Installing an Air Heat Pump in a Garage: Feasibility and Impact - User Inquiry
15213 9
Can I install a heat pump in an adjacent garage to reduce noise and keep the installation close to the boiler room?
No, putting the outdoor heat-pump unit in the garage is generally a bad idea because the unit needs large air flow and would effectively cool the garage instead [#18769549] If you mean an indoor all-in-one unit, forum replies say building rules may forbid heating appliances in such a room, and a heat pump for central heating plus hot water is too large for this setup; a DHW-only unit was cited at about 2 kW and 400 m3/h, while a heating + DHW unit was cited at at least 8 kW and “won’t work in the garage” [#18769033][#18769836] Noise-wise, the discussion says modern units can be quieter than older split systems, but “silent” modes reduce efficiency [#18769836] Another reply notes that some manufacturers, like Vaillant, offer quieter models and distance-based sound tools, so the real noise impact depends on the exact model and the distance to the neighbor [#18770363]
  • #1 18768928
  • #2 18768960
    jack63
    Help: 851
    Rate: 2822
    Want to cool your garage?
  • #3 18768981
  • #4 18769033
    krzyzak11
    Level 19  
    Help: 25
    Rate: 100
    It seems to me that building codes forbid this place for heating appliances (certainly no gas boiler allowed).
    Is this a pump for what or hot water?
    Note that the hot water pump moves about 400m3 of air per hour. You leave the room and there are 4 letters left of the pump capacity.
  • #5 18769341
  • #6 18769549
    ls_77
    Help: 500
    Rate: 947
    But do you want to install an indoor or outdoor unit in your garage?
    As an external one, it falls off due to the large air flows through the external unit.
  • #7 18769563
    karolark
    Help: 702
    Rate: 2516
    czesterw wrote:
    Yes. I will fish.
    But seriously. A annoying neighbor lives next door and, as I wrote, a pump fan with 90 dB
    could be unpleasant, especially at night.
    Where did the 90db come from?
  • #8 18769836
    krzyzak11
    Level 19  
    Help: 25
    Rate: 100
    400m3 was for the pump for heating only hot water. She has a power of 2kw
    You are talking about a central heating and hot water pump, power at least 8 kW.
    It won't work in the garage.
    But these devices are a bit louder than an air conditioner.
    In addition, it will work mainly in the cold season, when the neighbor's windows will be closed.
    In addition, the pump has a silent function, but it loses efficiency.
    If you want a quiet pump, look at the Bosch 7000, they are much quieter than Daikin's split pumps, but also a different price. You can't compare these devices in the SSD dr. Structurally completely different devices. The fact that both draw energy from the air, both are used for heating.
  • #9 18770363
    ls_77
    Help: 500
    Rate: 947
    As for the noise level of the heat pump, how close/far does your neighbor live?
    Vaillant also makes silent heat pumps. There are also some cool volume boosters on their site based on how far you are from the pump.
  • #10 18770542
The discussion revolves around the feasibility of installing an air heat pump in a garage adjacent to a building, with considerations for noise levels and building codes. The user, Czeslaw, expresses concerns about the noise from the pump, particularly at night, and seeks advice on the suitability of placing the unit in the garage, which has a volume of approximately 65 m³. Responses highlight the importance of understanding the specific type of heat pump (for heating or hot water) and its air flow requirements, noting that certain models may be quieter. Brands like DAIKIN and Bosch are mentioned, with Bosch's 7000 model suggested as a quieter alternative. The discussion also touches on the potential noise impact on neighbors and the need for compliance with local regulations regarding heating appliances.
