Saeco Aulika Black Office coffee machine - error e07 after making a few coffees
Przemekt27 59487 4
  • #1 18432786
    Przemekt27
    Rate: 11
    I have a Saeco Aulika Black Office coffee machine; after making a few coffees, error code e07 appears.
    After switching the machine on and off, the fault sometimes goes away, and sometimes I have to wait a while before it works properly again.
    What could be the cause?
  • #3 18492658
    digit7
    Rate: 58
    I also have error E 07, after turning it off and waiting an hour, the same thing happens. What to do? How to remove this "dispenser switch blocked"?
  • #4 18493364
    sorier
    Level 30  
    Help: 166
    Rate: 635
    The easiest way to check this microswitch. You remove the upper casing of the coffee machine and the grinder wheel, more or less under the dispenser coil there is this microswitch.
  • #5 21896251
    kzmg
    Hello, I also have a problem with the e07 error, I have checked the microswitch under the coil, it is working, the cables are ok and the error notoriously occurs. What could be the cause?
