Kubota B7000 Tractor: White Smoke, Pneumothorax Blowing, Z650 Engine Issues & Solutions
Tajfun211 14568 30
How do I fix white smoke, blow-by, and hard starting on a Kubota B7000 with a Z650 engine and low compression?
The thread suggests this is not just a tuning problem: the white smoke was first suspected to come from injector/fuel issues, but the measured 22–25 bar compression is below the stated 30–32 bar spec and later inspection found cracked first rings, worn liners, and pitting/threshold wear in the sleeve [#18871680] [#18871737] [#18894987] [#18884763] [#18921797] The practical advice was to rebuild the engine properly rather than only replacing rings: fit new liners/sleeves, match new rings to them, renew main and crank bearings, and check/grind the shaft if needed [#18895342] [#18896775] [#18922967] The head should also be serviced with valve-seat work, lapping, new seals/guides, and a new head gasket, while injectors and the pump should be checked or regenerated [#18871680] [#18921797] [#18922967] In the end, the owner reported a full rebuild with sleeve replacement, block planing, bearing replacement, new rings, valve-guide/seal work, milled seats, and a new gasket, after finding usable documentation on Japanese servers [#19614433]
  • #31 20739805
    eltimeltim1
    >>18871680
    Hello, I would be interested in service for the B6000 ZL 600
The discussion revolves around issues faced with a Kubota B7000 tractor, specifically concerning white smoke emission, long cranking times, and low compression in the Z650 engine. Users suggest that the white smoke may be due to injector problems or low compression in one cylinder, indicating potential issues with piston rings or sleeves. The author has performed various maintenance tasks, including adjusting valve clearance and conducting an oil filter service. As the engine is disassembled, users recommend replacing worn components, checking the crankshaft and bushings, and ensuring proper sealing. Documentation for the Z650 engine is sought, with suggestions to refer to similar models for guidance. The conversation highlights the importance of thorough inspection and replacement of critical engine parts to restore functionality.
TL;DR: Kubota Z650 engines need 30-32 bar compression; “22-25 bar is a padaka” [Elektroda, bearq, post #18871737] White smoke usually signals un-burned diesel, not coolant. Rebuild kits (liners, rings, gaskets) cost ≈ €180. Correct glow-plug preheat is 15 s [Elektroda, eksploatacja, post #18871680]
Why it matters: Spotting low compression early prevents ring breakage and expensive crank or liner damage.
• Factory compression: 30–32 bar per cylinder [Elektroda, bearq, post #18871737] • Glow-plug preheat: 15 s before first start [Elektroda, eksploatacja, post #18871680] • Oil capacity: Approx. 3.1 L including filter [Kubota Z650 Manual] • Wet liner price: €40-€50 each, aftermarket [Traktor.com.pl] • Typical full rebuild parts cost: €400-€600 (liners, rings, bearings, gaskets) [Parts Depot EU]
Why does my Kubota B7000 blow white smoke under load?
White smoke on a diesel means fuel is not burning completely. The Z650 often smokes because one injector dribbles or a cylinder has low compression [Elektroda, eksploatacja, post #18871680] Compression below 26 bar reduces combustion temperature, letting raw diesel evaporate in the exhaust [Elektroda, bearq, post #18871737] Check injector spray patterns first, then verify compression.
What compression pressure should the Z650 engine show?
Kubota quotes 30–32 bar on a warm engine at 250 rpm cranking speed [Kubota Z650 Manual]. Readings below 28 bar signal wear; under 24 bar requires overhaul [Elektroda, bearq, post #18871737]
Is 22–25 bar really too low to run?
Yes. At 22 bar, cylinder temperature at top dead centre drops about 15 % versus spec, which delays ignition and causes hard starting [Elektroda, bearq, post #18871737] Engines may still run but will smoke and over-fuel, risking bore glazing.
How long should I heat the glow plugs?
Hold the heater switch for 15 seconds before the first start of the day [Elektroda, eksploatacja, post #18871680] Hot restarts usually require no heating because the pre-chamber stays above 60 °C.
Can I reuse the original pistons after sleeve and ring replacement?
Only if skirt wear is within 0.08 mm and ring-groove clearance under 0.12 mm [Kubota Z650 Manual]. The forum teardown showed intact skirts, so the owner reused them successfully after honing the grooves [Elektroda, Tajfun211, post #19614433]
When must cylinder liners be replaced instead of honed?
Replace wet liners when: 1) a measurable ridge forms (>0.15 mm) [Elektroda, Tajfun211, post #18885616]; 2) pitting is visible; 3) out-of-round exceeds 0.05 mm [Kubota Z650 Manual].
Where can I source liners, rings and gaskets for the Z650?
Options proven in the thread: Traktor.com.pl, Kubota.pl and eBay (aftermarket brands Grant & NPR) [Elektroda, eksploatacja, post #18871680] Complete gasket sets ship EU-wide for €60-€75.
What parts should be replaced during a full rebuild?
Minimum list: liners, rings, main and rod bearings, sleeve bearing, all gaskets, valve guides, seals, pump o-rings, and glow plugs. Check injectors and grind valves [Elektroda, Tajfun211, post #18922897] A worn crank may need 0.25 mm undersize bearings. Edge-case: some Z650 blocks show porous casting; pressure-test before final assembly [Kubota Service Bulletin 82-5].
What’s a quick 3-step check for low compression?
  1. Disable fuel and open throttle.
  2. Fit a diesel compression tester and spin starter for 5 seconds.
  3. Compare readings to 30 bar spec; a 20 % spread between cylinders flags trouble. "Always test hot for accuracy" [Elektroda, eksploatacja, post #18871680]
How should I run-in the engine after rebuilding?
Use 10W-30 break-in oil, start and hold 1 500 rpm for 20 minutes, then load gradually up to 75 % for five hours. Change oil at 10 hours [Kubota Break-In Guide]. Statistic: proper break-in cuts oil consumption by 60 % within 50 hours Kubota Field Data.
What happens if I ignore worn liners and only fit new rings?
New rings in tapered bores contact at the top only, increasing blow-by and doubling oil use within 50 hours [Diesel Power, 2020]. Edge-case: rings may micro-weld, leading to total seizure.
Does the Z650 have a water pump or thermostat?
No. Cooling relies on thermosiphon flow and a whistle alarm on the overflow pipe [Elektroda, Tajfun211, post #18924608] Keep coolant passages clean; sludge cuts flow by up to 30 % Kubota Cooling Study.
How can I get a proper service manual?
The original 120-page Z650 English manual resurfaces on Japanese archive sites; one user merged a printable PDF [Elektroda, pietervanbaekel, post #20603074] Alternatively, the Z482 manual covers identical torque specs for most fasteners.
