[Solved] Fixing Philips NP1100 Internet Radio: Stations Not Found & Troubleshooting Tips - Erwin's Query
erwin1949 16770 7
  • #1 18748944
    erwin1949
    Hello, I am Erwin. I have a Philips NP1100 internet radio, even two and both are not working. Because I thought it was broken and I bought another one. What can I do to make them play for me? The error is that the station that interests me cannot be found. Can someone help me? I would like to ask you very much.
    Regards Erwin.
    Separated from the topic: Welcome topic for new users - introduce yourself
    by ArturAVS on 09 Jun 2020 15:53
    I corrected the spelling. In the "welcome" topic, we are not looking for help, but only introduce ourselves. In the appropriate departments, please describe your problems. [ArturAVS]
  • #2 18749139
    Polon_us
    Help: 1184
    Rate: 1280
    I owned this internet radio at one time and know exactly what my colleague is writing about. I also struggled with the lack of stations I wanted to listen to.
    There is a workaround, i.e. you can program the stations you want, but it is a bit "tedious".
    First of all, a colleague needs to know the streaming address of the radio in question - this is not the same as the address shown on the website of the radio in question. Please bear this in mind. For example, such a streaming address looks more or less like this -> "http://stream.task.gda.pl:8000/rg1"
    In order to put this address in his receiver, the colleague has to:
    - register this receiver on the Philips website
    - after registration, access to this receiver will be available via the mentioned Philips website
    - there will be a tab there that will allow you to enter the data of this station,
    - this will then be transferred to the receiver's memory via the Philips server
    - this Internet radio station will be visible in the "Favourite" menu of the receiver
    - Further entries can be made at any time
    A detailed description of the entire procedure can be found in the receiver's manual.
    As I have already mentioned, it is somewhat complicated, but it can be done
    Good luck :) .
  • #3 18749200
    erwin1949
    Thank you for the comprehensive explanation I will be combining Greetings.
  • #4 18819975
    Agnn
    From what Phillips gives, this radio has stopped working and will not be anymore. I have them too and the problems described have been appearing for several years. Either it does not search for stations (then the method given by Polon_us worked in the past) or you cannot connect to the Internet at all.
    Customer support of Phillips Polska in 2018, after several weeks of trying to solve the problem, stated that the serving server was down. Despite this, sometimes I was able to search for a station. But at the moment I can't connect to the internet at all, and support from Great Britain reported that the radio was made by an external provider that went bankrupt and Phillips has no documentation (!).
    Anyway, at the moment I can't even go to the radio management page on the Phillips website (procedure described by Polon). Only the page header appears, without any content.
    Unfortunately, I'm planning to buy a new radio. Maybe someone knows a reliable piece to connect to the amplifier? I will celebrate Phillips from afar.
  • #5 18820313
    Polon_us
    Help: 1184
    Rate: 1280
    Well, the reason I parted with this Philips product was because of its crashing as well as breaking the internet connection when it was working.
    Now I am using the Ocean Digital WR-10 receiver. I am very pleased with it. It is equipped with a number of audio outputs - analogue, digital optical and Coax. It has a number of useful functionalities, e.g. USB, BT, DAB, FM or the ability to work after DLNA. Connection to the Internet via WiFi or LAN.
    A very big advantage is the ability to directly connect to this tuner from your computer over the home network. This gives you the option of freely adding an Internet station without watching the service that supports this radio, you can also arrange your preset stations nicely using a computer. The receiver is operated by Skytune service - very good in my opinion.
    The only thing I could stick to is a relatively small display. But I can do it :)
  • #6 18821969
    Agnn
    Thanks for the recommendations. I don't want to hit like this Phillips radio
  • #7 18956213
    erwin1949
    Unfortunately the radio has stopped working and there will be no more dots.
  • Time display returned and internet radio works again
    #8 19110391
    Mikevandyke
    Hello, forum community.
    I'm Conny from Drahnsdorf.
    I wanted to let you know that the Philips internet radio is back on, just like that ...
    It has not shown the time for over a year. I could only play Internet radio via the Fritzbox set stations.
    Suddenly about 2 weeks ago, the device showed the usual time again, and lo and behold, I was able to play my radio stations again.
    Again with patience a device saved from disposal.
Erwin is experiencing issues with his Philips NP1100 internet radios, which are unable to find stations. Other users have reported similar problems, indicating that the device may no longer function properly due to server issues and lack of support from Philips. One user mentioned that Philips customer support confirmed the server was down and that the radios were made by an external provider that has since gone bankrupt, leaving Philips without documentation. Another user shared their positive experience with the Ocean Digital WR-10 receiver, highlighting its various functionalities and ease of use. A different user reported that their Philips radio unexpectedly resumed functionality after a year of inactivity, suggesting that patience may lead to a resolution.
