[Solved] Zigbee Input Module for Home Assistant: Recommendations for Digital Inputs
ducker1 4158 8
  • Request for a Zigbee module with digital inputs
    #1 19045040
    ducker1
    Help: 69
    Rate: 83
    Good morning.
    I am planning to build a home automation based on a zigbee gateway and control with Home Assistant.
    While there are quite a few actuators on the market I am having trouble finding an input module.
    What I am concerned with is the ability to hardware check the status of the device.
    Can anyone recommend me a device with digital inputs that can be operated via HA?
  • #2 19045862
    Rysiek2
    CCTV and Stationary Alarms specialist
    Help: 447
    Rate: 659
    ducker1 wrote:
    I am planning to build a home automation system based on a zigbee gateway
    Do you already have a control panel or are you just planning to buy one?
  • Requesting alternatives to CC2531 for local Zigbee inputs
    #3 19046205
    ducker1
    Help: 69
    Rate: 83
    I plan to buy, CC2531 Zigbee2MQTT and base everything on Home Assistant.
    The automation will be in a house with an installation not suited to automation so a lot of the devices will be wireless.
    The input module can communicate in any way I want, as long as it is possible to read the statuses.
    I don't want to be tied down with equipment from one manufacturer and would also prefer a locally managed system rather than one managed from the cloud.
    If anyone has any alternatives to the aforementioned gateway, I would be grateful for suggestions.
  • #4 19046417
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    What states do you want to read?
    ducker1 wrote:
    If anyone has any alternatives to the aforementioned gateway then I would appreciate suggestions.
    - e.g. Conbee II is worth considering.
  • #5 19047433
    ducker1
    Help: 69
    Rate: 83
    States? Most logical, I want to check that specific tasks have been carried out.
    I am planning to install some custom solutions and want to make sure that the door lock, for example, locks correctly.
    I hadn't heard of conbee before but I've caught up now.
    It looks like a more polished solution but probably supports fewer devices.
  • #6 19047441
    Rysiek2
    Help: 447
    Rate: 659
    ducker1 wrote:
    States? Most logical, want to check that specific tasks have been completed.
    A very valid line of thinking. Automation without feedback (real state information) is generally pointless.
    In my opinion you should look for a solution under this condition. As actuators with feedback inputs you have, for example, the ZM-10
    http://www.a2s.pl/zigbee-module-p-7658.html
  • #7 19048195
    ducker1
    Help: 69
    Rate: 83
    And what about compatibility?
    Because supposedly zigbee but these ZM-10s only work according to the description with 2 types of gates.
    But this is exactly the kind of solution I'm after.
  • #9 20066837
    ducker1
    Help: 69
    Rate: 83
    I'm sticking with the solutions from ESP Home for now, but I'm looking further afield, so I'm closing the topic for now.
The discussion revolves around finding a Zigbee input module compatible with Home Assistant for home automation. The user is looking for a device that can provide digital input feedback, particularly for tasks like confirming the locking of a door. Recommendations include the CC2531 Zigbee2MQTT gateway and the Conbee II, with a focus on locally managed systems rather than cloud-based solutions. The ZM-10 module is suggested for its feedback capabilities, although concerns about compatibility with specific gates are raised. A resource for Zigbee2MQTT compatible devices is provided, highlighting options like reed switches and keypads, as well as the use of ESPHome for custom solutions.
