[Solved] Motus scooty 10 - settings - Settings - How to run
hynio82 43683 8
  • #1 19042922
    hynio82
    Hello. Does anyone know how to enter the settings of the Motus Scooty 10 scooter??
    Regards
  • #2 19067254
    Pontikos
    Help: 321
    Rate: 1007
    Probably the easiest way is ST-link to the controller or display, because it will not connect after BT. But for this you would have to translate a bit from the programming side to modify something.
    The question is what and for what purpose do you want to modify?
    Do you want to kill yourself on such a construction, braking from a speed of 40 km / h, and with a front drum brake???
  • #3 19095489
    tlc76
    Rate: 14
    Has anyone tried to replace the Scooty 10 display with a Ninebot Max G30 one, which has the bluetooth function?
    There's a lot available on aliexpress at around $15-$20.
    I am not allowed (yet) to post URLs, so please go to aliexpress site and search "ninebot max g30 board" to see what I'm talking about.
    Thanks
  • #4 19321472
    Carlos20
    Rate: 27
    Hello, I am repeating the topic, no one has any idea how to turn up this scooter??
  • #5 19474570
    Dieguu
    Rate: 29
    I am looking for technical and service assistance, I need to turn off the cruise control in Motus 10
  • #6 19480542
    jarroQ
    Help: 170
    Rate: 629
    Provide markings or post a photo of the engine controller.
  • #7 19535729
    rob.swiderski
    Rate: 31
    Does anyone know how to upgrade Scooty 10 from 2020 to 2021? What element of the scooter is responsible for this? I would like to turn on the 35 km/h allowed by the 2021 vintage. Mechanically, the scooters have the same engine power.
  • #8 19619848
    johan7210
    Motus 10 from 2021 has a different display, controller and engine.
    If you want to get these 35 km/h, you need to replace at least the first two elements
  • Motus pro settings and safe parameter changes
    #9 19923965
    pkkcracovia
    I have a description for 10 pro - check maybe similarly:
    How to change parameters in Motus PRO electric scooters?
    Factory settings in electric scooters allow you to use the equipment safely and in accordance with the manufacturer's instructions. However, more demanding users may care about adjusting the parameters to their own driving style. That is why we suggest how to change the parameters in Motus PRO electric scooters (8.5, 10, 10 Sport).
    How to change parameters in 3 easy steps
    1. With the display on, press the POWER and MODE buttons at the same time (for about 2-3 seconds).
    2. To change the programs, press the POWER button (in this way, we go through the next functions - from P01 to P20).
    3. The values of the program data can be changed by pressing the MODE button (until the expected parameter value is obtained).
    Remember that after a period of inactivity (about 3-4 seconds), the display will automatically return to the home screen. To re-enter the settings, go back to step 1.
    Which parameters can be changed?
    Please note that not all parameters can be changed! It's extremely important. Some values should remain in their original state. Otherwise, the device may be damaged.
    Factory settings for Motus Motus PRO10, PRO10 Sport and PRO8.5 scooters are presented as Pxx-xxx, where "Pxx" is the parameter number and "xxx" is its value (below showing factory settings).
    Features that can be safely customized include:
    P01-003: Display Backlight Brightness (scale 1-3) - Factory Default for All Models: 2
    P02-000: Unit of measurement km/mile (0-km, 1-mile) - factory setting: km
    P04-005: Automatic shutdown timer (range: 1-15 seconds, Motus PRO10 Sport 1-60 seconds) - factory default: 5
    P08-100: Power limit, scale from 25% to 100% - factory default: 100%
    P09-000: Zero start/push start (0 - zero start, 1 - push back start) - factory default: 0
    P11-001: Electric Brake, Scale 1 to 5 - Factory Default: 1
    P12-003: Acceleration, scale 1 to 5 - factory default: 3
    P17-000: Cruise Control (1 - Enabled, 0 - Disabled) - Factory Default: 0
    There are also functions that are not used (P05, P10, P13, P14, P18, P19, P20). On the other hand, parameters such as voltage, wheel diameter, number of magnets in the motor, or ODO zeroing should not be adjusted by yourself! Otherwise, it may have a negative impact on your scooters.
    Remember that you make any changes at your own risk, and the producers are not responsible for incorrect settings made by users!
The discussion revolves around accessing and modifying the settings of the Motus Scooty 10 scooter. Users inquire about entering the settings, turning off cruise control, and upgrading the scooter from the 2020 to 2021 model to achieve a higher speed limit of 35 km/h. Suggestions include using an ST-link to connect to the controller or display for modifications, and replacing components such as the display and controller to enable the desired speed. A detailed method for changing parameters in Motus PRO electric scooters is also provided, which may be applicable to the Scooty 10.
