Klima Split: LG vs Samsung vs Kaisai vs Gree - Heating for 50m² House - Best Brand & Power?
kryst16 32526 8
  • #1 19139023
    kryst16
    Help: 7
    Rate: 261
    I am looking for air conditioning with a heating function (I mainly care about heating) for a house about 50m.
    Which power to choose?
    What company do you recommend?
    Is it worth considering Gree or Kaisai?
    I am asking for advice.
    mir111
    LG emergency
    Kaisai and gree are Chinese.
    If you want to heat, choose something more branded that has a good COP at low temperatures and modulates well.
    I recommend the Fujitsu KG series
  • Recommend branded unit with strong low-temperature COP
    #3 19141622
    kryst16
    Help: 7
    Rate: 261
    mir111 wrote:
    LG emergency
    Fujitsu makes nice equipment but unfortunately beyond my financial reach at the moment.
    All in all, I can choose from:
    1. GREE 5.4kW GWH18QD
    2. SAMSUNG 4.2kW AR35
    3. LG 5.1kW S12EQ
    It will not be the only source of heat because there is a fireplace in the house, the air conditioning is to be used for heating at night and after leaving for work, in addition, it is known for cooling.
    In fact, the Chinese GREE has the longest warranty because 5 years for everything, and LG gives 10 years for the compressor and 3 years for the rest.
    They are all around 3,000 (+/- 200 PLN).
  • #4 19151040
    TomD2121
    Help: 19
    Rate: 54
    You have not written what model of this Gree you offer. Either Lomo Eco or Lomo Luxury. I recommend the latter, although it costs about PLN 300. It is more suitable for heating, operates at - 22 degrees, has a hot start and intelligent defrost function. I have been heating my house with it for two years.
  • #5 19153073
    mazutmazut
    Rate: 17
    You gave Gree in the lomo luxury model, you can have a look at the amber standard, the price difference is negligible and the amber is a higher model and it will be more efficient.
  • #6 19153247
    TomD2121
    Help: 19
    Rate: 54
    For comparison, I looked at the catalog
    Gree Lomo Luxury: 5.13 / 5.28 kW cooling / heating capacity. SCOOP 4.0. A + class. Price 4.050 net
    Gree Amber Standard: 5.3 / 5.57 kW capacity. SCOOP 4.1. Class A + Price 4,390 net
    Parameters a bit better for Standard, but not much :-)
  • #7 19153285
    mazutmazut
    Rate: 17
    But the outdoor unit is larger, which translates into a larger exchanger, the minimum differences are also in the dimensions of the indoor unit.
  • Gree Lomo Luxury recommended for heating
    #8 19158142
    kryst16
    Help: 7
    Rate: 261
    I mean GREE LOMO LUXURY 5.4kW GWH18QD.
    Are there good reviews for Gree?
    Is it worth taking it?
  • #9 19158299
    TomD2121
    Help: 19
    Rate: 54
    It's a good "Chinese" for the money. I can write so much. There are better and worse devices. As I already mentioned, I myself have Luxury 5kW and it works fine.
The discussion centers on selecting an air conditioning unit with heating capabilities for a 50m² house. The user is considering brands like Gree, LG, and Samsung, with a focus on heating efficiency. Recommendations suggest opting for well-known brands with good Coefficient of Performance (COP) at low temperatures. The Gree Lomo Luxury model (5.4kW) is highlighted for its long warranty and performance, while comparisons are made with LG (5.1kW S12EQ) and Samsung (4.2kW AR35). Users discuss the Gree models' specifications, including the Lomo Luxury and Amber Standard, noting their heating capacities and efficiency ratings. Overall, Gree is considered a viable option, with positive reviews for its performance and value.
