heard but own evidence.
    What kind of answer do I get then? No response. I've known people who are already dead. They died of cancer. Interestingly, none of these people have ever smoked. I know people who smoke and that's not enough. They are still alive without any harm to their health. Nay. They have better health than those who don't smoke. So smoking is harmful or not? Those who believe ONLY IN A WORD and have not carried out their own research will say: Yes, it does.
    And I say: It doesn't matter.
    Those who have carried out their own research, not only in their own environment, must have found the Innemedium website or just enter "Smoking kills with laughter" in the search engine. There is a good topic there, of course, for logical people who do not have a closed mind.
    So the question arises: Why are we being scared so much that something is harmful? What is the purpose of this? Especially that research not only by scientists suggests something completely different.
    So, answering the question: The high-voltage lines do not harm in any way.
    Only one thing hurts: The chemicals you add to your food. This is where various diseases come from, including cancer.
  • #10 18399930
    750kV
    Help: 240
    Rate: 713
    fajrant06 wrote:
    ... They scare us in the same way that smoking is harmful. I hear it a lot from people. Then I ask them an important question: Show me the evidence of it.
    With this cancer, you are right. The claim that smoking kills is also greatly exaggerated. However, as a practitioner (36 years of smoking on average 2 packs / 24h), I find that cigarette tar causes respiratory failure. It is impossible to run 100 meters.
    The truest truth! Sweeteners are especially effective in destroying the liver.
    As for the WN and NN lines, you are 100% right. I am writing this as an electric power engineer.
  • #11 18400002
    fajrant06
    Help: 9
    Rate: 33
    But there is an important question to ask again:
    Is the fact that we cannot run these 100 meters is the result of the fact that we smoke or is it our body's fault, which is known to age over time and we already do some things worse, e.g. running these 100 meters is already causing problems. I smoke for about the same number of years as you and think to yourself that I don't have any health problems. I will say more: I ride a bicycle to work. I have 11 km one way. And I'm not even getting tired. So if the tar was harmful, I probably wouldn't have traveled even 1km. And it turns out that tar does not hurt (especially since we smoke cigarettes with a filter), but our body is aging and not taking care of the condition properly, over time there will be problems with running even 10m. Once, I had lung tests, heart tests, etc. Every doctor looked incredulous that I was okay at all and that my health is like an 18-year-old boy. Everything clean and healthy. Especially since I tell the doctor that I smoke. They were even more surprised because, according to their knowledge, I should already be sick with something or be a wreck of a man of that age. And here they found nothing.
    And the tar in your lungs? It is enough to think in what environment we live in and what we breathe. Exhaust gases at every step, etc.
  • #12 18401348
    Janusz_kk
    Help: 228
    Rate: 1478
    Why not? for x-ray or similar bands they come out and it is known that they are harmful.
    In order for a given radiation to be harmful, it must transfer the appropriate energy, it is best seen in a microwave oven
    which are at 2.4Ghz and not 50hz :)
    This is only a matter of cigarettes and this is what the ex-smoker who was also in no condition said,
    And now I have it, but I have not been smoking for over 30 years and I go for walks, it all adds up a lot.
The discussion revolves around concerns regarding health risks associated with living near a 220kV high-voltage power line, specifically focusing on electromagnetic fields (EMF) and their potential effects on health. The original poster measured EMF levels of 60V/m at 2m above ground and 5V/m at 1m, exceeding the 40V/m threshold. Responses indicate skepticism about the harmfulness of such EMF levels, citing a lack of conclusive scientific evidence linking high-voltage lines to health issues. Participants reference various studies and personal experiences, arguing that if high-voltage lines were indeed harmful, widespread health problems would be evident among those living and working near them. The conversation also touches on the economic implications of living near such infrastructure, suggesting that property values may be lower in these areas.
TL;DR: Public 50 Hz electric-field limit is approx. 1,000 V/m; "The alarm threshold of 40 V/m is definitely too low (for 50 Hz)." A 40 V/m alert alone doesn’t indicate a health risk near 220 kV lines. [Elektroda, Adamcyn, post #18398347]
Why it matters: Homeowners near 110–400 kV lines can interpret EMF meter alerts and plan protections without confusion or panic.
Is 40 V/m from a 50 Hz power line harmful?
No. For 50 Hz, 40 V/m is far below commonly referenced limits. A forum engineer notes, "The alarm threshold of 40 V/m is definitely too low (for 50 Hz)." Such alerts indicate instrument settings, not a health exceedance. [Elektroda, Adamcyn, post #18398347]
What are the official safe exposure limits for 50 Hz fields?
ICNIRP’s public reference levels are 5 kV/m for electric fields and 200 µT for magnetic fields at 50 Hz. These reference levels include substantial safety margins. Use them to contextualize any consumer meter reading near transmission lines. [ICNIRP, 2010]
Why does my EMF meter beep at 40 V/m under a 220 kV line?
Many consumer meters ship with a fixed 40 V/m alert suited to higher frequencies. At 50 Hz, that threshold is not a health limit. Per the forum expert, the 40 V/m alarm is simply too low for 50 Hz contexts. [Elektroda, Adamcyn, post #18398347]
I live ~60 m from a 220 kV line—does that distance meet planning norms?
In the thread, the homeowner received a building permit without issues, and other houses stand even closer. That demonstrates the distance can comply with local siting and permitting requirements. Always confirm specifics with your local authority. [Elektroda, Anonymous, post #18397508]
Do high‑voltage lines cause proven health effects?
A veteran substation worker summarizes the evidence gap: "no one has yet managed to prove that there is any negative impact on our health." Available experience in the thread aligns with this assessment. [Elektroda, retrofood, post #18397744]
Could a power‑line failure endanger my house?
Failures are rare but possible, as participants note. Utilities address them when they occur. Keep rights‑of‑way clear and observe utility guidance to minimize risk around structures and vegetation. [Elektroda, kosmos99, post #18398202]
Does living near a line affect property value more than health?
One contributor notes lower plot prices mainly from aesthetics: the "nasty view from the window," not proven health harm. Market perception often drives valuation near visible infrastructure. [Elektroda, retrofood, post #18398122]
Should I add lightning protection if I live near HV lines?
An energy specialist reports that additional lightning protection is provided when HV lines run nearby. Discuss surge protection and bonding with a qualified electrician to align with local practice. [Elektroda, 750kV, post #18399634]
Why did my reading jump from ~5 V/m at 1 m to ~60 V/m at 2 m?
Your measurements show height matters under lines. You noted ~5 V/m at 1 m and ~60 V/m at 2 m. Take readings at consistent heights and locations to compare trends over time. [Elektroda, Anonymous, post #18397508]
How do 50 Hz fields compare with microwave or Wi‑Fi energy?
They behave differently. "In order for a given radiation to be harmful, it must transfer the appropriate energy," explains one user. Microwaves (e.g., 2.4 GHz) heat effectively; 50 Hz fields don’t couple energy the same way. [Elektroda, Janusz_kk, post #18401348]
Do utility workers get hazard pay for EMF exposure?
A former substation worker sought an allowance but the employer declined, citing no evidentiary basis. He adds that no serious research had shown such an impact for their work context. [Elektroda, retrofood, post #18397744]
Which EMF meter features help assess 50 Hz fields near power lines?
Pick a meter designed for ELF/50 Hz electric fields with a range extending into kV/m. Avoid "panic meters" that alarm at 40 V/m, as that threshold isn’t a 50 Hz health limit. Brands that specify 50 Hz modes can help. [Elektroda, Adamcyn, post #18398347]
