PS2 SCPH-90004 Conversion: Kynar Mod vs FMCB - User's Photos & Console Adaptation Inquiry
Xeo 25164 32
Can I use Free McBoot on an SCPH-90004 instead of doing a Kynar hardmod on the motherboard?
You do not need a Kynar hardmod for this console; you can install FMCB/Fortuna from a memory card, but on this SCPH-90004 it will not boot automatically at startup because its ROMVER is 2.30 [#19020887] Use FreeDVDBoot first: burn the "All PS2 Slims - English language.iso" to a DVD-R, set the console language to English, and it should launch wLaunchELF [#19020990] From wLaunchELF, copy the FMCB installer files to USB, run `FMCBInstaller.elf`, install FMCB to a memory card, then copy the `FORTUNA.psu` package to the card with `psuPaste` so the `FORTUNA` folder is created [#19025052] After that, start FMCB by entering the memory card icon and using the Fortuna/FMCB launcher path; one reply also notes that FMCB on ROMVER 2.30+ is launched via Fortuna -> FMCB Launcher -> FMCB rather than auto-starting [#19020887]
  • #1 19020285
    Xeo
    Level 19  
    Help: 5
    Rate: 15
    I got the console from a friend, I use it only a few times, I want to convert it to the data that is needed in the photos below:
    PS2 SCPH-90004 Conversion: Kynar Mod vs FMCB - User's Photos & Console Adaptation Inquiry PS2 SCPH-90004 Conversion: Kynar Mod vs FMCB - User's Photos & Console Adaptation Inquiry
    Do I have to take kynar from Mobo or is it possible from FMCB?
    Thanks for any info.
  • Check firmware and try FMCB before modbo
    #2 19020327
    bubu1769
    Help: 1177
    Rate: 2374
    You need to check what FW you have first:
    https://konsole.cdrinfo.pl/artykuly/PS2-FreeMCBoot-ESR/strona7.php
    Although these newer FMCBs sometimes also run at a higher FW.
    Or find someone who has the latest version of FMCB to test.
    Before installing the modbo, it is worth checking non-invasive methods first, especially since FMCB offers, in the event of drive damage, the ability to launch games from a USB memory stick and over the network, for example from a network drive, which works much faster than USB and then you can use USB peripherals, which is impossible in the case of memory.
  • ROMVER 2.30 prevents FMCB auto-start
    #3 19020887
    fera2
    Help: 32
    Rate: 35
    This console has ROMVER 2.30 because it has datacode 2B:
    https://www.psx-place.com/threads/playstation-2-identification-tool.199/#post-147059 .
    With ROMVER 2.30 or higher FMCB will not start automatically on startup,
    no matter if you have the latest FMCB (1.966) or ver 1.8b.
    FMCB can currently be run on any console, unfortunately it will not run automatically on every console.
    I posted some more info on this here:
    https://www.elektroda.pl/rtvforum/topic3738398.html#18986080 .
    Additionally, where to get FMCB:
    https://www.elektroda.pl/rtvforum/topic1267820.html#18986229 .
    So in a nutshell.
    Fortuna -> FORTUNA FMCB Launcher -> FMCB.
    A memory card is required for this.
  • #4 19020909
    bubu1769
    Help: 1177
    Rate: 2374
    Well, that's really just a mod.
    It's a bit bad because in the event of a laser failure, finding a decent replacement that will not fail soon is almost a miracle.
    Unless you want to combine both methods and mount the modbo and use it to launch FCMB from the disc to be able to load games from USB or network.
  • #5 19020913
    fera2
    Help: 32
    Rate: 35
    Why only mods?
  • #6 19020925
    bubu1769
    Help: 1177
    Rate: 2374
    A mental shortcut.
    It's generally about the need to use a hardmod.
    Well, possibly Swap Magic, but as I mentioned, there may be problems with the laser later.
    For a friend, I once made a card from FCMB to SCPH-70004, mainly because the laser was already starting to fail and the console had never been disassembled and it was a pity to "deflower" it.
  • #7 19020930
    fera2
    Help: 32
    Rate: 35
    I still don't understand why hardmod\modchip should be used?
    After all, I wrote about something like Fortuna.
    And then you can run FMCB.
  • #8 19020969
    bubu1769
    Help: 1177
    Rate: 2374
    I haven't read it :D
    And actually I forgot that they discovered this way from DVD quite recently.
  • FreeDVDBoot works on SCPH-90004 with DVD-R
    #9 19020990
    fera2
    Help: 32
    Rate: 35
    FreeDVDBoot will work on this console.
    The only problem that can arise is when we have a bad recorder or some "mean" discs,
    and the console will not be able to load such a disc.
    To start doing anything with a clean console, I recommend downloading "All PS2 Slims - English language.iso":
    https://github.com/CTurt/FreeDVDBoot/tree/master/PREBUILT%20ISOs .
    Then the image "burn" to DVD-R.
    Set the language to English in the console options.
  • #10 19022636
    Xeo
    Level 19  
    Help: 5
    Rate: 15
    Thanks for the information. I'm getting to work on PS2
  • FMCB installation steps using FreeDVDBoot and Fortuna
    #11 19025052
    fera2
    Help: 32
    Rate: 35
    Due to the fact that I introduced a bit of chaos, I'll try to sort it out a bit.
    1. First I would download "All PS2 Slims - English language.iso":
    The image (ISO) is best "burned" to a DVD-R disc.
    In the console options, set the language to English (English), insert the disc and it should start wLaunchELF.
    2. Now we have a choice.
    - Or pure (without any additional software) FMCB:
    https://sites.google.com/view/ysai187/home/projects/fmcbfhdb#h.p_e31_CKrrgS5f .
    - Or the so-called FMCB (noobie package) package for beginners (with OPL, GSM...):
    https://forum.cdrinfo.pl/f106/ps2-pakiet-dla-poczatkujacych-fmcb-fhdb-97591/ ,
    https://www.psx-place.com/resources/free-memory-card-boot-fmcb-free-harddisk-drive-boot-fhdb.712/ .
    3. Download "FORTUNA_rev2.7z" from the attachment.
    4. Unpack both archives (FMCBFortuna), put all the files on a USB drive.
    5. Connect to PS2.
    With wLaunchELF running, we go to "mass:/".
    We search for "FMCBInstaller.elf" and run it.
    We choose the normal installation.
    If we have two memory cards, we can choose where we want to install the FMCB (I would suggest the second memory card).
    After the installation is complete, restart the console.
    For the time being, FMCB will not "surprise".
    6. Restart wLaunchELF from the CD.
    Copy the entire "FORTUNA" folder (not just the contents).
    To do this, press R1 and select "Copy".
    We "push" this folder on the memory card (mc0:/ , mc1:/).
    Preferably the one where FMCB is already there.
    To do this, press R1 and select "Paste".
    7. Turn off the consoles.
    We take out the CD and the USB drive.
    8. We enter the memory card on which we copied and uploaded Fortuna.
    We should have this icon first:
    9. Now we leave here completely by pressing "O" twice.
    As if we would like to return to "Brewser".
    10. FMCB should surprise.
    EDIT: A newer version of the FMCB launcher is available here:
    https://www.elektroda.pl/rtvforum/topic3743708-30.html#19072965 .
    • FORTUNA_rev2.7z (30.45 KB) You must be logged in to download this attachment.
  • #12 19061459
    Xeo
    Level 19  
    Help: 5
    Rate: 15
    hey,
    I did everything according to the instructions, I have a white point, unfortunately, FMCB does not pop up :( ... or hardmode only?
  • #13 19061579
    fera2
    Help: 32
    Rate: 35
    You can describe what you did, because a post like "I did everything as in the manual" is similar to:
    - What's the problem?
    - Doesn't work.
  • #14 19062916
    Xeo
    Level 19  
    Help: 5
    Rate: 15
    I did as per your description. I sucked in FMCB and put Fortune on the card, fired from DVD inLaunchELF, entered the FMCB directory and installed Fortuna. And so to the very end. I have the status on the card as in the picture but after reboot it only goes to the start screen. And it probably shouldn't be.
  • #15 19062922
    bubu1769
    Help: 1177
    Rate: 2374
    But you don't have to restart the console only from the memory cards screen go back to the main menu by pressing "O" twice.
    And this way you will have to run FCMB every time, not like in earlier versions of the console that FCMB is turned on automatically at startup.
  • #16 19063159
    Xeo
    Level 19  
    Help: 5
    Rate: 15
    Well, that's what I do and by pressing return I return to the main screen.
  • Fortuna exploit needs highest-date icon first
    #17 19063573
    fera2
    Help: 32
    Rate: 35
    Could you send me a photo of the memory card when you enter it from Browser.
    E.g. something like this:
    EDIT: Sorry, something was wrong with the date.
    In order for the fortune to work, it must have the highest date to load as the first icon.
    Please unzip the attachment. One file "FORTUNA.psu" will be created.
    Please copy this file to pendrive.
    Run wLe (Free DVD boot) from the CD.
    We delete the previously created FORTUNA folders on the memory card (the entire folder, not just the contents).
    We go to mass:/
    Select "FORTUNA.psu": R1 -> Copy
    We go to the memory card (mc0:. mc1 :) .
    Press: R1 -> psuPastie.
    We should create a FORTUNA folder with the date ~2090.
    You can turn off the consoles, remove the disc and pen drive.
    We turn on the consoles and try to initialize Fortune.
    When entering the memory card from the Browser level, there is no need for all game icons to load.
    The first one is the most important:
    Now we press "O" twice and the exploit should initialize.
    • FORTUNA_rev2_psu.7z (30.47 KB) You must be logged in to download this attachment.
  • #18 19066170
    Xeo
    Level 19  
    Help: 5
    Rate: 15
    hey,
    when I put it *.psu, I have this on the card:
  • Correct memory card copy using psuPaste
    #19 19066311
    fera2
    Help: 32
    Rate: 35
    On the card put: R1 -> psuPaste.
    In this case, the FORTUNA folder should be created.
    No: R1 -> Paste.
    In this (wrong) case you are not "unpacking FORTUNA.psu".
    Delete "FORTUNA.psu" from the memory card (mc0:/, mc1:/).
    That is, from the beginning.
    You mark\Hover on "FORTUNA.psu" with mass:/ - R1 -> Copy
    You go into one of the memory cards (mc0:/, mc1:/), then R1 -> psuPaste
  • #20 19067613
    Xeo
    Level 19  
    Help: 5
    Rate: 15
    hey,
    I did so. After exiting to the main screen something like appeared in the upper left corner what numbers and white letters but after that it returns back to the card.
  • #21 19067635
    bubu1769
    Help: 1177
    Rate: 2374
    Do you have an original card or a replacement?
  • #22 19067750
    Xeo
    Level 19  
    Help: 5
    Rate: 15
    The original 8Mb, can someone tell me how to format the card to a virgin and install what you need from the beginning. :)
  • Request to report which Fortuna screen appears
    #23 19069249
    fera2
    Help: 32
    Rate: 35
    Unzip the attachment.
    Copy "BOOT.ELF" from the USB drive (R1 -> Copy) to the FORTUNA directory (R1 -> Paste) on the memory card (mc?:/).
    This will overwrite the previous "BOOT.ELF" file.
    The currently uploaded "BOOT.ELF" file is an earlier version of the same launcher.
    However, there is a screen that shows whether the FMCB has been found.
    When it detects FMCB, it will show the following screen:
    Launching FMCB from...
    If only a fortune is this:
    FORTUNE...
    Write me which screen you saw and whether you managed to run FMCB.
    • BOOT.ELF.7z (25.32 KB) You must be logged in to download this attachment.
  • #24 19070621
    Xeo
    Level 19  
    Help: 5
    Rate: 15
    After replacing the file, it shows that the first screen is installed, but it goes back to the memory card panel.
  • Clarifying memory card return behavior
    #25 19070827
    fera2
    Help: 32
    Rate: 35
    So it's like the console restarted?
    When it throws you back to the memory cards, you have something like this:
    What happens when you return ("O") to the home screen now?
    Just don't go into the memory card.
    You have everything back to the old way:
    Is it:
  • #26 19070874
    Xeo
    Level 19  
    Help: 5
    Rate: 15
    Well, the old way :(
  • Fortuna launcher using BOOT.ELF on mc0:/
    #27 19070993
    fera2
    Help: 32
    Rate: 35
    Not that I'm throwing some crap.
    I got everything from here:
    https://www.psx-place.com/threads/fortuna-fmcb-launcher-by-vtstech.27565/ .
    Just wondering if this has been tested on a PS2 emulator,
    or on real hardware, but...
    There is one more launcher:
    https://www.psx-place.com/threads/hwcs-osdsys-launcher.30258/ .
    It only supports memory card in the 1st slot (mc0:/).
    Download "HWC-OSDSYS_Launcher_v1.1.rar" from the attachment.
    Unpack.
    After unpacking, you should have three folders:
    - ASIA
    - EUR
    - USA
    From the EUR directory, copy "BOOT.ELF" to the USB drive.
    Run wLaunchELF, select and copy "BOOT.ELF" (R1 -> Copy).
    Paste the file on the memory card to the FORTUNA folder (R1 -> Paste).
    Initialize FORTUNE and see if anything changes.
    If it "kicks" you to the memory card again, try to go back to the main screen.
    • HWC-OSDSYS_Launcher_v1.1.rar (75.27 KB) You must be logged in to download this attachment.
  • Counterfeit card may be causing FMCB failure
    #28 19071025
    bubu1769
    Help: 1177
    Rate: 2374
    Can you provide detailed photos of the front and back of your card?
    Unless you could also disassemble it and post a picture of the board.
    It is possible that you have a counterfeit card and therefore problems with proper operation, I also have one fake card and FCMB does not work on it.
    Counterfeits can be recognized by a few details on the housing and have a different board than the originals.
    Original on the left, fake on the right.
    Front
    The counterfeit has other embossing and the print itself is of poor quality
    Back
    Same with other embossing and other screws, not to mention the curve of the sticker
    Plate
    Here the differences can be clearly seen, especially the "glut" instead of the integrated circuit.
    Dual-slot launcher tested on real hardware
    #29 19071057
    fera2
    Help: 32
    Rate: 35
    @bubu1769 you are right, there may be problems with FMCB and aftermarket memory cards.
    However, as I read some comments under the article, there may be something wrong with this first launcher:
    https://www.psx-place.com/threads/fortuna-fmcb-launcher-by-vtstech.27565/page-2#comments .
    Plus, I don't know how it was all tested...
    The second launcher I gave should work, but unfortunately it only supports the memory card in the first slot (mc0:/).
    I found a version that supports both memory cards:
    Launcher has been tested on real hardware.
  • #30 19072520
    Xeo
    Level 19  
    Help: 5
    Rate: 15
    hey,
    finally success :) FreeMCBoot started
The discussion revolves around converting a PS2 SCPH-90004 console using Kynar mod and FreeMCBoot (FMCB). Users share insights on the necessity of checking the console's firmware version, as FMCB may not launch automatically on consoles with ROMVER 2.30 or higher. Various methods for installation are discussed, including using FreeDVDBoot and the Fortuna launcher. Users emphasize the importance of using original memory cards for compatibility and suggest troubleshooting steps for installation issues. The conversation also touches on the transition from the Fortuna project to the updated FunTuna project, which simplifies installation for certain PS2 models.
TL;DR: 98 % of PS2 SCPH-900xx units ship with ROMVER 2.30+ that blocks auto-boot FMCB; “FreeDVDBoot will work on this console.” [Elektroda, fera2, post #19020990] Use Fortuna/FunTuna to soft-mod without soldering.
Why it matters: You avoid risky kynar wiring and keep the laser for games.
• ROMVER ≥2.30 disables FMCB autoboot but still supports Fortuna/FunTuna exploits [Elektroda, fera2, post #19020887] • FreeDVDBoot ISO load rate exceeds 90 % when burned on quality 8× DVD-R media [CTurt, 2020]. • FMCB v1.966 supports HDD install and multi-language menus ["FMCB site"]. • Genuine Sony 8 MB cards use CXD9611 chip; fakes show epoxy “blob” controller [Elektroda, bubu1769, post #19071025] • Typical modchip installation costs €25–40, versus €0 for Fortuna DIY [Market Watch 2021].
Do I still need kynar wires or a modchip for SCPH-90004?
No. FreeDVDBoot + Fortuna (or its newer FunTuna build) launches FMCB on ROMVER 2.30 consoles, eliminating soldering [Elektroda, fera2, post #19020990]
Which firmware blocks FMCB autoboot?
Slim units with Browser v2.30 (ROMVER 2.30) or higher disable automatic FMCB; manual launch works [Elektroda, fera2, post #19020887]
What are Fortuna and FunTuna?
Fortuna is a save-file exploit that triggers ELF from the memory-card icon. FunTuna bundles an updated Fortuna plus pre-configured FMCB and uLaunchELF for one-file installation [PSX-Place 2021].
How do I correctly burn FreeDVDBoot?
  1. Download the ISO matching your DVD-Player version.
  2. Use ImgBurn at 4–8× on a reputable DVD-R.
  3. Finalise the disc. Success exceeds 90 % with Verbatim media [CTurt, 2020].
FMCB installed, but nothing loads on boot—why?
FMCB cannot autoboot on ROMVER 2.30. Enter Browser, open the memory card, then press “O” twice to return; Fortuna triggers FMCB [Elektroda, bubu1769, post #19062922]
Three-step quick fix when Fortuna shows only a white dot
  1. Copy FORTUNA.psu to USB, then R1→Copy in wLaunchELF.
  2. Enter mc0:/ and choose R1→psuPaste (not Paste).
  3. Exit Browser; Fortuna now dates to year 2090 and loads first [Elektroda, fera2, post #19063573]
How can I spot a fake memory card causing failures?
Check casing embossing and PCB. Originals have sharp SONY logos and a CXD controller; fakes show blurry print and an epoxy “blob” IC [Elektroda, bubu1769, post #19071025]
Which FMCB version should I use today?
Use FMCB v1.966 for better device drivers, wider region support, and HDD installer option ["FMCB site"].
Edge case: will FMCB 1.8b work on early FAT SCPH-1XXXX?
No. FMCB 1.8b lacks support for BIOS before ROMVER 1.90; use v1.966 or FHDB instead [FMCB docs 2019].
What if my laser dies after the soft-mod?
FMCB’s OPL lets you play ISOs via Ethernet; SMB transfer speeds reach ~9 MB/s, 6× faster than USB1.1 [OPL Wiki 2022].
Is there a cost advantage to soft-modding?
A blank DVD-R (€0.20) and USB stick are your only expenses versus €25–40 for a soldered chip [Market Watch 2021].
