Krups EA8908 - message "Disconnect and reconnect or use application"
russell_terrier 98880 31
Why does my Krups EA8908 immediately show 'Disconnect and reconnect or use the app' after startup, and how can I fix it?
The error is usually caused by a fault in the boiler temperature-sensing/heating circuit, most often a damaged NTC/thermistor on the boiler or its wiring, and sometimes blown thermal fuses near the sensor. [#19944958] [#20541427] [#21149539] Some users fixed it by repairing a broken sensor tip, soldering/replacing the sensor lead, or installing a new NTC sensor element. [#19944958] [#20664122] [#21309735] If the machine starts "Automatic maintenance" and then fails after water is pumped, check the flow meter, its harness, and the board module in that order; a clogged internal water filter on the flow meter can also cause the fault. [#19360935] [#20162646] [#20163255] In scaled-up machines, cleaning the water system with a ready-made coffee-machine descaler helped some owners, but other cases still needed service repair. [#19689608]
  • Repeated reconnect prompt after power cycle
    #1 19238014
    russell_terrier
    Rate: 34
    Today, between making one coffee and the next, the message "Unplug and plug back in, or use the app" appeared on the display. It was impossible to turn it off or switch the machine off. After unplugging the machine from the socket, plugging it back in and switching it on, you can set the date and time. Then the message "Preheating" appears (even though I haven’t selected any coffee to make), and after 1–2 seconds, "Unplug and plug back in or use the app" appears again. Both messages are accompanied by sounds (as if something is switching). Has anyone else had the same problem?
  • #2 19292728
    PioWal1234
    Rate: 134
    I have but it happened to me today :( Do you know what was the reason and how to solve it???
  • #3 19292831
    russell_terrier
    Rate: 34
    I had a boiler to replace. However, this message can mean many different faults.
  • #5 19360833
    irowr
    Rate: 205
    Hello, I join the topic, yesterday ok today problem and it shows "Automatic maintenance" two cycles at the end of "Unplug and reconnect Or use app". The espresso machine is over 2 years old. Is there anything I can do on my own or is it a service? Thank you.
  • #6 19360841
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    Two cycles of what...? Filling the circuit with a nozzle, or two cycles of boiler operation, i.e. the descent of the pressing piston down?
    Kawa i Naprawa - Serwis AGD
  • #7 19360878
    irowr
    Rate: 205
    After switching on the coffee machine, "Automatic maintenance" is activated immediately, you can hear something starting and then it is filled with water, "Set the 600 ml vessel under the nozzles", OK, Filling the machine, Then again the same thing and the message "Disconnect and reconnect or use the app.
  • Flowmeter hall sensor as likely fault source
    #8 19360935
    nioop
    Help: 503
    Rate: 3337
    No water flow reading.
    For verification - flowmeter, flowmeter harness, board module - in that order.
    The flow meter is just a standard hall sensor.
  • #9 19361489
    irowr
    Rate: 205
    Thank you for your help.
  • #10 19688311
    djslowsilver
    Rate: 9
    Hello, I have the same problem, unfortunately replacing the flow meter with the harness for a new original one did not give anything
  • #11 19689608
    irowr
    Rate: 205
    In my case, the espresso machine landed in the service, the calcified water system was cleaned and it helped. For cleaning, use ready-made descaling liquids for coffee machines, not powders and tablets.
  • Question about manual descaling procedure
    #12 19799734
    Banditos
    Help: 6
    Rate: 26
    I have the same problem - Automatic Maintenance turns on, a 600ml vessel under the nozzles, OK, some water will flow and this error pops up. Once it helped to disconnect the equipment from the socket for a few days.
    Have any of you tried to do "cleaning the calcified water system" on your own?
    Earlier there was a problem with the grinder replaced by the factory service in Wrocław for a fee - allegedly flooded. Overall, I think this model is very poor quality.
  • #13 19799756
    sorier
    Level 30  
    Help: 166
    Rate: 634
    Unscrew the front and top panels and look inside to see what the brewing unit looks like. Maybe the culprit is not scale, but coffee or coffee grounds have blocked the plunger.
  • Holding the settings button triggered maintenance cycle
    #14 19910520
    bczajkowski1990
    I immediately after turning on the coffee machine, as soon as any information appeared, probably automatic maintenance and the settings button lit up, I held it down and held it until the coffee machine turned on. There was a process of maintenance, rinsing on the way and it worked. At the moment, I'm doing cleaning because I've had such a message for two weeks, but he left the cleaning process to return after vacation
  • Broken boiler temperature sensor tip fixed with conductive glue
    #15 19944958
    benek194
    Rate: 16
    russell_terrier wrote:
    Today, between making one coffee and another, the message "Unplug and reconnect or use the app" appeared on the display. Couldn't turn it off or turn it off. After disconnecting the plug from the socket and reconnecting and switching on the coffee machine, you can set the date and time. Then it says "Preheat" (even though I don't select any coffee to prepare) and after 1-2 seconds it says "Unplug and reconnect or use app". The appearance of both messages is accompanied by sounds (as if something is switching). Maybe someone had the same problem?
    Probably this problem is no longer valid, but I just fixed my coffee maker that had exactly the same symptoms.
    I am sharing the solution here, maybe it will be useful for other people having the same problem.
    The reason turned out to be a broken tip of the temperature sensor, which is permanently attached to the boiler casing.
    After sticking with conductive glue, the error disappeared and the espresso machine works without errors.
    By the way, it was cleaned of all the ground coffee dirt inside :)
  • Clogged internal water filter causing disconnect error
    #16 20162646
    macgra19
    Rate: 23
    This may be the most common cause of this error: a clogged water filter - not in the water tank, but in the espresso machine. It's the white part on the back of the case where the water drain from the water tank goes. To clean it, you need to unscrew the espresso machine (the guide is here:
    https://youtu.be/S0cUNKSh8DY ), remove the water filter (located on the flow meter), clean it thoroughly and reinstall it.
    This reason is also described here:
    https://www.bean2cup.org/forums/index.php?s=2...73a9b5bb5b199b3eacae316&showtopic=18644&st=15
  • Filter removal without disassembling the machine
    #17 20163255
    macgra19
    Rate: 23
    It turns out that it is not even necessary to unscrew the espresso machine - just first remove the black gasket that protects the filter, and then remove the filter itself (it's hard to do, it's best to have some pliers handy). You also need to be careful when installing the filter so as not to block the side water outflow (there are four meshes on the side of the filter, you have to insert it in such a way that the water flow to the side outflow is ensured).
  • #18 20173654
    pakoo1
    Hello, when heating milk, this error pops up disconnect and re-use or use the application.
  • Boiler NTC sensor cable or glue fault
    #19 20541427
    dlusio
    Help: 11
    Rate: 40
    This error usually and most often causes unglued cables or a cable from the ntc sensor of the boiler, anyone who starts messing with the coffee machine can move the sensor or the cables will connect or not, the first answer is replacing the boiler ok will help because the sensor is glued to the boiler but it can either be soldered to boiler or stick it on thermally conductive glue and the error disappears. No filters, no descaling...
    Mobilny Serwis AGD LENKA
    Różana, Kraków, 32-020 | Tel.: 798XXXXXX (Show)
  • #20 20597676
    fotomarpl
    Rate: 9
    >>19293579
    And what to do in such a situation?
  • #21 20603834
    fotomarpl
    Rate: 9
    Disconnect and re-use or use the application" and errors 09, error 10 if you have such errors, please contact net.mar(_at_)interia.pl
  • #22 20664122
    kuba_puchatek
    Rate: 13
    For me, the reason turned out to be a broken tip of the temperature sensor, which is permanently attached to the boiler housing.
    After soldering, the error disappeared and the machine works without errors.
    Thanks for the hint.
  • Blown thermal fuses point to heater fault or overheating
    #23 20888142
    elvispm
    Hello, I will refresh the topic a bit, of course the same thing happened to me, the message "disconnect and ....." after following the recommendation disappeared, but instead "install 2 tanks" or something similar appeared, generally the message appears when the container is removed for coffee grounds. The container is always in its place 🤣. I disassembled it, checked the micro switch - it works, but both G4A00 216 ºC thermal fuses blew (the failure generally occurred after brewing coffee and in the milk frothing mode - which did not occur).
    I want to know the reason, because the fuse doesn`t blow like that. Does anyone know the resistance values of the heater in the furnace and the temperature sensor mounted on the furnace (which is often mentioned here)?
    Or maybe some other ideas as to why this happened.
    Thank you in advance for any help.
  • #24 20888916
    Ginulfi
    Help: 56
    Rate: 177
    It looks like the electronics are broken. When the boiler or NTC is damaged, it generates completely different messages. It simply displays the inscription "Heating". If you disconnect the boiler plugs and NTC, will anything change? Probably nothing that will indicate that the system is not progressing to this phase of testing.
  • #25 20996538
    lukaszjurkiewicz79
    For me, the message disappeared after removing the water tank. I poured it out, rinsed it, put it back in and it still works.
    Before disassembling, I suggest you do this simple step (press all drawers, wash) - if that doesn`t work, then disassemble.
  • #26 21024994
    bodan82
    Today I had the same symptoms, it turned out to be broken cables from the temperature sensor.
  • Blown boiler thermal fuses caused fault message
    #27 21149539
    Mordrag
    Rate: 9
    I know the topic is old, but maybe someone else will have this problem.
    In my case the thermal fuses on the boiler were blown. The ones next to the ntc sensor. Visible in the picture in this topic above.
    The sensor connectors looked ok. but when pulled harder one fell off and this was probably the cause of the burnt out thermals.
    The espresso machine may display, in addition to the standard "disconnect connect or application" message, a message about the need to lining up the tanks, because the limit switch and one of the thermals are on the same wire.
    Tomorrow when the parts arrive, I'll put it together and let you know if it works.
    Edit: I forgot to write. Everything is working. The machine makes coffee like new.
  • #28 21309731
    Zbyszek0708
    Rate: 12
    Where did you order the parts?
  • #29 21309735
    Mordrag
    Rate: 9
    >>21309731 .
    On Allegro. The name of the auction below. I think you can also match it somewhere else after the parameters from the auction. In any case, I bought exactly that and it works until now.
    KRUPS EA* NTC sensor element for repairing the thermoblock of the coffee machine
  • #30 21472198
    bizmax29
    After a few times of following the commands from the display the coffee machine worked. 🙄 On / off fills the coffee machine etc. And so far it is ok.
✨ The discussion concerns a Krups EA8908 coffee machine that repeatedly shows the message “Disconnect and reconnect or use the app” / “Automatic maintenance,” often immediately after startup or during rinsing, even when no coffee cycle is selected. Users report relay clicking, forced maintenance cycles, and related messages such as tank/container alignment warnings. Suggested causes include a faulty boiler temperature sensor/NTC, broken or loose sensor wiring, blown thermal fuses on the boiler, a clogged internal water filter/flow path, or a defective flow meter/harness. Several fixes were reported: cleaning/descaling the water circuit, reseating or replacing the flow meter filter, repairing or soldering the NTC sensor connection, replacing the boiler or thermal fuses, and in some cases the machine recovered after repeated power cycling or removing/reinstalling the water tank.
