Connection power 7 kW vs 14 kW – difference in monthly fixed fees?
sputnik1 153741 33
How does a 14 kW connection compare to 7 kW in monthly fixed fees, and will I pay more for it for life?
For a residential G tariff, 14 kW instead of 7 kW does not mean a higher monthly fixed fee; the ordered power mainly affects the one-time connection charge, not the ongoing bill [#12718909][#12718864] In the G tariff, power has little impact on the bills, while in the C tariff it can matter significantly [#12718958] Several replies note that for a house under construction the utility may assign the C tariff, in which case there can be extra monthly charges for the ordered power until the tariff is changed to G after the building is inhabited [#12719504][#12727596][#12720811] One example given was about PLN 25 more per month during construction [#12720013], and another PGE case showed about PLN 550 per year extra at 1000 kWh/year [#12726490] So the key is not 14 kW versus 7 kW itself, but which tariff group you are billed under and whether you can switch to G for the finished house [#12727596][#12720811]
  • #1 12718549
    sputnik1
    Help: 9
    Rate: 114
    I warmly welcome
    I need help
    I got a contract from the power industry for the construction of a connection and a connection power of 14kw (as I applied for) to build a house.
    Now I have a puzzle because my friends have 7 kw. They tell me that it makes no sense because now I will pay a lot more for the rest of my life :-(
    How does it compare with fixed fees per month, not counting consumption, of course.
    The fact that the connection fee is calculated from kw, I know but what next ????
  • #2 12718864
    bartekfigura
    Level 30  
    Help: 112
    Rate: 524
    The power of 7 kW can be realized as a 1-phase connection, although it is rather not used in single-family housing. 14 kW is definitely a 3-phase connection and it is not much more expensive here. I used to have a 1-phase connection in my apartment, then I switched to 3 phases and I did not notice the difference in the amount of bills. However, the very order of 14 kW power is more expensive because in this case we pay for each kW, but it is a one-time fee. It is very good that you have opted for a 14 kW connection. It will be more convenient with today's number of electrical appliances in the home.
  • #3 12718909
    zbich70
    Help: 1171
    Rate: 6666
    There are no capacity-related charges in the G tariff group. Friends screw you up or have business. ;)
  • #4 12718958
    tom_bart1
    Help: 5
    Rate: 46
    For customers billed in the "G" tariff, the power has little impact on the bills, while in the "C" tariff, the impact of power is significant.
  • #5 12719110
    gogi20
    Help: 42
    Rate: 128
    zbich70 wrote:
    There are no capacity-related charges in the G tariff group. Friends screw you up or have business. :wink:
    Same thing all over again ... because it's a folk legend ... :)
  • #6 12719160
    sputnik1
    Help: 9
    Rate: 114
    Thanks for the information, now I'm completely stunned :-) . It's like, apart from the first connection fee, there really is no difference in the bills afterwards ???
    gogi20 and what did you mean?
  • #7 12719178
    gogi20
    Help: 42
    Rate: 128
    The fact that your friends provide you with information that the baker gave them and the baker gave them a mechanic, a mechanic ... and no one asked in the energy sector :) You just have to swallow the first charge for the connected power.
  • #8 12719249
    stomat
    Help: 257
    Rate: 1982
    There is no difference when it comes to the house. If it was about the company, yes, there is a difference. 7 kW per house is probably a mistake, in my opinion 14 is the minimum. Then people write here on this and other forums how to replace or remove the security because they have to walk to the CC all the time.
  • #9 12719504
    masonry
    Level 30  
    Help: 106
    Rate: 832
    After all, the author writes that the connection is for building a house. Knowing the thieves of ZE, I suppose that he got the C tariff and there is a difference not only in the first payment, but also in the later payments. I think it would be wiser to reduce the capacity for the time of construction, and when the G tariff is available, then to increase the capacity. There is one more possibility, recently there was a topic where the fight to change the tariff was described before the building was handed over. Probably the author succeeded, so maybe it is worth fighting now before signing the contract.
  • #10 12720013
    stomat
    Help: 257
    Rate: 1982
    Yes you are right. So you won't be paying more for the rest of your life just for the rest of the construction. More about PLN 25 per month.
    masonry
    Level 30  
    Help: 106
    Rate: 832
    I don't understand what you mean with paying until the end of construction. If he gets the G tariff immediately, he will not pay for the power ordered every month.
    Even if it was PLN 10 / month, it does not mean that I have to agree to being robbed by ZE. If there are more such cases, then either the EC will be forced to change its approach, or the EC will better legally validate its request for the settlement of individual construction in the C tariff (the tariff for economic activity).
    Even though you are a ZE employee, can't you see that there is something wrong here?
    Why is a private person who often builds a residential building to pay for electricity in a business tariff. Why can't he pay at G tariff?
    If someone builds in the form of a service (developer), let him pay in C tariff, but a private person in G.
  • #12 12720999
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    But how is ED to distinguish it, because if the application was submitted by the developer, it would be a different fairy tale, and Kowalski submitted to whom the company is building. I wonder if there are any regulations for it.
  • #13 12721385
    stomat
    Help: 257
    Rate: 1982
    Strong words but completely unfounded. Note that the price of energy in the C tariffs is set on an arm's length basis. There is competition and the market has set a price. Why do you say this is a "thieving" price? So open an energy trading company, offer a lower "fair" price and win the market.
    For political reasons, the state orders to sell energy to households at a lower price. Below the cost. It is imposed by means of tariffs controlled by the state office - ERO. I do not believe that it is a thief to strictly narrow the circle of subsidized recipients.
  • #14 12721621
    kkas12
    Help: 1076
    Rate: 4312
    Reasonable words, of course.
    The market and the law have nothing to say here.
    These are standards set directly and unlawfully by suppliers.
    Only free cash counts.
    A private investor is treated like a croissant and a cash cow.
    If he can afford construction, he can afford tribute to the energy supplier.
    Please read here Link and here Link
    These links show that this is however thievery.
  • #15 12721720
    masonry
    Level 30  
    Help: 106
    Rate: 832
    I would like to thank my colleague Krzysiek for providing the link, I was talking about the topic under the second link.
    Buddy dent, but it's not quite okay to loot a blacksmith just because he can afford to build a house.
    Since Tauron has bent, something is up.
    In that topic, everything is described in detail and the illegal ZE request is described there. It is about the demand to collect the building as a basis for changing the tariff, it is unlawful. Perhaps it is rather a ploy of ZE in order to collect undue money from recipients.
    The Energy Regulatory Office does not know everything either, it only knows as much as will be provided by the Electricity Association when approving tariffs.
  • #16 12722057
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    stomat wrote:
    Below the cost.
    Buddy, and what are the costs, if I am a monopolist, because power plants are how much I can charge for the generated energy URE will forbid me. I invite my colleague Stomat to the car park of the power plant employees. This is the case with many professions in this country that complain about the meager earnings (and these are the costs), check the parking lot and see what they drive to work.
  • #17 12723131
    sputnik1
    Help: 9
    Rate: 114
    And please, I asked about a supposedly simple matter and it turns out that ...
    I read the contract terms and calculations and found nothing about the tariffs.
    He only writes that Category V, whatever that is meant to be. The cost of a 14kw connection per plot is more than PLN 2,000 plus VAT, with a total output of about PLN 2,500.
    But now I am stupid because there is nothing about tariffs, only this 5th category.
  • #18 12723293
    bartekfigura
    Level 30  
    Help: 112
    Rate: 524
    It is a connection group.
    group V - entities connected directly to the distribution network, with a rated voltage of no more than 1 kV and a connection power of no more than 40 kW and a rated current of counter protection no more than 63 A.
    For example, other connection groups:
    group I - entities connected directly to the transmission network.
    group II - entities connected directly to the distribution distribution network, with a rated voltage of 110 kV, and entities connected to the distribution network that require electricity supplies with parameters other than standard, or entities with their own generating units cooperating with the network.
    group III - entities connected directly to the distribution network with a rated voltage higher than 1 kV, but lower than 110 kV.
    group IV - entities connected directly to the distribution network with a rated voltage of not more than 1 kV and a connection power of more than 40 kW or the rated current of the meter protection in the current path greater than 63 A.
    group VI - entities connected to the network through a temporary connection, which will be replaced by a target connection on the terms specified in the agreement, or entities connected to the network for a specified period, but not longer than one year.
  • #19 12723455
    stomat
    Help: 257
    Rate: 1982
    Buddy Krzysztof, power plants are no longer "monopolists". Power plants have very different owners and energy is bought on the power exchange TGE . I think it's time to get used to the fact that the product has different prices for different recipients. Today, at the petrol station, I also wanted to refuel ON TIR, because it is cheaper and it is refueled from the same distributor, but the "thief" from the station did not let me do it and he robbed me only because I could afford a car. Tomorrow I am writing a letter to Orlen what is the right to this :)
    PS Did I write anything about low earnings? For a change, I invite you to see what the state of the net is, especially in the countryside.
  • #20 12723987
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    I come from Silesia and there is a lot of investment in the countryside, I think even more than in cities.
    You did not write anything about small earnings, I wanted to make you aware of where these costs are. I know Mrs. The main power engineer of a large plant that buys energy and sells surplus energy. He claims that it is IDEE FIXE.
  • #21 12724198
    masonry
    Level 30  
    Help: 106
    Rate: 832
    stomat wrote:
    Today at the petrol station I also wanted to refuel ON TIR, because it is cheaper and it is refueled from the same distributor, but the "thief" from the station did not let me do it and he robbed me only because I can afford a car
    It's very good that he didn't let you. The gun from the dispenser for TIR is thicker and would not fit into your filler, you would still spill fuel. :D
    If ZE correctly (legally) establishes its requirement to settle the construction site in tariff C and does not change the mind for some of the smarter recipients (not afraid to fight), it will cease to be a thief.
    We have examples that some have managed to win a tariff change without taking over the building, so not everything is okay.
    If the ZE was almost valid, it would not change the tariff, meanwhile, there are more people who got the G tariff without construction acceptance.
  • #22 12726462
    sputnik1
    Help: 9
    Rate: 114
    That is:
    - due to the greater connection capacity, someday I will not pay more?
    - and when will I find out about the applied tariff?
  • #23 12726490
    grzeskk
    Help: 320
    Rate: 730
    Colleagues, this week I was dealing with PGE. For the time of construction, I was given the C11 tariff, 7kW power (at my request, 3xC16 fuse) when signing the contract, with the requested 13kW (3xC20 fuse). Now I was able to change the tariff to G11 (G12 is not profitable) at the request signed by an electrician and after the ZE control if the building is inhabited and no construction works are being carried out - the building has not been taken back. The fees are higher by approximately PLN 550 per year with an average consumption of 1000kWh / year. Such realities are in PGE, comp. Lowicz.
  • #24 12726871
    stomat
    Help: 257
    Rate: 1982
    Since the tariff (approved by the Energy Regulatory Office) is not enough, I wonder if the Sejm act will be sufficient? Or maybe you need to enter into the constitution?
    And the fact that somewhere out there an employee waved his hand and included the bugger in the wrong tariff for the sake of peace and quiet means nothing. I was once caught by a policeman when I entered the ban, he took the documents and after a while said: "okay, go sir". Does this mean that you do not get a fine for entering the ban? And that those who give tickets for it are thieves?
  • #25 12727322
    sputnik1
    Help: 9
    Rate: 114
    The farther into the forest, the more trees ;-) . Honestly, I was completely stupid. and I don't know how to want, I don't know what the difference and how the tariff is.
  • #26 12727596
    zbich70
    Help: 1171
    Rate: 6666
    What do you not understand? The tariff group will be determined at the stage of concluding the contract for the sale and supply of energy. It will probably be group C (for the time of construction). Whether it is legal or not, you have the details above. You have to judge for yourself whether you want to fight "battles".
    As for the difference in fees - you will find everything in the operator's tariff.
    Example
  • #28 16298196
    Robinson74
    Rate: 159
    Exactly. Is it possible without major costs?
    For example, 7 kW for the construction period and 14 kW ultimately?
    What if during the construction it turned out that the 7 kW is not enough? What may be the cost of such an increase in power for the construction site?
    Studio Języka Angielskiego
    Piastowska 18, Krosno, 38-400
  • #29 16298341
    stomat
    Help: 257
    Rate: 1982
    Of course you can. After all, at the construction site of a steel plant, for example, much less power is needed than the steel plant then uses for its normal operation. Construction and a dwelling house are two different things. You can read the prices of the distributors and sellers available on their websites.
  • #30 16298862
The discussion revolves around the differences in monthly payments associated with electricity connection capacities of 7 kW and 14 kW for residential construction. The initial connection fee is higher for 14 kW, but subsequent monthly fees may not significantly differ, especially under the G tariff, which is more favorable for residential users. Participants clarify that while the 14 kW connection is more suitable for modern households with multiple electrical appliances, the impact on monthly bills largely depends on the tariff classification (G vs. C). Some users suggest that the higher capacity may only incur additional costs during construction, and switching tariffs post-construction could mitigate long-term expenses. The conversation also touches on the complexities of tariff classifications and the potential for legal disputes regarding energy supplier practices.
TL;DR: A 14 kW home connection costs a one-off ~2 500 PLN but adds 0 PLN/month in G-tariff capacity fees; “There are no capacity-related charges in the G tariff group” [Elektroda, zbich70, post #12718909] Capacity uplift at PGE is 7.87 PLN per kW [Elektroda, stomat, post #16303273]
Why it matters: Choosing the right power and tariff prevents surprise bills during and after construction.
• One-off connection fee: 14 kW ≈ 2 500 PLN incl. VAT [Elektroda, sputnik1, post #12723131] • Capacity uplift price (PGE): 7.87 PLN / kW [Elektroda, stomat, post #16303273] • Monthly capacity charge in G-tariff: 0 PLN [Elektroda, zbich70, post #12718909] • Typical capacity charge in C-tariff: ~25 PLN/month for 14 kW [Elektroda, stomat, post #12720013] • Average Polish household use: ~2 000 kWh/year [Eurostat, 2022]
Will a 14 kW connection raise my monthly bills compared with 7 kW?
No, if you are billed on the household G-tariff. That tariff has no standing charge per kilowatt, so 7 kW and 14 kW cost the same each month once the connection is built [Elektroda, zbich70, post #12718909]
Why do builders warn about higher fees with more power?
During construction you are often placed on the business C-tariff, which adds a capacity charge. At 14 kW that can be about 25 PLN per month [Elektroda, stomat, post #12720013] Once you switch to G-tariff the extra fee disappears.
How big is the one-off connection fee difference between 7 kW and 14 kW?
Distribution operators price the connection per ordered kilowatt. The poster paid about 2 500 PLN for 14 kW; 7 kW would have been roughly half that [Elektroda, sputnik1, post #12723131]
Is 7 kW enough for a modern single-family house?
Many users find 7 kW too low; appliances can trip a 1-phase fuse. “14 kW is the minimum” for current loads [Elektroda, stomat, post #12719249]
How do I change from C-tariff to G-tariff before house completion?
Submit a written request, include an electrician’s statement that the house is inhabited, and pass a utility inspection. One user switched this way without an occupancy permit [Elektroda, grzeskk, post #12726490]
Can I start with 7 kW during construction and upgrade to 14 kW later?
Yes. PGE charges 7.87 PLN per added kilowatt when no network work is needed—55.09 PLN to move from 7 kW to 14 kW [Elektroda, stomat, post #16303273]
What happens if 7 kW proves insufficient?
Frequent breaker trips occur, forcing manual resets or fuse replacements—an avoidable nuisance [Elektroda, stomat, post #12719249]
Are there edge cases where G-tariff users still pay capacity fees?
Only if mis-classified. Some builders were wrongly left on C-tariff; after complaint and regulator review, fees were refunded [Elektroda, masonry, post #12724198]
3-step How-To: request a power increase
  1. Download the “Change of Connection Parameters” form from your DSO’s site.
  2. Fill requested kW and attach current installation diagram.
  3. Submit; pay the quoted fee (e.g., 7.87 PLN/kW at PGE). Approval typically arrives within 30 days [Elektroda, stomat, post #16303273]
