Xiaomi MI Pro 2 (2022) - Unlocking Speed Limit to 25km/h: How to Bypass/Unlock Scooter Restrictions
Kacpii12 50403 11
Can I unlock a 2022 Xiaomi Mi Pro 2 to 25 km/h, and what workaround is used on newer scooters?
Yes, but on newer Xiaomi Pro 2 units it is often no longer a simple software-only unlock. One suggested method is to replace the motor controller/DRV with one running Pro1 software, but other users report that newer PRO2 controllers can throw e27/E35 and may block the controller, so a basic ST-Link attempt can fail [#20083364][#20107588] A more advanced approach reported as working is swapping/programming the MCU in the DRV or replacing it with an MCU from another board after transitions, which requires more equipment than ST-LINK [#20107657] Another report says that for Pro2 controller v3.0 and above it is impossible without a programmer, and a 2021 Pro2 with controller v3.1 would not accept unlocking in Xiaoflasher [#20551172][#20734471]
Treść zostaÅ‚a przetÅ‚umaczona polish » english Zobacz oryginalnÄ… wersjÄ™ tematu
  • #1 20081460
    Kacpii12
    Hello, I have a question, namely I plan to buy Xiaomi MI Pro 2 from 2022, and from what I've heard with newer scooters from Xiaomi it's a problem to unlock them up to 25km. Unfortunately, I do not know if this is true, so I would like to make sure and if there is a way around it, I would like to ask for instructions on how to bypass / unlock it?
  • #2 20083364
    jarroQ
    Help: 170
    Rate: 629
    I didn't know what the name extension with NE means, but if they are any design corrections or equipment additions, the unlocking method is the same as in PRO2.
    The fastest way is to replace the motor controller (DRV) in the platform with one with software from Pro1.
  • Pro-2 unlocking can brick the controller
    #3 20107588
    Pontikos
    Help: 321
    Rate: 1007
    Buddy Jarroq - don't write if you don't know, your advice is HARMFUL!
    Unfortunately, the approach to PRO-2, as to PRO, ends with an invariable message e27 and E35 - then often even ST-link no longer sees the controller and in no way can it be moved!
    Of course, unlocking the PRO-2 is still fully possible, but it requires a bit more knowledge and experience.
    To start at all, you should prepare a second dashboard, preferably the one from m365
    If I remember correctly, new dashboards send a compatibility bit to the controller, if it is incorrect, it blocks the controller.
    The second thing is that the drivers of the A and B series behave differently ;-)
  • Replacing blocked DRV MCU to bypass scooter limits
    #4 20107657
    jarroQ
    Help: 170
    Rate: 629
    Did Pontiko get stuck on something like that? I give advice based on my knowledge and experience.
    I haven't come across any bit of compatibility so far.
    I made maybe 10pcs PRO2 with my "harmful" method and they drive without a problem. And this on the latest BLE update without any BLE modification.
    As the MCU in the DRV is blocked, I just replace it with a new one and program it or replace the MCU from another board "after transitions".
    Error 27 on an unlocked MCU is just a piece of cake and is not a problem for me. Like BMS errors 21, 22 and 23.
    You just need to have a little more knowledge and have more equipment than just ST-LINK.
  • #5 20143683
    marcinks2
    Rate: 102
    I am interested in modifying the mi pro2 tz to increase the speed.
  • #6 20275201
    wojcikmichal978
    Level 4  
    Buy a display from Allegro for PLN 100.
    It helped me. I was looking for a solution for half a year on how to unlock the Xiaomi Mi Pro 2 scooter. If you want to not lose the warranty, then keep the original display. If the warranty is necessary, then you change the display to the original and restore it to factory settings in the Mi Home application.
  • Controller must be Pro 2 V3.0 for xiao365 unlock
    #7 20551172
    Maro6950
    Rate: 9
    Replace the steering wheel even with xiao365 but first you need to change the softa in 365 because it will not communicate with your controller and the important thing is that you must have the controller in pro2 V3.0 above it is impossible without the programmer. I modded mine and even 4 jets went empty under load 36 -35 flies normally. That’s it and the rest is up to you what you do with this message. And those who make secrets from it count on money from those without proper knowledge. Good luck and wisdom on the path. Increase the battery capacity because it discharges 2 times faster 😀
  • Counterfeit displays may not program at all
    #8 20553175
    jarroQ
    Help: 170
    Rate: 629
    Maro6950 wrote:
    I modded mine and even 4 nozzles went empty under load 36-35 flies normally.
    It's all about playing with the currents... :) As long as you don't fry the engine.
    Unlikely at present. For PLN 100 you can buy a blocked or clone that does not program at all because it has non-factory counterfeit soft.
  • #9 20553477
    Maro6950
    Rate: 9
    the engine is not even warmer than the tires after 8km. The son of a good softa threw it and it's ok, in the pro two there is a 600watt engine so it can withstand it without any problems
  • Motor can handle 10–20% current increase safely
    #10 20553487
    jarroQ
    Help: 170
    Rate: 629
    600W yes, but it's not continuous power. The motor housing is much cooler than the stator. It really doesn't take much to lead to the situation as in the picture above. The current can be increased by 10-20% without any problem. However, if we increase the current by 40%, we already fry the insulation.
  • #11 20561262
    kaniu1500
    Jarroq and how much does such pleasure cost? Just out of curiosity :)
  • Controller v3.1 blocks DRV downgrade attempts
    #12 20734471
    mkika84
    Is it possible for someone to further develop a way to unlock a scooter with a replacement handlebar? I have a pro2 scooter from 2020, which is unlocked, and I am trying to unlock the same model from 2021. I purchased the xiaoflasher program, but unfortunately the driver does not want to accept the unlocking.
    From what I remember at the moment, it looks like this:
    DRV: 2.4.8 BMS: 1.4.1 BLE: 1.5.7 and I cannot change the drv to a lower one.
    Edit: I disassembled the platform today and unfortunately the controller is v3.1.
The discussion revolves around unlocking the speed limit of the Xiaomi MI Pro 2 (2022) scooter to 25 km/h. Users share various methods to bypass restrictions, including replacing the motor controller (DRV) with one from the Pro 1 model, and using alternative dashboards. Some participants caution that unlocking the Pro 2 requires advanced knowledge and experience, as newer models may present compatibility issues that can lead to error messages. Suggestions include purchasing a compatible display and modifying the software, while also noting the importance of maintaining the original display to preserve warranty. The conversation highlights the need for specific tools and knowledge to successfully unlock the scooter without damaging components.
TL;DR: Modders report 10 successful PRO2 unlocks; "You just need to have a little more knowledge and have more equipment than just ST-LINK." Unlocking is doable via controller or dashboard swaps, but firmware/MCU locks complicate it. [Elektroda, jarroQ, post #20107657]
Why it matters: This FAQ helps Xiaomi Mi Pro 2 owners reach 25 km/h by choosing safe, workable unlock paths.
Can I unlock a Xiaomi Mi Pro 2 (2022) to 25 km/h?
Yes. Treat NE or 2022 revisions like the standard PRO2. The quickest route is replacing the motor controller (DRV) with one running Pro1 software. This mirrors the known PRO2 approach. Verify compatibility before purchasing parts or flashing. [Elektroda, jarroQ, post #20083364]
Why do I get E27/E35 after flashing, and what does it break?
E27/E35 often appear when you treat PRO2 like older PRO units. The controller can then lock, and ST‑Link may stop detecting it. Prepare a second dashboard first to avoid compatibility blocks. Note that A‑series and B‑series controllers behave differently. [Elektroda, Pontikos, post #20107588]
How do I unlock using a second dashboard (m365)?
Use this handlebar swap method:
  1. Prepare a second dashboard (e.g., m365) to avoid compatibility locks.
  2. Install it temporarily and ensure the controller handshakes correctly.
  3. Perform your changes, then restore the original dashboard if desired. [Elektroda, Pontikos, post #20107588]
Do I need a BLE mod on the latest firmware to unlock?
Not always. Some have unlocked multiple PRO2 units on the latest BLE without any BLE modification. That approach focused on controller-level work rather than BLE patches. "I made maybe 10pcs PRO2... on the latest BLE update without any BLE modification." [Elektroda, jarroQ, post #20107657]
How can I avoid warranty issues when swapping displays?
Use a spare display for unlocking and keep the original stored. If you need warranty service later, reinstall the original display and restore factory settings in the Mi Home app. This preserves the stock appearance. [Elektroda, wojcikmichal978, post #20275201]
Are PLN 100 dashboards from Allegro reliable for modding?
Be cautious. Units around PLN 100 are often blocked or clones and refuse programming. Budget for a genuine, programmable dashboard if you plan to modify firmware. Low-cost clones can stall your project. [Elektroda, jarroQ, post #20553175]
Is unlocking possible on a V3.1 controller without a programmer?
No. Above V3.0, unlocking without a hardware programmer is not possible. Consider a programmer or a compatible hardware swap if your controller is V3.1. App-only methods will not suffice here. [Elektroda, Maro6950, post #20551172]
Why did Xiaoflasher fail to downgrade DRV 2.4.8 with BLE 1.5.7?
A user with a V3.1 controller reported that Xiaoflasher did not change DRV 2.4.8, and downgrading failed. This reflects firmware and controller protections on that hardware revision. [Elektroda, mkika84, post #20734471]
Do A‑series and B‑series PRO2 controllers unlock differently?
Yes. A‑series and B‑series controllers behave differently during unlocking. Plan your approach accordingly and prepare a second dashboard to handle compatibility checks. Skipping this step can trigger lockouts. [Elektroda, Pontikos, post #20107588]
How far can I increase current safely without cooking the motor?
Keep increases conservative. "The current can be increased by 10–20% without any problem." Pushing roughly +40% risks frying the motor insulation. Monitor temperatures and avoid long sustained overloads to protect the stator. [Elektroda, jarroQ, post #20553487]
What tools do I need beyond ST‑Link?
Expect more than ST‑Link for difficult cases. If the DRV MCU blocks access, experts replace the MCU and program it or transplant one from a donor board. "You just need to have a little more knowledge and have more equipment than just ST‑LINK." [Elektroda, jarroQ, post #20107657]
Will an m365 handlebar/dashboard work plug‑and‑play on PRO2?
Not without prep. First, change the software on the m365 dashboard; otherwise it will not communicate with your PRO2 controller. Also ensure your controller is V3.0 if you aim to avoid using a programmer. [Elektroda, Maro6950, post #20551172]
How much faster will the battery drain after a power mod?
Expect noticeably higher consumption. One modder reports the battery "discharges 2 times faster" after increasing performance. Plan for capacity upgrades if you extend current limits for speed or torque. [Elektroda, Maro6950, post #20551172]
What power is the PRO2 motor, and does that help with headroom?
The PRO2 uses a 600 W motor according to user reports. One rider noted the motor stayed cooler than the tires after 8 km in their setup. Always validate thermals on your unit after any power increase. [Elektroda, Maro6950, post #20553477]
ST‑Link stopped seeing the controller after errors — what happened?
This can follow E27/E35 lockouts caused by treating the PRO2 like the older PRO. The controller may hard‑block communication afterward. Avoid this by using a compatible dashboard first to pass the handshake. [Elektroda, Pontikos, post #20107588]
How do experts recover a blocked DRV MCU?
They replace the DRV’s MCU with a new one and program it, or transplant a compatible MCU from another board. This bypasses locks that resist standard flashing and clears error states like E27. [Elektroda, jarroQ, post #20107657]
