Patriot BURST 240GB, SATAFIRM S11 Data Recovery: Phison S11 Repair & Flash ID Info
saass999 16002 12
Can I recover data from a Patriot Burst 240GB SSD stuck in SATAFIRM S11 by flashing or repairing the Phison S11 firmware myself?
Do not keep flashing the Patriot Burst/Phison S11 yourself, because these tools can reinitialize the NAND and may partially or completely destroy the data even if they end with an error [#18507656][#18508309] The SATAFIRM S11 state and the reported 113 GB are not reliable signs of recoverable logical data; these utilities can show misleading values during the process [#18508309] Proper recovery requires reloading the controller microcode and rebuilding the translator, ideally with a PC-3000 SSD/Phison utility or a specialist company that knows this controller [#18507665][#18507714][#18508309] If you already started the upgrade/ISP procedure, you may have already lost the contents or most of it [#18507656][#18508350] The likely cause of the failure is NAND wear/weak memory plus manufacturing limits and defects, where ECC is no longer enough [#18510002]
  • #1 18507645
    saass999
    Hello everyone
    I have a big problem with the disk as in the topic. I tried various tools, e.g .: Phison S11 repair From this side:
    http://vlo.name:3000/ssdtool/
    tool Phison flash id reads from disk this:
    Model: SATAFIRM S11
    Fw: SBFM21W1
    P / N: 511-170717128, SBSM21.0
    S11fw: SBFM21.1, 2017 Jun14
    Original Model: Patriot Burst
    Bank00: 0x2c, 0xc4,0xe5,0x32,0xaa, 0x4,0x0,0x0 - Micron 32L (L06B) MLC 512Gb / CE 256Gb / die
    Bank02: 0x2c, 0xc4,0xe5,0x32,0xaa, 0x4,0x0,0x0 - Micron 32L (L06B) MLC 512Gb / CE 256Gb / die
    Bank08: 0x2c, 0xc4,0xe5,0x32,0xaa, 0x4,0x0,0x0 - Micron 32L (L06B) MLC 512Gb / CE 256Gb / die
    Bank10: 0x2c, 0xc4,0xe5,0x32,0xaa, 0x4,0x0,0x0 - Micron 32L (L06B) MLC 512Gb / CE 256Gb / die
    Controller: PS3111
    Flash CE: 4
    Flash Channel: 2
    Dram Size, MB: 32
    Flash CE Mask: [+ - + ----- + - + -----]
    Flash Mode / Clk: 5/7 (Set 5/7)
    Block per Die: 2192
    Block per CE: 4384
    Page per Block: 1024
    SLC Cache: Default
    MaxBBPerPlane: 70
    ONFI [A7]: MICRON MT29F2T08CUCBBM4 [12E9]
    Page size: 18592 (16384 + 2208)
    Page / Block: 1024
    Plane: 2
    Defects All (per plane) Early Later
    Bank00: 28 (9.13) 28 (9.13) 0 (0.0)
    Bank02: 20 (5.5) 20 (5.5) 0 (0.0)
    Bank 08: 27 (9.6) 27 (9.6) 0 (0.0)
    Bank10: 19 (7.5) 19 (7.5) 0 (0.0)
    Total: 213 213 0
    Early defect list
    Bank00: 96 97 98 99 100 101 102 103 104 105 106 107 108 109 352 353 354 355 609 611 1931 2000 4192 4193 4194 4195 4196 4197 4198 4200 4201 4202 4204 4205 4448 4449 4452 4453 4493 4704 4705 4708 4709 4993 5001 5217 5615 5729 6027 6096
    Bank02: 96 97 98 99 100 101 102 103 104 105 106 107 108 109 352 353 355 356 357 608 609 612 896 897 900 904 1120 1128 1376 1636 1931 2000 4192 4193 4194 4195 4196 4197 4198 4199 4200 4201 4202 4203 4204 4205 4449 4451 4707 5234 6027 6096
    Bank08: 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 352 353 354 356 358 608 612 896 1638 1931 2000 4192 4193 4194 4195 4196 4197 4198 4199 4200 4201 4202 4203 4204 4205 4207 4227 4448 4449 4450 4451 4452 4705 4706 4708 4996 6027 6096
    Bank10: 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 352 353 354 355 356 357 358 608 609 611 612 613 614 757 896 901 904 909 1021 1637 1931 2000 4192 4193 4194 4195 4196 4197 4198 4200 4201 4202 4203 4204 4205 4448 4449 4452 4475 6027 6096
    Later defect list
    Attr Tresh Flags ValId WrstId RawId Description
    I tried reading that the chances of getting to the data are flashing the firmware, I tried, for example, various toolboxes are phison - unfortunately or I get info that it is not MLC solution or e.g. upgrader FW SBFM21_1 (ea11) throws a prompt:
    After ISP Jump, Set AP-Key Failed !!
    Interestingly, some toolboxes show the whole green circle 240GB in the status and some show some 113GB in red, which is as if they saw the data there.
    will anyone give me a hint?
    thanks in advance
  • #2 18507656
    Łukasz_W
    HDD and data recovery specialist
    Help: 633
    Rate: 658
    Where did you read this information?
    Uploading the software involves reinitializing the memory chip and resetting the content.
    If the procedure has been initialized (despite throwing an error), the data is already over.
    HEX SERWIS
    Smołdzinska 2B/16, Kobysewo, 83-304 | Tel.: 530XXXXXX (Show) | Company Website: https://hex-serwis.pl
  • #3 18507661
    saass999
    @ Łukasz_W what I can try to do - thanks for your interest
  • #4 18507665
    Łukasz_W
    Help: 633
    Rate: 658
    Thread.
    You need to contact the company that has a solution for this controller and knows what to do in order not to permanently lose the content, as above.
    You need to load the replacement software and rebuild the translator. Successful recovery depends on the condition of your memory.
    HEX SERWIS
  • #5 18507686
    saass999
    and this replacement software is more precisely?
  • #7 18507714
    kaleron
    Help: 963
    Rate: 2344
    You need to recharge the microcode that allows you to read the part of the firmware that is in the NANDs and contains information unique for a given carrier, such as translation tables, defect lists, on the basis of which LBA addresses can be assigned to specific physical addresses. This controller uses dynamic randomization, so desoldering the circuits and retrieving data from the read binary using mathematical methods supported by the analysis of logical structure elements is not an option. In short - if you plan to force the medium to work, forget about the data. Someone who advised you to flash the firmware has no idea about data recovery, and the message you posted justifies the fear that you might have managed to destroy the content, because you obviously had communication with NANDs.
    Kaleron sp. z o. o.
    Hirszfelda 4/18, Jelcz-Laskowice, 55-231 | Tel.: 713XXXXXX (Show) | Company Website: https://kaleron.pl
  • #8 18508246
    saass999
    @ Lukasz_W
    I started flash but whether it was an upgrader or from the toolbox, I always had a negative message - the disk state does not change in any way (I think) .. in the sense that all the time SATAFIRM S11 and all the time FW read then via Phison flash id is the same, i.e. SBFM21W1, and some versions of the toolbox in the% capacity ball still see 113GB as if data / occupancy .. I have the impression that all these operations simply did not contribute anything because it seems or they did not come to an end correctly with upgrades (5%) and errors .. and toolboxes and messages that it will not perform the operation and that's it ..
    @kaleron
    Is what you wrote when it comes to performing microcode recharge that allows you to read this part of the firmware located in NANDs only through (as my colleague @ Łukasz_W suggests) - PC-3000 and this equipment?
    thanks again for your interest
  • #9 18508309
    kaleron
    Help: 963
    Rate: 2344
    The fact that the entire process has failed does not mean that erasing the memory contents could not have succeeded even partially. The message issued by the carrier indicates that access to NANDs has been cut off, which does not mean that low-level programs that receive this access, according to the message you posted, could not perform any operations. And these are operations that are irreversibly destructive to data. And these programs do not analyze the content in terms of logical structures at all, so do not interpret a message with a visible 113 GB as information about used space in terms of logical structures. Programs of this type often show nonsense during operation and only at the end restore access to the full LBA addressing. If you've done 5% of the operation, that's enough to make you tremble for your data.
    Yes - the easiest way to recharge this microcode is to use a PC-3000 with a software extension for SSD. This is not the only way, but the ATA commands you would have to use when doing it manually are not documented. It is really bad that you tried to fix this media by flashing. Unfortunately, there is no shortage of such irresponsible advice, and it is difficult to obtain reliable knowledge.
    Kaleron sp. z o. o.
  • #10 18508350
    Łukasz_W
    Help: 633
    Rate: 658
    As your colleague Kaleron says, you can probably say goodbye to the contents of the disk or most of it.
    HEX SERWIS
  • #11 18509666
    saass999
    hmm .. well ..
    the topic seems to be closed ..
    Added after 39 [minutes]:
    and the fundamental question about the cause - what is the cause of the "run-up" of the FW?
  • #12 18510002
    kaleron
    Help: 963
    Rate: 2344
    Weak memories, smaller and smaller transistors, packing more and more bits into the transistor = the need to distinguish more and more charge levels, manufacturing defects - all this translates into an increasing number of bot errors. There comes a moment when the ECC codes are not enough, something crashes and the problem is ready.
    Kaleron sp. z o. o.
  • #13 18510269
    saass999
    thanks again
The discussion revolves around data recovery issues with a Patriot BURST 240GB SSD, identified as a SATAFIRM S11 model. The user attempted various recovery tools, including Phison S11 repair, but faced challenges with firmware updates and data access. Responses suggest contacting specialized companies for controller solutions and using specific software to rebuild the translator for data recovery. Concerns were raised about the risks of data loss due to failed operations and the potential for irreversible damage to the memory contents. The conversation also touched on the causes of firmware failures, attributing them to manufacturing defects and the limitations of error correction codes in modern memory technologies.
TL;DR: On Phison PS3111‑S11 drives showing "SATAFIRM S11", DIY flashing risks data loss—"If you've done 5% of the operation, that's enough to make you tremble for your data." Use PC‑3000 to load replacement microcode and rebuild the translator. [Elektroda, kaleron, post #18508309]
Why it matters: This helps owners of Patriot Burst/Phison S11 SSDs stuck in SATAFIRM S11 recover data safely instead of wiping drives.
What does “SATAFIRM S11” actually mean on my Patriot Burst?
It is a minimal service mode. The controller failed to load its microcode from NAND. The translator and defect tables are inaccessible, so LBA mapping breaks. Recovery requires injecting temporary microcode, reading service modules in NAND, and rebuilding the translator. [Elektroda, kaleron, post #18507714]
Is flashing firmware with Phison tools a safe way to recover data?
No. Uploading firmware on Phison S11 reinitializes NAND and resets the content. If the procedure starts, your data is at risk. Treat any flasher as destructive and avoid it for recovery. Use read‑only workflows instead. [Elektroda, Łukasz_W, post #18507656]
My tool shows 113 GB in red—is that my data?
No. These utilities don’t analyze file systems and can display nonsense during service‑mode work. Partial capacity indicators don’t represent real user data. Only a proper translator rebuild restores valid LBA access. “Programs of this type often show nonsense during operation.” [Elektroda, kaleron, post #18508309]
What does “After ISP Jump, Set AP‑Key Failed !!” indicate?
The tool entered ISP mode but failed to set the authentication key. It still indicates communication with NAND. Even if the overall process fails later, partial erase or program operations may already have occurred. Stop further attempts. [Elektroda, kaleron, post #18508309]
How do professionals recover data from a PS3111‑S11 in SATAFIRM S11?
Use PC‑3000 SSD with the Phison utility. 1. Identify controller and NAND. 2. Load replacement software (microcode) into RAM. 3. Read firmware modules, rebuild the translator, then image. “You need to load the replacement software and rebuild the translator.” Success depends on NAND condition. [Elektroda, Łukasz_W, post #18507665]
What is the translator and why does it matter?
The translator maps LBAs to physical pages using defect lists and metadata stored in NAND. If microcode can’t load or tables corrupt, the map is lost and the SSD shows SATAFIRM S11. Rebuilding restores readable sector mapping. [Elektroda, kaleron, post #18507714]
Can I desolder the NAND and recover data from raw dumps?
No. This controller uses dynamic randomization. Raw dumps lack consistent patterns for mathematical reconstruction. You need controller‑assisted access to de‑randomize and read metadata and tables correctly. [Elektroda, kaleron, post #18507714]
I only ran 5% of a firmware update—am I safe?
Not safe. Even minimal progress can trigger destructive operations. “If you’ve done 5% of the operation, that’s enough to make you tremble for your data.” Seek a controlled readout, not more flashing. [Elektroda, kaleron, post #18508309]
Why did the firmware “run up” or fail on this drive?
Weak NAND, smaller transistors, and more bits per cell increase errors. Eventually ECC becomes insufficient and the controller crashes into failure. That failure manifests as SATAFIRM S11. [Elektroda, kaleron, post #18510002]
What hardware details should I expect on a Patriot Burst 240GB (SBFM21W1)?
Reported: PS3111 controller, Micron 32‑layer MLC, two channels, four CEs, and 32 MB DRAM. Page size is 18,592 bytes (16,384 + 2,208). Typical die capacity is 512 Gb with two planes and about 2,192 blocks per die. These parameters guide translator rebuild. [Elektroda, saass999, post #18507645]
Are the necessary ATA vendor commands documented for DIY recovery?
No. The commands to load microcode and access service modules aren’t documented. The practical route is using a lab tool that implements those commands, such as PC‑3000. [Elektroda, kaleron, post #18508309]
What should I do right now to protect my files?
Contact a data‑recovery company that has a Phison S11 solution. They will load replacement software and rebuild the translator without reinitializing the NAND. Recovery chances depend on the memory’s health. [Elektroda, Łukasz_W, post #18507665]
