Setting Water Hardness on Electrolux EEM48321L Dishwasher: Key Combinations & MediaExpert Assembly
GREG0728 28353 9
How do I enter the settings and set the water-hardness level on an Electrolux EEM48321L dishwasher?
Use the dishwasher’s settings procedure described in manual section 7.8 to change the water-hardness level; sections 7 and 7.1 provide the related hardness information. [#18778259] The factory default is level 5. [#18778119] First determine the local water hardness, then use the manual’s table to select the corresponding dishwasher setting. [#18778707] For the cited Sosnowiec/Maczka water-supply results, the calculated setting was considered to be at most level 4. [#18780293]
  • #1 18777992
    GREG0728
    Rate: 10
    ELECTROLUX EEM48321L dishwasher - I can't set the water hardness from the instructions, can you tell me how to do it?
    Is it some combination of keys because the assemblers from MEDIAEXPERT also could not set it for me, claiming that the dishwasher adjusts itself to the hardness of the water ...
  • #2 18778119
    rozales
    Help: 43
    Rate: 160
    Everything is described in points 7 and 7.1 of the manual.
    By default it is set to 5. What value do you want to change to?
  • #3 18778180
    GREG0728
    Rate: 10
    If in the BEKO dishwasher I had a level of 4 out of 5 and in the coffee machine I also got 4 out of 5 in December, I thought about setting the dishwasher to 7 out of 10? I just don't know how, the instructions are hard to read for me...
  • #4 18778259
    rozales
    Help: 43
    Rate: 160
    In point 7.8 everything is described what and how.
    You did it?
  • #5 18778474
    GREG0728
    Rate: 10
    Amateurism on my part but I didn't, I didn't read it ? it's strange that mediaexpert professionals didn't know that either...
  • #6 18778707
    rozales
    Help: 43
    Rate: 160
    Then find out what water intake you have and in the table read what you have to set.
  • #7 18780142
    GREG0728
    Rate: 10
    I have the results of water tests in Sosnowiec - the MACZKA intake (attached) but it's a bit hard to find...
    • 202005maczki.pdf (1.87 MB) You must be logged in to download this attachment.
  • #9 18780858
    GREG0728
    Rate: 10
    Thank you very much for your help and calculations ?
  • #10 18799681
    Akinomak
    Rate: 56
    So how do you enter setup mode? I wanted to turn off the AirDry function and I don't know how to enter the setting mode...
The discussion revolves around setting the water hardness on the Electrolux EEM48321L dishwasher. Users reference the manual, specifically points 7 and 7.1, which detail the settings. The default hardness level is set to 5, and users inquire about adjusting it based on their water quality. One user mentions previous settings on a BEKO dishwasher and a coffee machine, suggesting a desired hardness level of 7 out of 10. Additional guidance is provided to check local water hardness and adjust settings accordingly. A link to a water hardness conversion tool is shared, and there are inquiries about entering setup mode to disable the AirDry function.
