Need Toshiba 32W3963DG Dump/Firmware - VES315WNDB-2D-N21, 17MB211S M/B
Namik79 5850 12
How can I get a working dump or firmware for a Toshiba 32W3063DG with panel VES315WNDB-2D-N21 and 17MB211S main board?
Use a direct EPROM/flash dump for the memory chip; one user reported that the provided file could be programmed into memory, and another later confirmed that the EPROM dump worked 100% [#18700037] [#18851885] The file was discussed as a memory-programming dump rather than USB recovery firmware [#18850790] [#18851885] The board memory mentioned in the thread is MX25L1606E NOR flash [#20767919]
  • #1 18656184
    Namik79
    Hello to all
    Please help me find dump for Toshiba 32W3063DG, panel code VES315WNDB-2D-N21, 17MB211S m/b. Thank you a lot off!
  • #2 18674648
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Hello, please tell me the serial number, to try to get the software
  • #3 18675008
    Namik79
    Hello, 8290955 900259 Thank you!
  • #4 18677378
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Already I requested the recovery software
  • #5 18677856
    Namik79
    Thank you very much! I wait for news from you.
  • #6 18684817
    Namik79
    Dear Sir, do you have any news?
  • #7 18686455
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    My friend who works at vestel is waiting for the recovery file to be provided.
  • #8 18686994
    Namik79
    Aquario_blue wrote:
    My friend who works at Vestel is waiting for the recovery file to be provided.
  • #9 18700037
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    My friend is having trouble getting the software, because the equipment was not sold in our country, however he provided a file to program the memory
    Test the attached file, if it resolves, I would like you to backup some files in order to help other users in the future
    • MX25L1606E.rar (31.88 KB) You must be logged in to download this attachment.
  • #10 18708203
    Namik79
    Not work ((((((
  • #11 18850790
    mick1066
    Hi, is this recovery firmware via USB, or dump (Bin file to direct reprogram EPROM)? Thanks.
  • #12 18851885
    mick1066
    Excellent eprom dump,works 100%,Thank you.
  • #13 20767919
    mykola10848
    >>18850790
    Obecnie klasyczna dwutranzystorowa technologia EPROM została niemal całkowicie wyparta przez pamięć flash typu NOR. Jednak nazwa EPROM jest mocno zakorzeniona w segmencie pamięci o niskiej pojemności, niezależnie od technologii.
    Added after 5 [minutes]:
    MX25L1606E - NOR flash memory
The discussion revolves around the search for firmware or a dump file for the Toshiba 32W3963DG television, specifically for the panel code VES315WNDB-2D-N21 and the 17MB211S motherboard. Users are requesting assistance in obtaining the necessary software, with one user providing a serial number to facilitate the search. There are mentions of recovery software requests, and one user indicates that a friend is attempting to acquire the software but is facing challenges due to the model not being sold in their country. An alternative file was provided for memory programming, but it did not work for the original poster. Later responses confirm the successful use of an EPROM dump. The conversation also touches on the transition from traditional EPROM technology to NOR flash memory.
TL;DR: Need a fix for Toshiba 32W3063DG/32W3963DG on 17MB211S? An EPROM dump "works 100%" for one user (100% success). This FAQ explains where to get it and how to program it safely. [Elektroda, mick1066, post #18851885]
Why it matters: It gives you a proven path to revive Vestel-based Toshibas when official recovery isn’t available.
Is this a USB firmware or a direct memory dump?
The working solution confirmed in the thread is an EPROM dump for direct programming of the TV’s firmware memory. One user reported: “Excellent eprom dump, works 100%.” That indicates a binary written into the TV’s flash rather than a USB update. [Elektroda, mick1066, post #18851885]
What board and panel does this apply to?
The request targets a Toshiba 32W3063DG using mainboard 17MB211S and panel VES315WNDB-2D-N21. Ensure your set matches these identifiers before using any dump. [Elektroda, Namik79, post #18656184]
Which memory IC holds the firmware on this set?
A contributor identified the firmware storage as NOR flash, specifically MX25L1606E. Use an appropriate NOR‑flash programming method for repairs. [Elektroda, mykola10848, post #20767919]
Do I need to provide the TV’s serial number to get the right software?
You might. In this thread the serial was requested, and the owner posted 8290955 900259. Providing it can help align firmware to your unit. [Elektroda, Namik79, post #18675008]
Why might official USB recovery not be available?
A helper noted difficulty obtaining the software because the equipment was not sold in their country. They therefore shared a file to program the memory directly. [Elektroda, Aquario_blue, post #18700037]
Where can I get the dump referenced here?
It was attached in the thread by the helper who requested testing. They also asked for backups if it worked, to help future users. [Elektroda, Aquario_blue, post #18700037]
How do I program the dump into the TV?
Typical workflow:
  1. Back up your original flash contents before any write.
  2. Program the provided dump file into the TV’s flash memory.
  3. Power‑up and test; if successful, share backups to aid others. [Elektroda, Aquario_blue, post #18700037]
What tools are typically required for this repair?
Use a flash programmer compatible with NOR flash memory and a safe way to access the chip. The post identifies an MX25L1606E NOR device, so match your tool to that family. [Elektroda, mykola10848, post #20767919]
Did anyone report a failure with the shared dump?
Yes. The original requester later replied “Not work ((((((” after testing the attached file. Treat hardware and panel mismatches as possible causes. [Elektroda, Namik79, post #18708203]
Is there a confirmed success case with this dump?
Yes. One user confirmed, “Excellent eprom dump, works 100%.” That single report indicates the binary can fully restore functionality when matched correctly. [Elektroda, mick1066, post #18851885]
What should I back up before flashing a new dump?
Back up the current contents of the firmware memory. The sharer explicitly asked for backups if the fix worked, to help other users later. [Elektroda, Aquario_blue, post #18700037]
How do I verify I have the right hardware IDs before flashing?
Confirm your TV uses mainboard 17MB211S and panel VES315WNDB-2D-N21, as specified in the request. Only proceed if these match. [Elektroda, Namik79, post #18656184]
Why do people say “EPROM” if the device is NOR flash?
A contributor explained classical EPROM has been largely replaced by NOR flash in low‑capacity roles, but the EPROM term is entrenched. [Elektroda, mykola10848, post #20767919]
What if I can’t source an official Vestel recovery for my region?
Follow the approach used here: program the shared memory dump instead of waiting for a regional recovery package. It was posted when recovery couldn’t be supplied. [Elektroda, Aquario_blue, post #18700037]
