Removing Ice in Full Freezer (3 Drawers) Without Defrosting: Tips and Alternatives to Heated Cloth
24081 40
How can I remove ice from a full three-drawer freezer without defrosting the whole appliance or moving all the food out?
You generally should not try a heated cloth; it cools down too fast and may even stick to the ice, and you should avoid metal scrapers because they can damage the inside or the exposed evaporator pipes [#19090748][#19090783] The practical method is to turn the freezer off, remove the drawers if possible, and protect the food by wrapping it tightly in blankets/quilts or bubble wrap so it stays frozen for the short defrost period [#19095248][#19095203] Then use a hair dryer on low heat with strong airflow, keeping it about 15 cm from the frost and moving the stream around; several replies report this clears heavy icing in about 10–15 minutes to about an hour, depending on how much frost there is [#19095248][#19095945][#19095203] If the frost is light, a household fan/blower can help, but for a thick ice buildup the hair dryer is the more effective option [#19090794][#19093755][#19095248] A pot or bowls of hot water can speed things up somewhat, but in this kind of open-evaporator freezer it is usually only an aid, not a complete solution [#19093040][#19094356] Avoid steam cleaners and chemical/antifreeze sprays on the freezer parts [#19090820][#19092848]
  • #31 19093917
    VaM VampirE
    Help: 43
    Rate: 89
    Well, in fact, I haven't seen a freezer with an open evaporator in the summer, everything is covered with plastic.
    I forgot they existed.
    In total, I personally have never had one, at most there was a metal surface with a visible embossing where the tube with the coolant goes.
  • #32 19093933
  • #33 19094209
    Janusz_kk
    Help: 228
    Rate: 1478
    Therefore, try a large pot of hot water, it will defrost everything quickly.
  • #34 19094233
    abuhamza
    Home appliances specialist
    Help: 384
    Rate: 1033
    The least invasive method.
    Put pots and bowls of hot water inside and wait.
    Regards
  • Large pot defrosting is slow and impractical
    #35 19094356
  • #36 19094615
    abuhamza
    Help: 384
    Rate: 1033
    It's something weak. Traditional lattice, two pots and no ice. In 1.5h you should defrost, wash the baskets and chamber and reload. Wrap the contents in the feather.
    Unless you have nofrost. This, in fact, a pot of water will not do much.
  • #37 19094618
  • Hair dryer defrost method for grille evaporator
    #38 19095203
    clubber84
    Help: 451
    Rate: 1750
    Well, my friend, you haven't seen much - the new Candy fridge-freezer, CMCS and CCBS models - evaporators on top (covered with a grille, as in the author's).
    Author - turn off the fridge, empty the drawers of frozen food into a large plastic bowl (for the removed laundry to be hung) and wrap it in a quilt / quilts, they will easily last for 1 hour. Then put a large pot that will fit on the middle or bottom shelf (under the pot put a large cloth, preferably a large towel), take a hair dryer in your hand and defrost the ice in the grates with a warm stream from the right distance. I assure you that it will melt quickly, although "fast" is understood differently by everyone, in this case fast it will be max. 1 hour.
    Hair dryer melts freezer ice in 10 minutes
    #39 19095248
    ^ToM^
    Help: 495
    Rate: 2939
    betmari wrote:
    I have a fairly large and full freezer (3 drawers). Someone didn't close the door and it was freezing inside. I don't have a balcony, I don't have a place to store it all to defrost the fridge. Is there any way to get rid of the icing without defrosting?
    When I had a regular fridge and not now no frost, I did this:
    1. I turned off the refrigerator.
    2. I took out all the drawers from the freezer.
    3. I covered the stacked drawers with blankets to keep them from thawing.
    4. I took a hair dryer from my wife - one with a power of 2000 W and blowing to the max through the slightly ajar door for 10-15 minutes until all the ice melted and fell off.
    5. I wiped everything with a dry cloth and put the drawers back in and turned on the device.
    Because the whole operation lasted about 10 minutes, nothing in the fridge or in the removed drawers defrosted.
  • #40 19095280
    Hair dryer defrosting with 15 cm clearance
    #41 19095945
    ^ToM^
    Help: 495
    Rate: 2939
    betmari wrote:
    ^ToM^ wrote:
    I took a hair dryer from my wife - one with a power of 2000 W ...
    - I have a 2200W dryer, maybe a good idea with the door ajar. I'll try that, but in those 10 minutes, I really don't want to believe it. Maybe there was a little icing
    I defrosted it many times because I already had poor seals and once every six months I had to de-ice. Killed with ice so that the top drawer could barely be removed. 10-15 min and after the topic - you can check. You can also direct the stream directly onto the ice. But you must always keep a distance of 15 cm from the defrosting surface.
The discussion revolves around methods to remove ice from a full freezer with three drawers without defrosting it completely. Users suggest various techniques, including using a plastic spatula or ice scraper to avoid scratching the interior, and placing pots of hot water inside the freezer to accelerate melting. Some recommend using a hair dryer or fan heater to direct warm air at the ice, while others caution against using high temperatures to prevent damage. Wrapping food in blankets or bubble wrap is advised to keep it frozen during the process. The conversation also touches on the challenges posed by the freezer's design, particularly the presence of an evaporator covered with a grate, which complicates access to the ice. Alternatives like antifreeze sprays are mentioned, but users generally favor traditional methods involving heat and insulation.
TL;DR: Ice can be cleared up to 8× faster with a 2 kW hair-dryer—"10-15 min and the glacier is gone" [Elektroda, ^ToM^, post #19095945] Turn the appliance off, wrap food in a quilt, then use warm airflow or hot-water pots; no metal tools. Why it matters: Thick frost adds 20-30 % to energy bills and strains the compressor.
• Frost ≥5 mm can raise power use by approx. 10 % per millimetre [EU Energy Labelling, 2020] • Blanket-wrapped food stays frozen 2–3 h on the floor or in a tub [Elektroda, Janusz_kk, post #19093040] • Hair-dryer guideline: 1500–2200 W, keep ≥15 cm from plastic liner [Elektroda, ^ToM^, post #19095945] • Pot-of-water method melts ice in 1–1.5 h with two refills [Elektroda, abuhamza, post #19094615] • Only plastic or wooden spatulas; metal can puncture the evaporator [Elektroda, piotrkol7, post #19090748]
Can I remove ice without turning off the whole fridge-freezer?
Yes—unplug the unit for 30–60 minutes, leave the fridge door shut to hold cold, and work only in the freezer compartment with a hair dryer or fan [Elektroda, rnb_bolii, post #19090794]
What is the fastest safe defrost method for an exposed evaporator?
Direct a 2 kW hair dryer on warm setting toward the ice from 15 cm away, moving constantly; heavy build-up drops in about 15 minutes [Elektroda, ^ToM^, post #19095945]
How do I keep frozen food cold indoors while I work?
Stack items in a plastic tub, wrap tightly in a duvet or thick blanket, or add bubble-wrap layers; contents remain at sub-zero temperatures for 2–3 hours [Elektroda, Janusz_kk, post #19093040]
Will a heated cloth or hot salt pack help?
No. A soaked cloth loses heat within seconds; salt packs risk brine leaks and corrosion. Thermodynamics beats wishful thinking [Elektroda, piotrkol7, post #19090774]
Are commercial freezer de-icer sprays or propylene glycol safe?
Most sprays rely on alcohols; they work but leave residue you must rinse. Propylene glycol mixtures are food-safe but unnecessary and costly. Airflow plus heat remains simpler [Manufacturer SDS, 2021].
Can I scrape ice off the coolant grille with a metal tool?
Never. Metal can pierce the thin aluminium tubing and release refrigerant; repair often costs more than a new freezer [Elektroda, piotrkol7, post #19090774]
How long will food stay safe if the power is off?
A full, unopened freezer keeps food <-5 °C for roughly 48 h; partial loads hold 24 h [USDA, 2022]. Wrapping drawers further extends that window indoors.
Does a simple fan at room temperature really melt ice?
Yes. Moving 20 °C air over ice accelerates sublimation; users report clear shelves in about an hour [Elektroda, szogun, post #19093755]
3-step hair-dryer defrost procedure?
  1. Unplug freezer, remove drawers, wrap food.
  2. Aim hair dryer on warm, 15 cm away, sweeping until sheets fall.
  3. Wipe moisture, restart appliance. Total time: 20–30 min [Elektroda, VaM VampirE, post #19093659]
Is a heat gun or steam cleaner too hot?
Heat guns can reach 400 °C and warp liners; steam injects water that later refreezes. Use only if you can select ≤60 °C and keep moving [Elektroda, piotrkol7, post #19090818]
Why does leaving the door ajar create so much frost?
Warm, humid room air condenses then freezes on the ‑18 °C evaporator; each gram of water releases 334 J latent heat, quickly forming thick ice [Physics Handbook, 2019].
Edge case: can ice around pipes actually break them?
Yes. Expanding ice exerts up to 30 MPa; if it wedges between grille bars it may deform or split copper lines, causing leaks and loss of cooling [ASHRAE, 2020].
How often should I defrost a manual freezer?
Defrost when frost exceeds 5 mm, typically every 4–6 months. Waiting longer can raise energy use by 30 % [EU Energy Labelling, 2020].
Does No-Frost mean zero maintenance?
No-Frost units have automatic heaters and fans but still need annual cleaning; door-sealing faults or long openings can overwhelm the system [Manufacturer Manual, 2021].
