[Solved] The browser does not load some pages, many applications are not running
xelektronikx 19044 15
Why do many websites and internet apps time out on all devices in my house, and how can I tell whether the problem is my router or my ISP?
If the same problem remains when you connect directly to the provider’s line instead of through your router, the fault is probably on the provider side rather than in your home network [#18609672][#18609712] In this thread, the issue persisted even after bypassing the router, so the router was ruled out [#18609699][#18609712] The original poster later confirmed it was a provider problem and that service returned when the external IP changed [#18611071]
  • #1 18609469
    xelektronikx
    Level 4  
    Suddenly, without any interference, the browser does not load many websites, Skype and some internet-based applications do not work, some pages load and some do not.
    This happens on all devices in the house, I restarted the router, checked if the IP addresses of the devices were not the same, I deleted the browser cache, I am not using any antivirus other than defender.
    Previously, I did something with the ports on the router but it shouldn't be a problem because I did a factory reset.
    ERR CONNECTION TIMED OUT
    The problem is on my side or the supplier?
    Edit
    Sometimes it happens that I do not have internet at all, I check cmd for pinging with other devices but everything is correct, if I do not have the Internet, I restart the router and the Internet appears, but there is still a problem with loading pages
  • #3 18609651
    xelektronikx
    Level 4  
    The supplier is ANFA
    A year ago, I changed the router to TPLINK WR841N
  • #5 18609668
    xelektronikx
    Level 4  
    I have a radio, so I still have an antenna
  • #6 18609672
    sosarek
    Help: 9320
    Rate: 15529
    So the cable from the "antenna" instead of the router connect directly to the computer and check if it works.
    Z
    Pka, Poznań, 60-850
  • #7 18609699
    xelektronikx
    Level 4  
    I connected now from the antenna and the same problem continues, the same websites and application do not work as before
  • #9 18610545
    xelektronikx
    Level 4  
    So no dns setting will do anything more?
    Are there any other possibilities for me to have a problem?
    The neighbor also has the same supplier but he has no such problems
  • #11 18610599
    xelektronikx
    Level 4  
  • #12 18610606
    sosarek
    Help: 9320
    Rate: 15529
    I wrote you what else you can do to rule out a problem with the system.
    Z
    Pka, Poznań, 60-850
  • #13 18610614
    xelektronikx
    Level 4  
    Now I went to win defender and found a lot of serious actions, a lot of exploits and trojans are listed
  • #14 18611033
    sosarek
    Help: 9320
    Rate: 15529
    Disconnect the power supply of this radio from the power supply for a few minutes.
    Z
    Pka, Poznań, 60-850
  • #15 18611071
    xelektronikx
    Level 4  
    I did on a device where I had a Trojan format but now there is no internet on all devices
    The error from dns is intertwined with the error that the microsoft resource is not responding
    Added after 38 [minutes]:
    Okay, the problem was with the provider, now everything is back to normal, I noticed that the external ip has changed
  • #16 18611184
    xelektronikx
    Level 4  
    Added after 33 [seconds]:
The user reported issues with their browser not loading various websites and applications like Skype across all devices in their home. They attempted several troubleshooting steps, including restarting the router, checking IP addresses, clearing browser cache, and performing a factory reset on the router (TPLINK WR841N). Despite these efforts, the problem persisted, leading to intermittent internet connectivity and DNS errors. The user later discovered that the issue was related to their internet service provider (ANFA), as the external IP address had changed, and connectivity was restored after the provider's intervention.
TL;DR: 100% of your devices failing plus "Okay, the problem was with the provider" points upstream; after 1 external IP change, pages loaded again. [Elektroda, xelektronikx, post #18611071]
Why it matters: This FAQ helps home users whose browsers won’t load some pages and apps fail, to isolate ISP vs router vs DNS fast.
Why do some websites and apps not load on all my devices?
When every device fails, suspect an upstream issue, not one PC. In this case, the ISP fixed it, and service returned. The user noted their external IP changed when it started working again. That pattern points to provider-side routing or IP assignment. If you see this, document timestamps and symptoms. Then contact your ISP. [Elektroda, xelektronikx, post #18611071]
How do I check if it’s my router or the ISP?
Use this quick isolation test:
  1. Unplug your router. Connect the antenna/CPE Ethernet directly to your PC.
  2. Get an IP automatically, then try the same sites and apps.
  3. If failures persist, it’s upstream. Call your ISP. “Connect the cable from the ‘antenna’ directly to the computer and check if it works.” [Elektroda, sosarek, post #18609672]
Will changing DNS servers fix this?
DNS changes help only when resolution is the cause. Here, DNS tweaks weren’t needed, because the ISP resolved the fault upstream. Service returned after the provider’s intervention and an external IP change. Run the direct-connect test first. If it still fails, involve your ISP instead of chasing DNS. [Elektroda, xelektronikx, post #18611071]
What does “ERR_CONNECTION_TIMED_OUT” mean and what should I do?
It means the site did not respond in time. Check your internet connection, VPN, proxy, and firewall settings. Clear cache and cookies. Try another network to compare. If multiple devices fail, test by bypassing the router. If the error persists, contact your ISP with details. “Fix connection errors in Chrome”
Should I power‑cycle the WISP radio/antenna (the rooftop or window unit)?
Yes. Disconnect the radio’s power supply for a few minutes to clear faults. Then power it back on and retest. This step can restore connectivity when the CPE hangs. If issues persist across devices after this, run the direct-connection test and contact your ISP. [Elektroda, sosarek, post #18611033]
My neighbor uses the same ISP and has no issues. Is that possible?
Yes. One subscriber can be affected while another is not. The thread reports a neighbor with the same supplier had no problems. Document your symptoms, run the direct-connect test, and escalate with timestamps and error messages. [Elektroda, xelektronikx, post #18610599]
Windows Defender found trojans. Could malware be the reason?
It can break networking on that specific device. If Defender reports serious threats, isolate that machine, update Defender, and run a full scan. Remove detected items or consider a clean reinstall. Only resume network testing after cleaning, to avoid false leads. [Elektroda, xelektronikx, post #18610614]
What does connecting the antenna cable directly to my PC tell me?
It bypasses your router and Wi‑Fi. If the same sites and apps still fail, the fault is outside your LAN. “Then the problem probably lies with the supplier.” Share the result with your ISP to speed diagnosis. [Elektroda, sosarek, post #18609712]
Why do pings work while web pages still fail?
Ping uses ICMP, which differs from web traffic over TCP and DNS lookups. ICMP replies do not guarantee that DNS, TLS, or HTTP traffic works. Firewalls or routing issues can allow ICMP yet break web sessions. Test DNS and HTTP separately to confirm. “What is ICMP?”
After the fix, my external IP changed. Is that normal?
Yes. ISPs can reassign your external IP during maintenance or fault resolution. In this case, connectivity returned after the change, indicating a provider-side adjustment. Record the change and time in your support ticket for reference. [Elektroda, xelektronikx, post #18611071]
Do I need a new router (e.g., TP‑LINK WR841N) to fix this?
Not if the bypass test still fails. The user connected the antenna directly to a computer and saw the same problem. That means the router wasn’t the cause, so replacing it would not help. Focus on the ISP path instead. [Elektroda, xelektronikx, post #18609699]
How should I talk to my ISP to get this fixed faster?
Share that the direct‑to‑PC test failed, include exact errors, and when they occur. Mention whether all devices are affected. Note any external IP change correlating with restoration. Ask them to check routing on your segment. This improved resolution here. [Elektroda, xelektronikx, post #18611071]
How can I test with a faster public DNS?
Set your device or router DNS to 1.1.1.1 and retest affected sites. This checks for resolver issues without changing providers. 1.1.1.1 leads global resolver performance at an average near 13–14 ms. Revert if no change. This is a diagnostic, not a cure‑all. “DNSPerf Resolver Rankings”
Edge case: Only some apps fail while others work—what should I check?
Selective failures are real. The user reported Skype and several internet apps failing while some pages loaded. Run the direct‑connect test, then power‑cycle the radio. If the pattern persists across devices, escalate to your ISP with timestamps and errors. [Elektroda, xelektronikx, post #18609469]
