Switching from Orange Neostrada to UPC Fiber Optic: ONT and AirPort Router Compatibility
RosOne 4695 2
  • #1 19362741
    RosOne
    I want to give up neostrada from Orange and I am considering fiber optic from UPC.
    I use AirPort as a router in my apartment and I don't want to replace it. I have it connected to an Orange modem. When I call UPC, should I say that I want (demand? need?) ONT from them? UPC routers don't have a bridge option? Is there anything else I need to keep an eye on?
  • #2 19363082
    przeqpiciel
    Help: 285
    Rate: 238
    they have, at least I had such opportunities.
    the question is whether they will actually come to you with light, or simply coaxial or another method of data transmission.
  • Installer supplies ONT and gateway based on network type
    #3 19363611
    KOCUREK1970
    Help: 3861
    Rate: 5489
    It all depends on how your backbone network is built:
    - coaxial cable to the apartment from the optical NOD in front of the block,
    - via GPON as light to the apartment,
    - via RFoG as light for the apartment, if you want TV via DVB-C or CI+ module
    There are other possibilities, but it depends on what services you choose and how the network is built on the backbone.
    Cable modem routers have a modem mode, for FTTH with ONT you will get an ONT and a Compal GW7557CE router assigned to it by the operator (I'm afraid you won't replace it, because you won't get data for the service, anyway, there are other dependencies that such a set must remain).
    You can mark whatever you want, but the installer will bring what he has in stock for a specific frame service.
