Siemens SN66N098EU/A5: E19 Error Solved but Water Not Filling, Tap Symbol Appears - Help Needed
k0da_zaq 1653 0
  • #1 18676278
    k0da_zaq
    Hi I have a Siemens SN66N098EU/A5 4 yrs old.
    It started with E19 with broken solenoid and burned transistor (STN83003), after solenoid replacement and soldering transistor controller still shows E19 error. So I guess something burned into CPU.
    So I replaced controller with flashed one (12007911), e19 is gone now, but water is not filled. after cycle start it shows tap symbol.
    Though if I fill it with water manually, program continues. Aquastop is fine, just put there 220v and valve opened correctly.
    This controller opened a tap twice, when I had machine upside down, and pumps disconnected from the cup. That led me to an idea heat pump is not sending enough impulses, so I replaced heat pump too, didn't help. And I no longer able to reproduce valve open event.
    Anybody have an experience with such controller? Can somebody explain a logic flow happens within a controller?
    Thank you,
    Dinar
