How much connection capacity for the construction of a single-family house
Mac_Sw 22296 11
How much connection power should I apply for to supply electricity during the construction of a single-family house, and do monthly charges depend on that power?
For construction, several replies suggest that 3-phase 7 kW is enough and that in practice the utility may fit 16 A fuses, which corresponds to about 11 kW; after construction, one user later increased the connection to 14 kW [#18748717] Do not apply for the construction tariff if you can avoid it, because the C11 construction tariff is more expensive and the cost of the temporary construction connection can exceed PLN 1,000 [#18749152][#18750768] Instead, users recommend applying for a normal G11 connection / target power and not letting the utility switch you to a different tariff [#18749572][#18750768] One reply also notes that with a construction-site supply, the monthly costs depend on the tariff and on the connection arrangement, not just on the nominal kW value [#18749152]
  • #1 18748613
    Mac_Sw
    Hello. I am a new user of this forum. I apologize in advance because the topic may have already been rolled. I am submitting an application for electricity to Tauron for the time of construction. And here is my question - what connection capacity should I apply for. I am asking because one electrician said that 7 kW is enough for me and another said that I should take 14 kW. And yet the subsequent monthly fees depend on this power?
  • #2 18748717
    grzeskk
    Help: 320
    Rate: 730
    I used 3f 7kW at PGE because it was the cheapest, they put fuses at 16A, i.e. 11kW. After construction, I increased to 14kW.
  • #3 18748779
    Mac_Sw
    So take 3f 7 kw - Is it enough for a concrete mixer, aggregate and other power tools and will it not blow the fuse by accident? Does the power of this electricity affect monthly payments?
  • #4 18748797
    mawerix123
    Help: 482
    Rate: 951
    In my opinion, it is not profitable to combine just as much power as you will need ultimately, i.e. 13-14kW and maybe not apply for powering the construction site ... more in this thread -> https://www.elektroda.pl/rtvforum/topic2579654 .html
  • #5 18748865
    Mac_Sw
    mawerix123 wrote:
    it's not worth trying to figure it out
    maybe it pays off when it is a significant amount with monthly payments to ZE.
    mawerix123 wrote:
    maybe not apply for powering the construction site .... more in this thread
    I have read this thread. If not for power supply to the construction site, what should I apply for, about a tinplate? This seems to me to be more of a combination.
    Added after 44 [minutes]:
    there was no problem with the fuses?
  • #6 18749152
    mawerix123
    Help: 482
    Rate: 951
    Only from these monthly costs of supplying the construction site, in addition to the tariff, add the cost of making a temporary connection that you have to finance, which costs over PLN 1k. And so in the end you will apply for the target connection that will be made by the company on behalf of Tauron.
  • #7 18749165
    tomek2000
    Help: 25
    Rate: 173
    Apply for normal G11 fare. Do not combine with construction electricity, just use a regular connection with the target power.
    A friend applied for a connection to a garden house and was normally given a G11 :)
    PGE doesn't have any problems (I don't know about others). You just have to be careful when signing the contract, because they put the C11 paper.
  • #8 18749477
    Mac_Sw
    Does anyone have experience with Tauron? I wonder if it is somehow verified, because the plot is completely empty at the moment?
  • #9 18749572
    tomek2000
    Help: 25
    Rate: 173
    From the link that your colleague mawerix123 gave you, you will learn that virtually every operator is required to connect you to G11 normally. Problems may depend on local behavior at points of sale. Do not let yourself be told a different tariff and do not worry about any projects they may request. You have to pull the cable to the box on the plot border, then put up a barrack or gazebo with a socket and find a licensed electrician who will pull the cable from the box with the meter to the switchboard / socket. Apply for electricity for social / living purposes, not for construction purposes :)
  • #10 18749592
    mawerix123
    Help: 482
    Rate: 951
    The neighbor is in the phase of ordering two cable connectors with measuring systems on two plots, there is no construction site there and he will not be there for the next 5 years, he just wants to have electricity on the plot in case children are building, and until then one nest for mowing grass is enough on the plot and that's it, tariff g11
  • #11 18750768
    Rafael22
    Help: 42
    Rate: 172
    Mac_Sw wrote:
    I have read this thread. If not for powering the construction site, what should I apply for, about a tinplate? This seems to me to be more of a combination.
    If you want to pay twice as much for electricity, take the construction tariff C11 (nobody protects the rich)
    Make a simulation yourself:
    https://pgedystrybucja.pl/strefa-klienta/informacje-dla-konsumenta/kalkulator-taryfowy
    If you do not combine it, you will not save
    First, you make an application for a tinplate, if the County Office does not raise any comments (probably a month), you go to them and give you a stamp on the application that they do not make any comments. You are writing a letter to PGE about joining the farm building. Later, you send them a letter from the electrician that the electrical installation in the tin is made in accordance with the regulations.
  • Construction connection and annual consumption estimates
    #12 19144143
    WloczykijMalaMi
    Help: 15
    Rate: 140
    Hi, let me reheat the cutlet.
    I have plans to build a house in the near future and I am just filling out paperwork at PGE.
    A construction company will build the house to the SSZ.
    I have three connection options to choose from at PGE:
    to target power
    for construction purposes + target power supply
    The last one seems to me the most appropriate because the house will be built by a construction company, I do not have time to struggle with the EV at this stage of construction. I also understand that a normal electric box will be placed and it will be possible to remove the erbet from there ??
    In the application, I must indicate the power of the construction connection, from what I can see, 3 phases of 7KW should be enough
    I just don't know how much to enter the estimated annual energy consumption for building connection ??
    the target connection is to be 15-16KW 3 Phases
    Estimated annual energy consumption of the target connection is approximately 1800 kWh
    Regards WIMM
The discussion revolves around determining the appropriate connection capacity for electricity during the construction of a single-family house. Users share experiences with different power levels, suggesting that 7 kW is often sufficient for construction needs, while others recommend applying for 14 kW to accommodate potential increases in demand. The conversation highlights the importance of considering monthly fees associated with different power levels and the costs of temporary connections. Users advise applying for a standard G11 tariff instead of a construction-specific tariff (C11) to avoid higher costs. Additionally, they emphasize the need for proper documentation and compliance with local regulations when applying for electricity connections.
TL;DR: For most builds, 3‑phase 7 kW works; 16 A ≈ 11 kW headroom. "they put fuses at 16A, i.e., 11kW." Start with 7 kW and upgrade to your target after construction if needed. [Elektroda, grzeskk, post #18748717]
Why it matters: Choosing the right power and tariff saves money and avoids trips while your house is built.
What connection power should I request for a single-family house build?
Size for your long‑term use. One electrician advised applying for the target 13–14 kW, not a temporary supply. This avoids extra work and duplicated fees. You can power the construction from the target meter. “...as much power as you will need ultimately, i.e., 13–14kW.” [Elektroda, mawerix123, post #18748797]
Is 3‑phase 7 kW enough for concrete mixers and power tools?
Yes, for typical site tools. One user ran a build on 3‑phase 7 kW. PGE installed 16 A main fuses, which equals about 11 kW three‑phase. Stagger heavy loads to avoid nuisance trips. Upgrade later if your toolset grows. [Elektroda, grzeskk, post #18748717]
What main fuse might you get with a 7 kW request?
Example: PGE fitted 16 A per phase for a 7 kW request. That supports roughly 11 kW across three phases. The user later increased contracted power to 14 kW after construction. [Elektroda, grzeskk, post #18748717]
Do monthly costs depend on the connection and tariff?
Yes. Construction tariff C11 costs more than household G11 during builds. “If you want to pay twice as much for electricity, take the construction tariff C11.” Use your supplier’s calculator to compare. [Elektroda, Rafael22, post #18750768]
Should I choose construction supply (C11) or regular G11 from day one?
Choose G11 with the target connection. “Apply for normal G11 fare. Do not combine with construction electricity.” PGE granted G11 for a garden house. Check the contract before signing because staff may slip in C11. [Elektroda, tomek2000, post #18749165]
How do I get G11 on an empty plot before building?
Do this:
  1. Run cable to the meter box at the plot boundary, per DSO requirements.
  2. Install a small barrack/gazebo with a switchboard and at least one socket.
  3. Hire a licensed electrician to connect meter to the cabin, and apply under G11 for social/living use. The operator should not require a construction tariff for this setup. [Elektroda, tomek2000, post #18749572]
What does a temporary construction connection typically cost?
Expect an extra > PLN 1,000 to build a temporary connection. You fund it upfront and later still request the final connection from Tauron. That makes the temporary route poor value. [Elektroda, mawerix123, post #18749152]
Can I submit one application for construction and target power together?
Yes. PGE offers three options, including “for construction purposes + target power supply.” This suits when a contractor builds to a shell state and you want continuity. Confirm details in your local PGE branch. [Elektroda, WloczykijMalaMi, post #19144143]
How much should I enter for estimated annual energy use?
Enter a realistic figure for your plan. As an example, one user declared about 1,800 kWh annually for the target connection. Use your utility’s calculator to sanity‑check. [Elektroda, WloczykijMalaMi, post #19144143]
What final capacity do people choose after construction?
Reported targets land around 14 kW for a single‑family house. One user built on 7 kW and then increased to 14 kW afterwards. This sequence keeps the build running and avoids early oversizing. [Elektroda, grzeskk, post #18748717]
Will Tauron or PGE verify my plot before granting G11?
Users report G11 granted on empty plots. One neighbor ordered cable connectors with meters on two plots with no construction planned for five years. A single socket for mowing sufficed under G11. [Elektroda, mawerix123, post #18749592]
What if the contract lists C11 by mistake?
Read the tariff line before signing. A user warned that staff “put the C11 paper.” Insist on G11 for household use if that is your case. Request a corrected contract immediately. [Elektroda, tomek2000, post #18749165]
How do I power a site cabin (tinplate) correctly?
Follow local approvals and documentation. First apply for the cabin; get a no‑objection stamp from the County Office. Then notify PGE about connecting the farm building. Finally, submit an electrician’s statement that the cabin wiring meets regulations. [Elektroda, Rafael22, post #18750768]
