repair my HDMI IC Mn864729 PS4 PRO, we accidentally removed two capacitors
Moraes 3717 0
  • #1 18768129
    Moraes
    Witaj, próbując naprawić mój układ scalony HDMI Mn864729 PS4 PRO, przypadkowo usunęliśmy dwa kondensatory obok układu (są one naprzeciwko „P” od Panasonic). Jeśli ktoś zna lub ma BoardView (najlepsza opcja) schematu elektrycznego karty NVA-001 i może ją udostępnić, będę wdzięczny !!
    Olá, em uma tentativa de reparo do meu CI HDMI Mn864729 PS4 PRO, acidentalmente retiramos dois capacitores próximos ao chip (ficam do lado oposto ao "P" de Panasonic). Se alguém souber ou possuir um BoardView(Melhor opção) do esquema elétrico da placa NVA-001 e puder compartilhar, ficarei grato!!
    Hello, in an attempt to repair my HDMI IC Mn864729 PS4 PRO, we accidentally removed two capacitors next to the chip (they are opposite the "P" from Panasonic). If anyone knows or has a BoardView (Best option) of the electrical scheme of the NVA-001 board and can share it, I will be grateful !!
    • repair my HDMI IC Mn864729 PS4 PRO, we accidentally removed two capacitors CI HDMI IMAGEM.jpg (83.61 KB) You must be logged in to download this attachment.
