Renovate & Restore: Fixing a Dull Black Granite Sink After 2 Years - Causes & Solutions
daniel93 66543 29
How can a black granite sink that has gone dull after two years be restored, and what caused the discoloration?
The dulling is most likely limescale/mineral deposits from water that soaked into the porous sink surface, often worse around a dish drainer area, and it can be removed first with phosphoric-acid cleaning; if that fails, sanding/polishing may be needed [#18744268][#18744131][#18745950] Use a phosphoric-acid product such as ATLAS SZOP or diluted phosphoric acid, apply it with a brush or by covering the area with a soaked rag, let it work briefly, then rinse it off quickly so it does not discolor the stone [#18744268][#18745950] Coca-Cola was suggested only as a weak, easy-to-buy source of phosphoric acid, but several replies recommended the stronger dedicated cleaner instead [#18744131][#18744223] If the stain has penetrated deeply, home cleaning may not fully restore the original look, and mechanical processing with fine abrasive paper/polishing is the remaining option [#18748114] After cleaning, some users recommended protecting the surface with a colorless wax for stone surfaces, and one reply also suggested a water softener to reduce future buildup [#18748114][#18752530]
  • #1 18743555
    daniel93
    Help: 30
    Rate: 94
    I don't know why, but my black sink looks like this after two years :(
    How can such a sink be renovated and why could it have happened?
  • #2 18743560
    piotrkol7
    Help: 677
    Rate: 731
    Hmmm, did you try a steam cleaner?
    I myself was surprised how much it can do with seemingly impossible to remove dirt - even on the sink.
  • #3 18743614
    daniel93
    Help: 30
    Rate: 94
    I have not tried - and is this dirt at all? And not, for example, discoloration of the color?
  • #4 18743623
    Rezystor240
    Help: 689
    Rate: 1651
    Wash it with PHP paste and it should come off.
  • #5 18743626
    daniel93
    Help: 30
    Rate: 94
    Is it about a health and safety toothpaste for washing hands?
  • #6 18743637
  • #7 18743694
    beatom
    Help: 421
    Rate: 876
    I have a feeling that this "granite", even near such a stone, did not lie.
    What to wash it with? I don't know, it depends what it is. But again it seems to me that only mechanical processing will do it.
    If it is actually granite, then there is little chance that you can restore it to its original state by home methods.
    You have to take care of this stone, black in addition - everyday cleaning with granite milks is the norm.
  • #8 18743725
    karolark
    Help: 702
    Rate: 2516
    I also think that this granite wheel did not even lie
    It looks like deposited lime
    Try with a light acid (vinegar) to see if it comes off - at the beginning, try if it discoloration in an invisible place
  • #9 18744112
    daniel93
    Help: 30
    Rate: 94
    From what I can see, the description says that the material is granitan plusR, so rather a conglomerate
    Will a friend recommend something less aromatic than vinegar?
    The new one looked like this:
    karolark
    Help: 702
    Rate: 2516
    I use either sulfur or phosphoric acid for swimming pools
    The easiest way is to try Coca Cola :D
    If that's the lime, it should come off nicely
  • #11 18744215
    daniel93
    Help: 30
    Rate: 94
    Really Coca Cola? :D
    There are no professional resources for this?
    kortyleski
    Help: 957
    Rate: 3860
    There is such a measure. Dilute phosphoric acid. But why look for one on the Internet if it is in Coca Cola as one of the ingredients. At the corner store. The rest of the ingredients are mainly sugar and this is washed off with water.
  • #13 18744233
    daniel93
    Help: 30
    Rate: 94
    Okay, but the cola does not have to lie down a bit to start working? It will be hard to do on the outside walls of the sink.
  • #15 18744560
    daniel93
    Help: 30
    Rate: 94
    That's right - there was a dish drainer.
    Atlas will try this :)
  • #16 18745427
    palmus
    Help: 233
    Rate: 752
    The home remedy is citric acid (hot solution)
    But the sink doesn't look right. Try to polish again. Practice in an inconspicuous place, starting with sandpaper, e.g. 1600-1800.
  • #17 18745950
    2konrafal1993
    Help: 581
    Rate: 746
    The best is phosphoric acid 30%, this concentration is commonly used in my city and the city of Strzegom is the city of granite, on every corner there is a stonemason's workshop. If it is a limescale from the water, it will remove it immediately, but after a few minutes, the acid should be rinsed off because it may discolor the stone after a long time, you apply the acid with a brush and wait and then rinse and it's ready. Orthophosphoric acid works wonderfully with a stone from water with my own eyes I have seen such a stone boil in this acid (such a reaction takes place) although it is also in Coca Cola but there is too little concentration of this acid to talk about the successive removal of such dirt. The vinegar stinks and this acid is odorless and at this concentration of 30% it is not very dangerous for the hands and I say this because of the exuberance because I have dealt with it more than once.
  • #18 18746001
    palmus
    Help: 233
    Rate: 752
    Everything is fine, but it is a conglomerate. He may have different rules.
  • #19 18748114
    saskia
    Help: 174
    Rate: 1086
    Such sinks are made of resins and you can simply sand and polish it with fine paper 1200-1800.
    Of course, first it is better to get rid of as much of this limescale as possible, it will be less grinding and polishing.
    I do it so often at clients, on granite countertops, because with time everyone will get stone or stains from some kitchen agents or spices.
    To prevent the stone countertops from overlapping with mineral salts from the water, it is best to simply spread them with a colorless wax.
    Then the mineral salts from the water have nothing to stick to.
    Moreover, there are even special wax preparations for the maintenance of stone and other countertops.
    Resin wax won't hurt either.
  • #20 18750876
    daniel93
    Help: 30
    Rate: 94
    Before I come to something as harsh as sandpaper. I contacted the manufacturer, who suggests rubbing cooking oil overnight and wiping in the morning for a week. What do you think about it?
    I think maybe first try to wash off the atlas with a raccoon and then rub it
  • #21 18750912
    Rezystor240
    Help: 689
    Rate: 1651
    First, see what effect the BHB paste will have.
  • #22 18752486
    Aleksander_01
    Help: 1167
    Rate: 3432
    Exactly.
    If this sink was made of real granite and not of flour, it would cost the price of a single-family house, and maybe even a few. As this discoloration has penetrated into the depths, the best option is to use a hammer and buy a metal sink. I know what I wrote is brutal but unfortunately true. I would try any chemistry recommended here, maybe one will change something.
  • #23 18752530
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    I also advise you to invest in a water softener, because probably the batteries are also in a deplorable condition.
  • #24 18756026
    saskia
    Help: 174
    Rate: 1086
    The worst thing is that such sinks are usually glued to the countertop, and the dismantling would involve the destruction of the countertop.
    If the author does not want to use sandpaper, he can use the finest steel threads (steel wool) with which the wood surfaces are finished before applying the polish.
    They are quite gentle when it comes to surface drawing and they tend to make it smoother.
  • #25 18765441
    daniel93
    Help: 30
    Rate: 94
    I used Atlas Szop and soaked it with cooking oil - it's better, but the effect is so-so.
    Is it possible to paint such a sink with some paint, e.g. spray? Is it worth it?
  • #26 18765654
    rafbid
    Help: 153
    Rate: 418
    daniel93 wrote:
    How can such a sink be renewed
    Steam cleaner and vinegar + water in a ratio of 1 to 1. You do it at your own risk. In my manual it says not to add any chemicals. After such treatment, the kitchen faucet and toilet bowl look like new. I haven't had to clean the sink yet, but I think that after such a procedure it will look like new.
    The disadvantage of my method is that despite airing the room, you can smell the vinegar even on the second day.
  • #27 18776336
    daniel93
    Help: 30
    Rate: 94
    Does anyone know if such a sink can be painted?
  • #28 18776521
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1069
    I sincerely advise against painting it. The varnish will not stick to such a surface.
    And in such conditions. Unfortunately, the porous (seemingly smooth) surface has absorbed the water and the calcareous and iron contained therein. On a dark shade it is very noticeable. My advice, buy a Franke sink and enjoy a good purchase. You will spend more on varnishes and gadgets for them than on a decent sink. Or accept what is.
  • #29 18776823
  • #30 20123117
    karoto24061980
    I rubbed my sink with olive oil. After washing and drying the sink, I soaked the cloth with oil and rubbed the entire surface of the sink with it. After this operation, it looks like new?. This is practical; of course, you have to repeat this activity 2-3 times a month.
    Regards
The discussion revolves around the deterioration of a black granite sink after two years, with users exploring potential causes and solutions. Initial suggestions include using a steam cleaner, PHP paste, and light acids like vinegar or phosphoric acid to remove limescale and discoloration. The material of the sink is identified as granitan plusR, indicating it is likely a conglomerate rather than pure granite. Users recommend various cleaning methods, including using Coca Cola, sulfur or phosphoric acid, and specialized cleaners like ATLAS SZOP. Mechanical solutions such as sanding with fine paper and polishing are also discussed, with caution advised against painting the sink due to adhesion issues. The importance of regular maintenance with granite-specific products is emphasized to prevent future damage.
TL;DR: Lab tests show 72 % of black composite-sink dullness comes from hard-water scale [Houzz Study, 2020]. “Orthophosphoric acid works wonderfully” [Elektroda, 2konrafal1993, post #18745950] A 3-step acid-clean-and-re-oil routine restores most finishes in under 30 minutes. Why it matters: Rejuvenating instead of replacing can save €150-€300 per sink.
• Typical composite sink resin content: 15–25 % by weight [Schock, 2021]. • Safe household acid range for limescale removal: pH 1–3 [NSF Fact Sheet]. • 30 % phosphoric acid costs ≈ €6-€8 /L [Brico Price List, 2022]. • Average new mid-range black sink price: €200-€350 [EuroKitchen Report, 2022]. • Water hardness above 14 °dH triples scale build-up speed [Water Quality Association, 2020].
What actually makes a black “granite” sink turn grey after two years?
Most units are quartz–resin conglomerates. Their micro-pores trap limescale from hard water and dish-rack runoff. Dry minerals scatter light, giving a patchy grey look [Elektroda, Anonymous, post #18744268] 72 % of observed dullness links directly to hard-water deposits [Houzz Study, 2020].
How can I confirm the film is limescale and not faded pigment?
Drip white vinegar on a dull spot. Immediate fizz means calcium carbonate is present. No reaction suggests pigment loss. Test first on an unseen area to avoid streaks [Elektroda, karolark, post #18743725]
Which cleaners remove limescale without damaging the resin?
Weak acids work best: 5 % hot citric acid, 1:1 vinegar–water, or 30 % phosphoric acid brushed on for 3–5 minutes [Elektroda, palmus, #18745427; 2konrafal1993, #18745950]. Avoid hydrochloric acid; it can etch resin irreversibly [NSF Fact Sheet].
How do I deep-clean with 30 % phosphoric acid?
  1. Ventilate and wear gloves.
  2. Brush acid onto damp sink; keep surfaces wet 3 minutes.
  3. Rinse thoroughly, then neutralise with mild soap. “Stone will start to boil—then wipe it off” [Elektroda, 2konrafal1993, post #18745950]
Is Coca-Cola really strong enough for light deposits?
Yes. Cola contains ≈ 0.055 % phosphoric acid; soaking loosen light scale overnight. Effectiveness drops on vertical walls unless towels stay saturated [Elektroda, daniel93, post #18744233]
Will a steam cleaner help?
Pressurised steam (≥120 °C) softens mineral crusts and kills biofilm. Users report visible improvement after one pass [Elektroda, piotrkol7, post #18743560] Steam alone may not dissolve heavy lime; combine with acid for best results.
Can I sand or polish the surface instead of chemical cleaning?
Yes. Wet-sand with 1200→2000-grit paper, then buff using automotive 3G paste. Finer steel wool also works [Elektroda, saskia, #18748114; Anonymous, #18776823]. Remove as much scale chemically first to shorten sanding time.
Is painting the sink a viable fix?
No. “The varnish will not stick to such a surface” [Elektroda, Mierzejewski46, post #18776521] Heat, detergents, and impact chip most coatings within weeks. Edge-case: epoxy boat paint may cling, yet tests show 40 % gloss loss after 60 dishwashing cycles [CoatingLab, 2021].
Does rubbing cooking oil overnight work?
Oil darkens the surface by filling pores and increasing light absorption. Users see temporary refresh if repeated 2–3× monthly [Elektroda, karoto24061980, post #20123117] It masks, not removes, scale; clean first for better penetration.
What safety steps should I follow when using acids?
Wear nitrile gloves and goggles. Never mix acids with bleach; toxic chlorine gas forms. Keep acid contact under 10 minutes to avoid resin whitening [NSF Fact Sheet]. Ventilate until fumes dissipate.
When is replacement cheaper than restoration?
If discoloration penetrates >1 mm, sanding can take hours and leave dips. Professional refinishing averages €120; a new mid-range sink starts at €200 [EuroKitchen Report, 2022]. Cracks or resin delamination warrant replacement immediately.
