Which platform to choose under a SMART home and how to integrate Samsung Smart Things?
mail4skwarka 1893 10
How can I build a free, secure smart home platform that controls thermostatic heads, lights, Samsung SmartThings devices, cameras and smart sockets in one app, and what Zigbee hardware do I need?
Use Home Assistant as the main platform and app for controlling and monitoring the devices from one place [#20122176] Home Assistant has a large and growing list of supported integrations, plus unofficial integrations and ESPHome support, so it can connect to many different devices in several ways [#20123132] For Zigbee, you need a coordinator/gateway; a Conbee-type multi-board supporting different manufacturers was suggested [#20123132] For thermostatic heads, a Tado head was described as allowing manual changes to be blocked so the temperature is set only in the app, with no way to remove the lock directly on the thermostat [#20137709][#20140065]
  • Need a single platform for thermostats, lights, and SmartThings
    #1 20122173
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    Welcome
    To start with, what platform should I use to host all this?
    Preferably a simple, free and secure one.
    For a good day - 2 thermostatic heads will be connected (not yet purchased - so the question is what is the most suitable for the proposed platform solution),
    Then light switches - 5 rooms,
    Is it possible to integrate Samsung Smart Things devices - washing machine, and tv?
    Next step - connecting a camera, e.g. Tp-link,
    And probably smart sockets.
    Is it possible to control and monitor these devices using ONE application?
    thank you for your answers
  • #2 20122176
    K3
    Level 30  
    Help: 153
    Rate: 429
    mail4skwarka wrote:
    Can this be controlled , viewed via ONE app?
    Yes, Home Assistant.
  • #3 20122244
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    And zigbee devices? Plus a zigbee gateway?
  • Home Assistant integrations and Zigbee coordinator advice
    #4 20123132
    na_krótko
    You will find a list of supported integrations on the Home Assistant website, but new ones are coming in all the time anyway. In addition, check out the unofficial integrations, plus the supported integrations and standards of the EspHome project - which is also part of HA. In short I will summarise that you can connect almost anything, and many things in several ways. To support a Zigbee network you need a coordinator - I suggest a Conbee-type multiboard supporting different manufacturers.
  • Thermostatic heads with locked manual control
    #5 20137182
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    Thank you for your answers.
    Question regarding thermostatic heads
    Is there a thermostatic head on the market that allows manual temperature control to be disabled?
    I am also going to have Zigbee in my company and I would like to completely block the manual temperature control on the radiator.
    or that the temperature settings are locked in the software
    The parental lock is a different lock than the one I mentioned.
    Anyone had experience with such heads?
  • Thermostatic heads with app-only temperature control
    #6 20137709
    K3
    Level 30  
    Help: 153
    Rate: 429
    mail4skwarka wrote:
    Thanks for your answers.
    I will also be using Zigbee in my company and would like to completely block the manual temperature control on the radiator.
    or that the temperature setting is locked in the software
    Well, but the parental lock blocks manual changes on the head.
    I mean you can turn, but the temperature is only set in the app.
    I have a Tado, and that's how it works there....
  • #7 20138499
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    But the parental lock - adults will unlock it without any problem.
  • #8 20139284
    K3
    Level 30  
    Help: 153
    Rate: 429
    mail4skwarka wrote:
    But the parental lock - adults will unlock it without a problem.
    Only if they have the app. There is no way to remove the lock on the thermostat.
  • #9 20139938
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    what I mean is that parental locking is usually done by holding down the (-) key for 5 seconds.
  • #10 20140065
    K3
    Level 30  
    Help: 153
    Rate: 429
    mail4skwarka wrote:
    I mean that as a rule the parental lock is e.g. holding down the (-) key for 5 seconds
    In Tado you won't do it that way. The lock is via the app and there is no way to remove it directly from the thermostat.
  • #11 20140092
    mail4skwarka
    Level 19  
    Help: 26
    Rate: 138
    Thank you for your suggestions
    https://allegro.pl/oferta/glowica-termostatyczna-gtz08-zigbee-3-0-tuya-11294164517
    I write about this head that it is very quiet and good, a lot of parameters after updating the firmware
    and what are the differences with this GTZ04 model?
    https://stig.pl/glowica-termostatyczna-gtz04-zigbee-tuya-p-236.html
The discussion centers around selecting a platform for a smart home setup, with a preference for a simple, free, and secure option. Home Assistant is recommended as a versatile platform capable of integrating various devices, including Zigbee devices, with the use of a compatible coordinator like the Conbee multiboard. Users inquire about thermostatic heads that can disable manual temperature control, with Tado being mentioned as a model that allows app-based locking. The conversation also touches on specific Zigbee thermostatic head models, comparing the GTZ08 and GTZ04, highlighting their features and firmware capabilities.
