[Solved] Hex V2 clone - cable not responding after reprogramming in VCDS
gerdzio2000 51633 4
  • Atmega162 clone no longer reports HW version
    #1 19159899
    gerdzio2000
    Rate: 18
    The Hex V2 cable, a clone from China, does not work for me. It worked without a problem a few months ago, initially it was bricked because I didn`t turn off the Internet and I had to reprogram it, but then it worked.
    Today I wanted to clear the errors with vcds and it doesn`t work, the message "cable not connected to the car" appears and the cable is connected, the green LED is on.
    I took it apart, checked February, corrected February and nothing, it still doesn`t work.
    Checked on several versions of vcds by the loader.
    What`s strange is that it doesn`t show me the HW version, previously I had 1.95 and now nothing.
    I wanted to re-upload it, but using the VAGCOM_EEWriteLang program it doesn`t work, the message "no response" appears, even though the cable is connected to the car.
    I checked on two cars, both were the same.
    In the control panel, the cable shows as: Ross-Tech Direct Usb Interface.
    Win10 pro system, built-in antivirus, disabled, net for vcds test disabled.
    The VAGCOM_HWType program does not read the cable, but others such as MProg or FT_Prog see the cable.
    Inside there are: Atmega162, FTDI1635
    At the very beginning, when I connected the VCDS, the vehicle was scanned and suddenly things went wrong and the cable stopped working.
    I checked on two laptops and the same thing.
    What`s going on and what can I do about it?
    The host file was also copied to the right place so that the cable wouldn`t turn into a brick again.
    I don`t know, maybe there`s something wrong with the drivers, does anyone have any other ones for Win 10 64? I tried the ones from vcds, uninstalled and reinstalled, but still the same.
    Moderated By CameR:
    gerdzio2000 wrote:
    maple from China
    However, the best place to get such help is the technical support department of the software manufacturer. I would also like to remind you that the use of illegal software is punishable by law, and computer software is not covered by the so-called permitted use.
    Reg. 3.1.1. Do not share other information that violates the law.
  • #2 19181038
    roadtransport
    Rate: 74
    I don`t know how to solve your problem because I`m a beginner in this field, but I have something to do in my car - check why the cruise control stopped working - that`s why I`m considering buying such a cable - a clone. Is it working? Is it worth the money and does it have a limited number of VIN numbers?
    Thanks for sharing your knowledge
    grafiq77
    Rate: 36
    I can help save the cables.
    E-mail. hgienek1(_at_)gmail.com
  • #4 19240990
    marutko
    Rate: 10
    He helped install the cable with truly angelic patience and great commitment. Thanks a lot!!
  • #5 19273389
    gerdzio2000
    Rate: 18
    Thank you for helping me save the cable. I recommend.
    Added after 44 [seconds]:
    The user received help and the cable was saved.
