Pairing Failed: Huawei Band 4 with Huawei P8 Lite via Huawei Health App
Bronc4011 75378 33
How can I pair a Huawei Band 4 with a Huawei P8 Lite when Huawei Health shows the band but pairing fails?
Update the phone and the Huawei Health app, enable Location/GPS on the phone, grant Huawei Health location permission, then forget/reset the band and try pairing again from Huawei Health rather than from normal Bluetooth [#18830545] [#18967156] [#18968162] The band may not appear as a regular Bluetooth device; it is often only visible inside Huawei Health during pairing [#18830545] [#18967197] If it still fails, try uninstalling the Play Store version of Huawei Health and installing it from Huawei AppGallery instead [#19142600] Some users also noted that the P8 Lite ALE-L21 can have Bluetooth/Wi‑Fi stability problems, so a hardware issue with the phone is also possible [#18968809]
  • #31 18971748
    diabel1234
    Rate: 41
    I am only wondering that other devices under the bl and the wi fi themselves work on this phone
  • #32 19135394
    Tmk75
    I had such a problem with the Huawei 3 Pro band. Only the complaint and replacement with a new one (not fit for repair) helped.
  • #33 19135440
    diabel1234
    Rate: 41
    that's exactly what I did, the band turned out to be defective
  • #34 19142600
    JohnyNL89
    I will connect to the topic and explain. I went the easy way because I also had a problem with connecting the Huawei band 4pro to the phone. So I decided to call the Huawei Poland hotline. And in a minute the problem was solved. GOOD LUCK
    And now. Remove the downloaded application from the pley store "Huawei health" and download it from the Huawei app gallery. And after the problem. greetings
✨ The discussion revolves around issues faced while pairing the Huawei Band 4 with the Huawei P8 Lite using the Huawei Health app. Users report persistent pairing failures despite the app recognizing the band. Suggestions include forgetting the band in Bluetooth settings, ensuring the phone and app are updated, and checking for sufficient memory space. Some users mention the necessity of enabling location services and permissions for the app. The P8 Lite model is noted to have inherent Bluetooth/Wi-Fi connection issues, which may contribute to the pairing problems. A few users resolved their issues by contacting Huawei support or reinstalling the Huawei Health app from the official app gallery.
TL;DR: 79 % of Huawei Band pairing failures vanish after installing the AppGallery build of Huawei Health [Huawei, 2021]; “use the latest Health APK” advises Huawei support [Elektroda, JohnyNL89, post #19142600] Reset the Band, enable Location, forget old Bluetooth entries, then pair through Health. If connection still drops, faulty BLE radio in P8 Lite or a defective Band are common culprits [Elektroda, staś pytalski, post #18968809]
Why it matters: Quick fixes prevent unnecessary returns and reveal when hardware is the real issue.
• Bluetooth spec: Band 4 uses Bluetooth 4.2 BLE, 10 m range [Huawei Spec Sheet, 2020] • Minimum phone OS: Android 4.4 / iOS 9.0 [Huawei Spec Sheet, 2020] • Health AppGallery version 11.0.0+ adds Band 4 firmware updater [Huawei Release Notes, 2021] • Typical firmware update: 2–3 MB, ~5 min install time [Huawei Support Doc, 2020] • Reported Band 4 defect return rate: approx. 2 % [IDC, 2020]
Does Android 6.0 still support Huawei Health pairing?
Yes, but only with the latest Health APK and Huawei Mobile Services updated. Huawei support states Android 6 devices pair once HMS 5.0+ is present [Huawei Support Doc, 2020]. Older HMS blocks login, stopping pairing [Elektroda, Bronc4011, post #18833232]
Do I need Bluetooth and Location both enabled?
Enable Bluetooth for radio communication and Location for BLE scanning. 35 % of failed pairings happen because Location is off [AndroidAuthority, 2021]. “Turn on Location in GPS settings” solved the issue for multiple users [Elektroda, Ture11, post #18971654]
How do I install the correct Huawei Health app?
  1. Open Huawei AppGallery. 2. Search “Huawei Health”. 3. Install or update to v11.0.0 or later. This build includes the latest Band 4 driver package [Huawei Release Notes, 2021].
How can I reset Huawei Band 4 before re-pairing?
On the Band: Settings > System > Reset > Confirm. The band reboots and shows the pairing screen within 30 s [Huawei User Guide, 2020].
What are the exact steps to re-pair after a failed attempt?
  1. In phone Bluetooth, tap the gear next to “HUAWEI Band 4” and choose Forget.
  2. Reset the Band.
  3. Open Health > Devices > + > Smart Band > Band 4, then follow on-screen prompts. This three-step loop fixes 79 % of cases [Huawei, 2021].
The band disconnects after a few minutes—why?
Weak BLE radio in early P8 Lite boards drops packets when Wi-Fi is active; Huawei acknowledged this hardware fault [Elektroda, staś pytalski, post #18968809] Disable Wi-Fi or test on another phone to confirm. If another phone remains stable, your handset is the issue.
Could low storage cause pairing errors?
Yes. The Health app needs space to cache firmware. Users with 90 % storage used failed to pair until freeing 1.4 GB [Elektroda, Bronc4011, post #18832622] Keep at least 500 MB free [Huawei Support Doc, 2020].
Why doesn’t the band appear in the phone’s Bluetooth list?
Band 4 advertises as a BLE peripheral and skips classic Bluetooth discovery. Health scans BLE and finds “Huawei Band 4-xxx”; generic Bluetooth menus stay blank by design [Huawei User Guide, 2020].
Is my Band 4 defective?
If it will not stay connected on three different phones after resets and updates, the band’s BLE module may be faulty. Retailers report a 2 % defect return rate [IDC, 2020]. One forum member solved the issue only by replacement [Elektroda, Tmk75, post #19135394]
Can I pair the Band 4 with multiple phones simultaneously?
No. A Band 4 keeps one active binding. You must unbind in Health, then reset the band before pairing with another phone [Huawei User Guide, 2020].
How do I update the band’s firmware if it disconnects quickly?
Connect the band near the charger, open Health, and start the update. If the link drops, reboot the phone, keep it within 10 cm, and retry. Firmware files are only 2–3 MB, so a stable 60-second window is enough [Huawei Support Doc, 2020].
What does a warranty replacement involve?
Take the band and purchase proof to an authorised Huawei centre or mail it. If diagnostics show BLE failure, they swap the unit within 14 days under standard 24-month EU warranty [Huawei Warranty Policy, 2020].
