How to Remove Speed Lock on Xiaomi Mi Electric Scooter 3 After Update?
piolabecki 30543 9
How can I remove the speed limit on a Xiaomi Mi Electric Scooter 3 after updating it in Xiaomi Home?
After the Xiaomi Home update, the practical method mentioned is hardware replacement: if BLE is locked, swap the DRV/controller for an older one prepared for custom software, or use a v3.0 controller; one user says that setup reaches 36 km/h [#20166166][#20125742] Another reply says the Mi Electric Scooter 3 is the latest model and that custom software or generators for it have not yet been developed, so a normal firmware unlock may not be available yet [#20082313] There is also a claim that unlocking newer Xiaomi scooters is still possible without generators or special software, but no procedure was given [#20107591]
  • Firmware update likely blocked scooter speed unlock
    #1 20082239
    piolabecki
    I purchased a Xiaomi Mi Electric Scooter 3, I wanted to remove the speed lock by uploading a different soft,
    I tried through several apps such as XiaoFlesher, downG and ScooterHacking, but none of them uploaded the new soft.
    I have done a software update in the Xiaomi Home app, which is probably the cause of the problem.
    Is there any way to undo the update?
    I also tried to do a BLE downgrade from 1.5.5 to version 0.7.2, but this also had no effect.
    Is there any other way to remove the speed lock?
  • #2 20082313
    Dziarski Hank
    Help: 246
    Rate: 934
    You have the latest model for which, as you can see, custom softwares have not yet been developed, much less generators.
  • #3 20107591
    Pontikos
    Help: 321
    Rate: 1007
    Neither generators nor special softwares are needed.
    All you need is a little knowledge, and unlocking new Xiaomi is still fully possible, e.g. How to Remove Speed Lock on Xiaomi Mi Electric Scooter 3 After Update?
  • #4 20107884
    Dziarski Hank
    Help: 246
    Rate: 934
    Nice. Which version is it? How much will it pull on the straight with an average weight driver?
  • #5 20111916
    kbrochocki
    Rate: 18
    The topic seems to have died, I'm curious to know how to do it myself because that 20 km is a bit short....
  • #6 20125733
    skoniuszy
    Rate: 9
    Pontikos, will you say how you did it?
  • #7 20125742
    kbrochocki
    Rate: 18
    Get yourself a v3.0 controller, which is what I did and it runs at 36 km/h.
  • #8 20147908
    piolabecki
    Pontikos how about a hint?
  • #9 20162459
    Rol3k
    I am also curious, I have owned this scooter for some time and the maximum speed is 20 km/h, can it somehow be increased to at least 25 km/h?
  • #10 20166166
    jarroQ
    Help: 170
    Rate: 629
    If you have BLE locked then the quickest way is to replace the DRV with an older one with SW prepared accordingly.
    Preferably one with a high SW number so that accidentally plugging in the Xiaomi app doesn't upgrade to the latest legal version.
The discussion revolves around removing the speed lock on the Xiaomi Mi Electric Scooter 3 after a software update. Users report difficulties in uploading custom firmware using various applications like XiaoFlesher, downG, and ScooterHacking, likely due to the latest software update from the Xiaomi Home app. Suggestions include obtaining a v3.0 controller to achieve higher speeds (up to 36 km/h) and replacing the DRV with an older version that has compatible software to avoid automatic updates. The conversation highlights the need for specific knowledge and components to successfully unlock the scooter's speed limit.
